[XFree86] problème au delà de 640*480
problème au delà de 640*480 [XFree86] - Linux et OS Alternatifs
Marsh Posté le 11-11-2002 à 19:00:33
hello,  :hello:
Je n'arrive pas à afficher le 800*600 sous blackbox, voici le fichier XF86Config-4:
Section "Files"
 FontPath "unix/:7100"   # local font server
 # if the local font server has problems, we can fall back on these
 FontPath "/usr/lib/X11/fonts/misc"
 FontPath "/usr/lib/X11/fonts/cyrillic"
 FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/lib/X11/fonts/Type1"
 FontPath "/usr/lib/X11/fonts/Speedo"
 FontPath "/usr/lib/X11/fonts/100dpi"
 FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
 Load "bitmap"
 Load "dbe"
 Load "ddc"
 Load "extmod"
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "pex5"
 Load "record"
 Load "speedo"
 Load "type1"
 Load "vbe"
 Load "xie"
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "keyboard"
 Option  "CoreKeyboard"
 Option  "XkbRules" "xfree86"
 Option  "XkbModel" "105"
 Option  "XkbLayout" "fr"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/psaux"
 Option  "Protocol"  "PS/2"
 Option  "ZAxisMapping"  "4 5"
EndSection
Section "Device"
 Identifier "Nvidia Riva TNT"
 Driver  "nv"
EndSection
Section "Monitor"
 Identifier "IBM"
 HorizSync 28-33
 VertRefresh 43-72
 Option  "DPMS"
EndSection
Section "Screen"
 Identifier "Default Screen"
 Device  "Nvidia Riva TNT"
 Monitor  "IBM"
 DefaultDepth 24
 SubSection "Display"
  Depth  1
  Modes  "800x600" "640x480"
 EndSubSection
  Depth  4
 EndSubSection
  Depth  8
 EndSubSection
  Depth  15
 EndSubSection
  Depth  16
 EndSubSection
  Depth  24
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 Screen  "Default Screen"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
EndSection
Message édité par Profil supprimé le 12-11-2002 à 19:04:09
Marsh Posté le 12-11-2002 à 19:06:22
[:yoyoz]
Marsh Posté le 12-11-2002 à 19:17:07
http://koala.ilog.fr/cgi-bin/nph-colas-modelines-fr
Tu rentre les paramètres fréquences de ton écran :
33 Horizontal et 72 Vertical et pas de possibilité de modeline en 800x600.
Sauf avec une fréquence de rafraichissement de 51
Calculé par http://koala.ilog.fr/cgi-bin/nph-colas-modelines-fr
BP maximum : 200 Mhz
Fréquence verticale maximum : 72 Hz
Fréquence horizontale maximum: 33 Khz
Fréquence de rafraîchissement minimale : 50 Hz BP minimum : 20 Mhz
Fréquence horizontale minimale : 30 Khz
ModeLine "name" dotclock width x x x heigth y y y #RefreshRate
  ModeLine "800x600" 36.55 800 840 1040 1120 600 602 614 640 #51Hz
Soit ton écran est vraiment pas adapté, soit tu cherche à te bousiller les yeux,
soit tu t'es trompé dans les fréquences.
Marsh Posté le 12-11-2002 à 19:28:59
merci de répondre :jap:
mon écran est un vieux IBM qui doit même pas faire 14", par contre je sais qu'il passait le 800*600 sous Windows.
Mais par contre je ne sais pas ce qu'il peut afficher en terme de fréquence, maintenant je ne pense pas que ce soit lié au fait que n'accède pas au 800*600, non?
bon, je regarde les liens tant que mes yeux le peuvent encore [:xx_xx]
Marsh Posté le 12-11-2002 à 20:20:46
Je sais que XFree4 n'utilise pas directement les modelines, en prenant en
compte les caratéristiques de ton écran.
On peut néanmoins forcer les modelines, en les rajoutant, pour outrepasser les
paramètres par défaut.
Windows ne prend t-il pas par défaut les caractéristiques de la carte ?
Certains auront surement de plus justes explications.
Marsh Posté le 13-11-2002 à 16:41:17
j'ai noté ce qui est indiqué au dos du moniteur:
P/no: 39G2709
V 200-250  :??:
A 0.4
HZ 50-60
et dans le fichier XF86CONFIG-4
Section "Monitor"
Identifier "IBM"
HorizSync 50-60
VertRefresh 43-72
les valeurs VertRefresh vous paraissent cohérentes?
vous connaissez des outils sous Debian pour avoir des informations sur l'affichage en cours?
J'aimerais bien avoir du 800*600 [:zoutte]
Marsh Posté le 14-11-2002 à 00:34:33
ModeLine "800x600" 51.60 800 840 1040 1120 600 602 614 640 #72Hz
Mais il y a une remarque sur le site qui te permet de calculer
les modelines :
http://koala.ilog.fr/colas/modelines-comments.html
Est ce que tu l'a lu ?
Il te reste les man, doc et howto d'XFree pour te trouver un
réglage satisfaisant.
Seul toi peux le faire ...
Marsh Posté le 14-11-2002 à 10:56:04
bon, j'ai lu tout azimuth mais ça ne marche pas mieux et pour ce qui concerne les modelines, le serveur ne veut même plus se lancer.
Je lance un appel à témoin, quelqu'un a t'il eu un problème similaire, càd ne pas pouvoir afficher autre chose que le 640*480? Sincèrement ça fait trois jours que je suis dessus, j'aimerais passer à autre chose de plus interessant :ange:
ps: j'utilise les drivers open source pour NVidia
Marsh Posté le 14-11-2002 à 13:15:48
