mov to avi avec mjpegtools (yuvsacler probleme)
mov to avi avec mjpegtools (yuvsacler probleme) - Linux et OS Alternatifs
Marsh Posté le 25-07-2005 à 12:45:07
hello,
j'ai une petite video .mov issu d'un appareil photo numérique. Je dois le graver sur un DVD pour le lire sur une platine de salon.
J'ai trouvé une méthode avec les mjpegtools, mais j'ai l'erreur suivante avec yuvscalerpour la conversion de la video.
[  13:01:44  ~ ] cat stream.yuv | yuvscaler -O VCD -n p | mpeg2enc -f 1 -r 16 -o  video.m1v
   INFO: [yuvscaler] yuvscaler 1.6.3-rc1 (15-02-2004) is a general scaling utility for yuv frames
   INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler
   INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION!
   INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM!
   INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION!
   INFO: [yuvscaler] VCD output format requested in PAL/SECAM norm
   INFO: [yuvscaler] input:   frame size:  320x240 pixels (115200 bytes)
   INFO: [yuvscaler] input:       chroma:  4:2:0 JPEG/MPEG-1 (interstitial)
   INFO: [yuvscaler] input:   frame rate:  30/1 fps (~30.000000)
   INFO: [yuvscaler] input:    interlace:  none/progressive
   INFO: [yuvscaler] input: sample aspect ratio:  ?:?
   INFO: [yuvscaler] from 320x240, take 320x240+0+0, NOT_INTERLACED/PROGRESSIVE
   INFO: [yuvscaler] scale to 352x288, 352x288 being displayed
   INFO: [yuvscaler] Scaling uses the BICUBIC algorithm,
   INFO: [yuvscaler] frame rate: 30.000 fps
   INFO: [yuvscaler] Scaling ratio for width is 10 to 11
   INFO: [yuvscaler] and is 5 to 6 for height
   INFO: [mpeg2enc] VCD default options selected
   INFO: [mpeg2enc] Selecting VCD output profile
++ WARN: [mpeg2enc] No aspect ratio specifed and no guess possible: assuming 4:3 display aspect!
   INFO: [mpeg2enc] Progressive input - selecting progressive encoding.
**ERROR: [mpeg2enc] For MPEG-1, aspect ratio code  0 is illegal
--verbose|-v num
    Level of verbosity. 0 = quiet, 1 = normal 2 = verbose/debug
--format|-f fmt
    Set pre-defined mux format fmt.
    [0 = Generic MPEG1, 1 = standard VCD, 2 = user VCD,
     3 = Generic MPEG2, 4 = standard SVCD, 5 = user SVCD,
     6 = VCD Stills sequences, 7 = SVCD Stills sequences, 8|9 = DVD]
--aspect|-a num
    Set displayed image aspect ratio image (default: 2 = 4:3)
    [1 = 1:1, 2 = 4:3, 3 = 16:9, 4 = 2.21:1]
--frame-rate|-F num
    Set playback frame rate of encoded video
    (default: frame rate of input stream)
    0 = Display frame rate code table
--video-bitrate|-b num
    Set Bitrate of compressed video in KBit/sec
    (default: 1152 for VCD, 2500 for SVCD, 7500 for DVD)
--nonvideo-bitrate|-B num
    Non-video data bitrate to assume for sequence splitting
    calculations (see also --sequence-length).
--quantisation|-q num
    Image data quantisation factor [1..31] (1 is best quality, no default)
    When quantisation is set variable bit-rate encoding is activated and
    the --bitrate value sets an *upper-bound* video data-rate
--output|-o pathname
    Pathname of output file or fifo (REQUIRED!!!)
