bsod driver_power_state_failure
bsod driver_power_state_failure - SAV - Ordinateurs portables
Marsh Posté le 02-11-2017 à 21:44:39
Alors voilà, depuis hier j'ai le même BSOD qui s'affiche Driver_Power_State_Failure..
J'ai mis tous mes drivers à jours, de même que la dernière version de windows..
Mon ordi plante quand je lance Photoshop, mais pas quand je joue à des jeux vidéos..
Je pensais que c'était dû à ma tablette graphique donc j'ai désinstallé et reinstallé ma tablette, mais rien n'y fait..
Je sèche un peu du coup.. Voici mon rapport WhoCrashed :
Computer name: DESKTOP-EN3K4A0
Windows version: Windows 10 , 10.0, build: 16299
Windows dir: C:\WINDOWS
Hardware: GL553VD, ASUSTeK COMPUTER INC.
CPU: GenuineIntel Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 8469168128 bytes total
Crash Dump Analysis
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Thu 02/11/2017 21:21:37 your computer crashed
crash dump file: C:\WINDOWS\Minidump\110217-46703-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x163960)
Bugcheck code: 0x9F (0x3, 0xFFFFB80458AAA060, 0xFFFFC88B0805F7F0, 0xFFFFB8045EF946F0)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
On Thu 02/11/2017 16:54:29 your computer crashed
crash dump file: C:\WINDOWS\Minidump\110217-140312-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFAD86E2D11060, 0xFFFF980633A67C40, 0xFFFFAD86E90D56F0)
On Thu 02/11/2017 11:21:45 your computer crashed
crash dump file: C:\WINDOWS\Minidump\110217-34796-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFA40342BB6060, 0xFFFFA2821CC47C40, 0xFFFFA4034BE3C400)
On Thu 02/11/2017 10:47:41 your computer crashed
crash dump file: C:\WINDOWS\Minidump\110217-34718-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFDD0F666A9060, 0xFFFFF8015BBB3C40, 0xFFFFDD0F6B422AD0)
Conclusion
9 crash dumps have been found and analyzed. Only 5 are included in this report. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Merci d'avance pour votre aide !
