[Gnome] Problème authentification d'utilisateur
Problème authentification d'utilisateur [Gnome] - Linux et OS Alternatifs
Marsh Posté le 10-06-2005 à 12:39:13
Bonjour à tous!
Je suis actuellement en root sur Gnome et j'ai voulu créé une section avec gnome mais lorsque je m'identifie avec la dite section, ici analfabete j'ai deux ecran noir puis cela revient à l'écran d'acceuil, je vous est donc poster le fichier log:
  1. Jun 10 12:29:30 PowderFire [fglrx] Maximum main memory to use for locked dma buffers: 929 MBytes.
  2. Jun 10 12:29:30 PowderFire [fglrx:firegl_stub_register] *ERROR* Unable to the open some already present DRM kernel module!
  3. Jun 10 12:29:41 PowderFire (analfabete-7927): starting (version 2.10.0), pid 7927 user 'analfabete'
  4. Jun 10 12:29:41 PowderFire (analfabete-7927): Failed to load source "xml:readwrite:/home/analfabete/.gconf": Failed: Could not make directory `/home/analfabete/.gconf': Permission denied
  5. Jun 10 12:29:41 PowderFire (analfabete-7927): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0
  6. Jun 10 12:29:41 PowderFire (analfabete-7927): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 1
  7. Jun 10 12:29:41 PowderFire (analfabete-7927): None of the resolved addresses are writable; saving configuration settings will not be possible
  8. Jun 10 12:29:41 PowderFire (analfabete-7927): No writable config sources successfully resolved, may not be able to save some configuration changes
  9. Jun 10 12:29:41 PowderFire (analfabete-7927): Failed to open saved state file: Failed: Failed to open gconfd logfile; won't be able to restore listeners after gconfd shutdown (No such file or directory)
  10. Jun 10 12:29:41 PowderFire (analfabete-7927): Failed to open saved state file: Failed: Failed to open gconfd logfile; won't be able to restore listeners after gconfd shutdown (No such file or directory)
Je pense qu'il s'agit d'un problème de permission mais comment faire pour le régler  :(
Jai déja essayer avec la commande adduser mais j'ai toujours le même problème  :pfff:
Marsh Posté le 10-06-2005 à 12:43:41
chown -R anafalbete ~analfabete
Ca devrait marcher :)
Message édité par deather2 le 10-06-2005 à 12:43:53
