Probleme avec apt-get
Probleme avec apt-get - Linux et OS Alternatifs
Marsh Posté le 05-04-2002 à 21:58:32
j'ai mis a jour libc6
puis libc6-dev mais j'ai du enlever pas mal de libs qui n'aurait plus fonctionné
et là, je veux reinstallé ces libs et j'ai :
BosS:~/Documents# apt-get install libstdc++2.10-dev
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  libstdc++2.10-dev: Depends: libc6-dev but it is not going to be installed
E: Sorry, broken packages
BosS:~/Documents# apt-get install libc6-dev
Sorry, libc6-dev is already the newest version
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
BosS:~/Documents#
je capte plus ! j'ai d/l libstdc++2.10-dev en .deb, j'ai pris les deux verison differentes du site debian, et ca coince tjs ! Help !
j'ai tenté un apt-get dist-upgrade et apres 6mo de d/l, tjs le mm pb !
-= In Kik00 101 I trust :o =-
Marsh Posté le 05-04-2002 à 22:42:38
quelle version de Deb et de packages ?
Marsh Posté le 05-04-2002 à 22:45:04
sur ma Sid, j'ai ces versions qui cohabitent
ii  libstdc++2.10  2.95.2-13      The GNU stdc++ library
ii  libstdc++2.10- 2.95.4-5       The GNU stdc++ library (development files)
ii  libc6          2.2.5-4        GNU C Library: Shared libraries and Timezone
ii  libc6-dev      2.2.5-4        GNU C Library: Development Libraries and Hea
sinon, en faisant un apt-cache show libstdc++2.10-dev tu n'as pas plus d'informations sur les versions des dépendances ?
Marsh Posté le 05-04-2002 à 22:58:16
bah une potato (cf signature !)
et les packages pah heu ... ceux de la sid pr libc6
BosS:~# apt-cache show libstdc++2.10-dev
Package: libstdc++2.10-dev
Priority: standard
Section: devel
Installed-Size: 1988
Maintainer: Debian GCC maintainers <gcc@packages.debian.org>
Architecture: i386
Source: gcc (2.95.2-13.1)
Version: 1:2.95.2-13.1
Provides: libstdc++-dev
Depends: libstdc++2.10 (>= 1:2.95.2-10), libc6-dev, g++ (>= 1:2.95.2-10)
Suggests: stl-manual
Conflicts: libstdc++-dev, libg++27-dev, libg++272-dev (<< 2.7.2.8-1), libstdc++2.8-dev, libg++2.8-dev, libstdc++2.9-dev, libstdc++2.9-glibc2.1-dev
Filename: dists/potato/main/binary-i386/devel/libstdc++2.10-dev_2.95.2-13.1.deb
MD5sum: 0a253175c67ddd72096344a12d23cb19
Description: The GNU stdc++ library (development files)
 This package contains the headers and static library files necessary for
 building C++ programs which use libstdc++. Be advised that this only works
 with the GNU C++ compiler (version 2.95), and no earlier library will work it.
Priority: standard
Section: devel
Installed-Size: 1681
Architecture: i386
Source: gcc (2.95.2-13)
Filename: dists/potato/main/binary-i386/devel/libstdc++2.10-dev_2.95.2-13.deb
MD5sum: 6296b8f461e1e25e986c1d1f96c0682d
BosS:~# ~
Marsh Posté le 05-04-2002 à 23:10:45
c'est un gros morceau quand même libc6.
Pour le coup je suis pas trop.
tu veux garder un base de potato et avoir libc6(-dev) et libstdc++...(-dev) version Sid.
Dans ton sources list tu as des mirroirs pour Potato ou Sid ? Sid si j'en crois ton apt-get install mais alors pourquoi ton apt-get dist-upgrade fait que 6Mo ? :pt1cable:
Marsh Posté le 06-04-2002 à 00:07:59
et je voualsi just un libc6 recent (vieille la patato !) et j'ai aps fais gaff j'ai d/l le unstable alors apres, ca a ete la spirale infernale donc ... voilà j'en suis a ce point bizzare !
bah logiquement j'ai une liste de Sid pour mon apt-get mais j'ai aps capter non plus pkoi le dist-upgrade faisait que 6mo !
enfin, je sais pas, donc j'ai lancé une aide pour qu'on me d/l e t me grave la sid et je me ferai une new install des que mon dd sera revenu du sav IBM !
ca ce passe là pr m'aider a avoir uen deb sid: http://www.clubachat.firstream.net [...] .php?t=345
d'ailleur y'a une section linux sur le forum Club Achat !
Merci pr ton aide ;-)
