nouvelle pate thermique noctua NT-H1
nouvelle pate thermique noctua NT-H1 - Air Cooling - Overclocking, Cooling & Modding
Marsh Posté le 13-11-2007 à 13:43:16
J'ai reçu à l'instant un mail de noctua présentant une nouvelle pate thermique non conductrice la Noctua NT-H1 et qui fonctionnerait 3 ans entre au maximum -50°C et +110 °C avec des performances très bonnes selon noctua :
Quelqu'un a testé ou aurait des infos précises sur cette nouvelle pate thermique ?
"Date:  Tue, 13 Nov 2007 10:54:07 +0100
De:  Jakob Dellinger <presse@noctua.at>
À:  Jakob Dellinger <presse@noctua.at>
Objet:  Noctua-News: Noctua presets NT-H1 high-end thermal compound
Vienna, 13th November 2007 - Noctua presented today a new premium-grade
thermal compound for enthusiasts who demand both exceptional performance
and maximum ease of use: NT-H1 is a hybrid compound of different
micro-particles that allows for minimum thermal resistance, excellent
ease of use and outstanding long-term stability.
"Many current TIM solutions have drawbacks either in terms of
performance or ease of use", explains Mag. Roland Mossig, Noctua CEO.
"Enthusiasts in particular, who frequently change their coolers, demand
both first class performance and trouble-free handling though. Our NT-H1
combines these two features and provides all the performance,
reliability and quality that Noctua users have come to expect from our
products."
NT-H1 exhibits extremely low thermal resistance as well as excellent
pliability and spreadability. As a result, the compound is not only
highly efficient but also very easy to use because there's no need to
smear it over the heat-spreader: Put one drop of NT-H1 onto the centre
of your CPU, install the cooler and that's it! NT-H1 provides top
performance right from the start and doesn't require a longer "burn-in"
time. If you happen to make a mess, that's no problem at all: NT-H1 is
not electrically conductive and fully compatible with all materials
commonly used in PC environments.
In addition to its excellent performance and handling, NT-H1 provides
decisive advantages in terms of reliability and long-term stability:
Thanks to its exceptional curing, bleeding, dry-out und thermal cycling
characteristics, NT-H1 can be used for several years without any problems.
NT-H1 is not only suited for air and water cooling, but also for use
with compressor coolers: Even at the very lowest temperatures, the paste
delivers full performance and remains easy to clean off.
Price and availability
NT-H1 is available with immediate effect in syringes of 1.4ml, which is
sufficient for at least 15 applications. The suggested retail price is
EUR 7.99 / USD 8.99.
Links:
More information:
http://www.noctua.at./main.php?sho [...] =13&lng=en
Specifications:
http://www.noctua.at./main.php?sho [...] g=en&set=1
Photos: http://www.noctua.at./inc/imagevie [...] r=0&lng=en
http://sigs.enjin.com/sig-swtor/8ca0a36e07029b9a.png
Marsh Posté le 13-11-2007 à 17:08:29
Moi ce que je veux savoir c'est quesqu'elle vaut par apport a l'artic silver 5 ...
« La société est bien foutue. Ils mettent des uniformes aux connards pour qu'on puisse les reconnaître. »
Marsh Posté le 13-11-2007 à 20:45:36
Interessant de savoir qu'elle fonctionnera 3ans... c'est un detail que j'aurais aimé savoir pour l'AS5... je me suis deja fait avoir avec une AS3 à l'epoque qui faisais plus son boulo...
Marsh Posté le 14-11-2007 à 00:00:05
Dans tous les cas perso je change ma pâte tous les 6 mois car soit je change de matos soit je vois quelle perd de son efficacité :D
Topic Vente
Marsh Posté le 14-11-2007 à 18:33:03
Et quand c'est la pate thermique du chipset de ta main CM que tu as ensuite passé en serveur 1 an apres que tu as ensuite revendu a qq'un de la famille encore 1an apres qui habite à 60km, tu fait comment ?
Marsh Posté le 14-11-2007 à 18:58:12
ben tu la change aussi ^^ pas le choix :)
MON FEED-BACK
Marsh Posté le 14-11-2007 à 19:23:34
mwhahahaha
