Help pour slackware
Help pour slackware - Linux et OS Alternatifs
Marsh Posté le 21-02-2002 à 09:44:47
arg ben j'y connais rien en linux...
koike...
mais voila j'ai downloader zipslack une version alleger de slackware ben je l'install tout le tralala je boot et je login jusque la tout va en fait tout va mais ya pas une interface graphique dedans??
ou alors on m'a parler de gnome KDE et xfree c koi merci d'avance pour votre aide!!
Marsh Posté le 21-02-2002 à 09:51:29
:heink:
leger <-> X/Gnome/KDE ?
Marsh Posté le 21-02-2002 à 09:53:44
bon on oublie le LEGER c vrai!!
mais HELLLLLLLLLPPP!!
Marsh Posté le 21-02-2002 à 09:55:56
c'est bigSlack qu'il te faut :
ZipSlack
ZipSlack is a special edition of Slackware Linux that can be installed
      onto any FAT (or FAT32) filesystem with about 100 MB of free space. It
      uses the UMSDOS filesystem and contains most of the programs you will
      need. This means that you do not need to repartition your hard disk if
      you already have DOS or Windows installed. ZipSlack installs into a directory on your DOS filesystem. It can also be installed to and booted
      from a Zip disk.
This distribution is ideal for people who don't have a lot of hard
      disk space, do not have a fast Internet connection to download the entire
      distribution, or who want a Linux distribution they can carry around on
      a Zip disk.
BigSlack
New with Slackware 7.0 is BigSlack - another special edition of
      Slackware Linux.  BigSlack is similar to ZipSlack in that it is
      designed to be installed to a FAT filesystem, without the need to
      repartition your drive to get the benefits of running Slackware
      Linux.
The main difference in BigSlack and ZipSlack is what's included.
      BigSlack includes the majority of a full Slackware install -
      including a preconfigured X Windows setup and GNOME.  As such, it
      takes much more space than ZipSlack, requiring about 850 megs of free space.
BigSlack is ideal for people who have the hard drive space to
      spare, are looking to try out a full Slackware Linux installation,
      but do not want to repartition their hard drive.
[jfdsdjhfuetppo]--Message édité par minusplus--[/jfdsdjhfuetppo]
Marsh Posté le 21-02-2002 à 09:58:22
yep merci mais le seul soucis c que je doit installer sa sur un portable (DD6.4Go) mais j'ai po de lecteur cd juste un lecteur zip voila kles causes de mon choix!!
Marsh Posté le 21-02-2002 à 10:22:27
Y a ptet aussi moyen que tu copies le contenu du cd de la slack8 sur une partition du disque dur via le zip (j'espère que t'as accès à une bécane avec cd et zip) et tu pourras faire l'install à partir du disque dur après avoir booté avec les disquettes de démarrages.
* La vitesse de la lumière étant supérieure à celle du son, certaines personnes paraissent brillantes jusqu'à ce qu'elles ouvrent leur gueule. *
Marsh Posté le 21-02-2002 à 10:23:27
yep je peu tanter sa merci!!