--target-still-size|-T size
    Size in KB of VCD stills
--interlace-mode|-I num
    Sets MPEG 2 motion estimation and encoding modes:
    0 = Progressive (non-interlaced)(Movies)
    1 = Interlaced source material (video)
    2 = Interlaced source material, per-field-encoding (video)
--motion-search-radius|-r num
    Motion compensation search radius [0..32] (default 16)
--reduction-4x4|-4 num
    Reduction factor for 4x4 subsampled candidate motion estimates
    [1..4] [1 = max quality, 4 = max. speed] (default: 2)
--reduction-2x2|-2 num
    Reduction factor for 2x2 subsampled candidate motion estimates
    [1..4] [1 = max quality, 4 = max. speed] (default: 3)
--min-gop-size|-g num
    Minimum size Group-of-Pictures (default depends on selected format)
--max-gop-size|-G num
    Maximum size Group-of-Pictures (default depends on selected format)
    If min-gop is less than max-gop, mpeg2enc attempts to place GOP
    boundaries to coincide with scene changes
--closed-gop|-c
    All Group-of-Pictures are closed.  Useful for authoring multi-angle DVD
--force-b-b-p|-P
    Preserve two B frames between I/P frames when placing GOP boundaries
--quantisation-reduction|-Q num
    Max. quantisation reduction for highly active blocks
    [0.0 .. 4.0] (default: 0.0)
--quant-reduction-max-var|-X num
    Luma variance below which quantisation boost (-Q) is used
    [0.0 .. 2500.0](default: 0.0)
--video-buffer|-V num
    Target decoders video buffer size in KB (default 46)
--video-norm|-n n|p|s
    Tag output to suit playback in specified video norm
    (n = NTSC, p = PAL, s = SECAM) (default: PAL)
--sequence-length|-S num
    Place a sequence boundary in the video stream so they occur every
    num Mbytes once the video is multiplexed with audio etc.
    N.b. --non-video-bitrate is used to the bitrate of the other
    data that will be multiplexed with this video stream
--3-2-pulldown|-p
    Generate header flags for 3-2 pull down of 24fps movie material
--intra_dc_prec|-D [8..11]
    Set number of bits precision for DC (base colour) of blocks in MPEG-2
--reduce-hf|-N num
    [0.0..2.0] Reduce hf resolution (increase quantization) by num (default: 0.0)
--keep-hf|-H
    Maximise high-frequency resolution - useful for high quality sources
    and/or high bit-rates)
--sequence-header-every-gop|-s
    Include a sequence header every GOP if the selected format doesn't
    do so by default.
--no-dummy-svcd-SOF|-d
    Do not generate dummy SVCD scan-data for the ISO CD image
    generator "vcdimager" to fill in.
--playback-field-order|-z b|t
    Force setting of playback field order to bottom or top first
--multi-thread|-M num
    Activate multi-threading to optimise throughput on a system with num CPU's
    [0..32], 0=no multithreading, (default: 0)
--correct-svcd-hds|-C
    Force SVCD horizontal_display_size to be 480 - standards say 540 or 720
    But many DVD/SVCD players screw up with these values.
--no-constraints
    Deactivate constraints for maximum video resolution and sample rate.
    Could expose bugs in the software at very high resolutions!
--no-altscan-mpeg2
    Deactivate the use of the alternate block pattern for MPEG-2.  This is
    A work-around for a Bug in an obscure hardware decoder.
--dualprime-mpeg2
    Turn ON use of dual-prime motion compensation. Default is OFF unless this option is used
--custom-quant-matrices|-K kvcd|tmpgenc|default|hi-res|file=inputfile|help
    Request custom or userspecified (from a file) quantization matrices
--unit-coeff-elim|-E num
    Skip picture blocks which appear to carry little information
    because they code to only unit coefficients. The number specifies
    how aggresively this should be done. A negative value means DC
    coefficients are included.  Reasonable values -40 to 40
--b-per-refframe| -R 0|1|2
    The number of B frames to generate between each I/P frame
--cbr|-u
    For MPEG-2 force the use of (suboptimal) ConstantBitRate (CBR) encoding
--help|-?
    Print this lot out!
   INFO: [yuvscaler] output:   frame size:  352x288 pixels (152064 bytes)
   INFO: [yuvscaler] output:       chroma:  4:2:0 JPEG/MPEG-1 (interstitial)
   INFO: [yuvscaler] output:   frame rate:  30/1 fps (~30.000000)
   INFO: [yuvscaler] output:    interlace:  none/progressive
   INFO: [yuvscaler] output: sample aspect ratio:  ?:?
   INFO: [yuvscaler] Frame number 0
Message édité par Profil supprimé le 25-07-2005 à 13:26:49
Marsh Posté le 25-07-2005 à 14:40:57
essaye en specifiant l'aspect ratio ( "-a 2" pour du 4:3)
Edit: en fait c'est surement une connerie vu que c'est déjà le paramatre par default...
Message édité par Nis+ le 25-07-2005 à 14:42:37
Marsh Posté le 25-07-2005 à 15:07:26
oui, et j'avais essayé aussi en le mettant le "-a 2"
