aide pour overclocker sont i 5 3570k
aide pour overclocker sont i 5 3570k - CPU - Overclocking, Cooling & Modding
Marsh Posté le 11-11-2013 à 13:31:46
bonjour j'ai un problème je n'arrive pas a overclocker mon i5 il toujours est stable a 4.2 ghz mais je n’arrive pas a le stabiliser a 4.3 ghz ,
pouvez vous d'aimer svp ?
Marsh Posté le 11-11-2013 à 14:46:11
voici les graphe d'un petit test de 8 min a 42 ghz
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/967581_689623017714741_757018775_n.jpg?oh=0276c83570b757175618f72fd48c48ec&oe=528310A4
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1464952_689623021048074_1368018143_n.jpg?oh=03d463929803772366168a76f052d6b4&oe=52833916
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1456933_689623024381407_1062064573_n.jpg?oh=1a09452e951e44a853627a3e8bfba01e&oe=528322EB
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1396592_689623027714740_2057060060_n.jpg?oh=f95d6325dc8f244f0d0f16324c7206b4&oe=5282F06D
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1392650_689623037714739_318198754_n.jpg?oh=c2d0ac689d23fc6a9ab83e8b5a0ff26f&oe=52833294
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1420565_689623034381406_1780779891_n.jpg?oh=11278ea5ed70165599831bc87f05343f&oe=5282F62D
https://scontent-b-mad.xx.fbcdn.net/hphotos-frc3/v/1415593_689623051048071_1008947698_n.jpg?oh=06938fc109815e7d2ffe0cf12f9928f4&oe=52835F71
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1462050_689623044381405_405283747_n.jpg?oh=04b5589bc80d72ff497b7a5cfc86c662&oe=528320DB
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1454457_689623054381404_1515123353_n.jpg?oh=4c3aa48bc133d6a8c51faf1fd4140f46&oe=5282EF29
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1454428_689623064381403_1145272232_n.jpg?oh=1c0ec74bc91ef979c92330aa473fe486&oe=5282E6E4
https://scontent-b-mad.xx.fbcdn.net/hphotos-frc1/v/1419954_689623071048069_1366582686_n.jpg?oh=da54b8b6f80475977f1a93cfcdfaa840&oe=52831B5B
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1418345_689623067714736_95520773_n.jpg?oh=7ec16881c1eea5b65592c1c7d8441b75&oe=5283204A
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1396575_689623081048068_109059634_n.jpg?oh=b97aad0adfd72ce07f3f7b90c2e72555&oe=52832B74
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1395036_689623084381401_1798962668_n.jpg?oh=ca92677ca67856ab51e560e5050f8f92&oe=52835F8F
https://scontent-b-mad.xx.fbcdn.net/hphotos-prn2/v/1394994_689623091048067_1771955515_n.jpg?oh=c21ef3a87f51904ce5f74f60bd9e0d51&oe=52831FB3
Marsh Posté le 11-11-2013 à 16:05:14
A 4.2 Gz il n'est pas proprement dit stable, 8 Mn ne suffise pas pour déterminé la stabilité , fait un essai de 30 Mn minimum si c'est stable durant ces 30 Mn, pousse a 4.3 Ghz et noublie pas de monté ton Vcore (comme il ne tient pas sans y toucher)
le mien est gourmand en V il demande prêt de 1,27v a 4.4Ghz tu peut pousser mais ne monte pas au dessus de 1.30v et vérifie tes T°, tu as quoi comme refroidissement ?
Cordialement J-p
tout fil coupé a la même longueur sera toujours trop court
Marsh Posté le 11-11-2013 à 16:13:17
j'ai deja fait un test 1 h a 4.2 ghz est ca vas je n'ais pas eux d'erreur
mais si j'augmente le vcore  j'ai un ecran bleu,  même a 4.2 ghz
vous me conseiller de metre combien en vcore pour 4.3 ghz ?
et pour le monter a 4.3 ghz je monte le ratio ou la fréquence bclv/peg ?
 et je suis en watercoolling
ma carte mere est une asus z77p8 vlk
Marsh Posté le 11-11-2013 à 17:56:56
PLL overvoltage activé?
Turbo désactivé?
« Quand j'étais jeune, j'étais très con. Je suis resté très jeune. »Jean-Claude Van Damme
Marsh Posté le 11-11-2013 à 19:18:41
internal PLL overvoltage : activer
parcontre si je désactive le mode turbo je ne peut plus changer le ratio je peut donc agir que sur la fréquence BCLK/PEG
ces le ratio du mode turbo que je change enfait mais ce qui fait qu'il est toujour s en mode turbo
Marsh Posté le 12-11-2013 à 20:28:10
personne pour m'aidez ?
Marsh Posté le 12-11-2013 à 20:33:21
Et au niveau des réglages de limitation de puissance du bios tu as cherché?
Marsh Posté le 12-11-2013 à 21:22:58
pour alimentation du cpu j'ai tout laisser en auto
la j'ai reusis a l'avoir stable a 4.3 ghz mais pas moyen a 4.4 ghz je ne sais pas pourquoi même en mettant un vcore a 1.3v ca ne passe pas
voici les impression écran de mon bios
https://scontent-b-cdg.xx.fbcdn.net/hphotos-prn2/v/1420599_690295827647460_354612222_n.jpg?oh=f068068928a9233cce50023ac1d7aefb&oe=52841CF6
https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/v/1420240_690295920980784_2073474777_n.jpg?oh=bebba98d86f1ef1a90070dde9ad44be8&oe=52846914
https://scontent-b-cdg.xx.fbcdn.net/hphotos-prn2/v/1470793_690295957647447_956352060_n.jpg?oh=6f1c7a7d84fd956701d03a158fbd0c31&oe=52845353
https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/v/1420079_690296147647428_732694076_n.jpg?oh=f0c05ac90ca2681a4ce286d1cabcc8eb&oe=5284376B
dsl pour tout les images
Message édité par valentinprout59 le 12-11-2013 à 21:24:13
Marsh Posté le 13-11-2013 à 10:31:50
Quand tu dis que lorsque tu augmentes le vcore à 4.3Ghz, ça plante : Quel vcore as tu mis pour 4.3Ghz.
A ce que je vois, ton proc est dans la moyenne haute pour 1.22v/4.2Ghz.
A part augmenter le vcore, je ne vois pas. Essaie par palier de 0.05v.
PS : post nous uniquement des screen occt du vcore et du core le plus chaud. A ce stade, on n' a pas besoin du reste.
i7 11700K,Asus ROG MAXIMUS XIII APEX Z590, Asus TUF RTX 4070 Super, 32go Crucial Ballistix 3200, M2 Samsung 980 Pro 500go / 970 Evo Plus 1to, Corsair RM 850W
Marsh Posté le 13-11-2013 à 13:53:03
J étais a 4,2 GHz a 1,215 v et le maintenant je suis a 4,3 GHz a 1,22v mais je n'arrive pas a atteindre les 4,4 GHz alors que j' augmente de 0,01v
Y a pas un paramètre de mal régler dans mon BIOS ?
Marsh Posté le 13-11-2013 à 14:51:04
augmente de 0.05v en 0.05v. Puis tu affineras en redescendant par de plus petit palier.
tu devrais arriver à 4.4Ghz entre 1.25 et 1.28v.
Ton proc semble être dans la moyenne, donc rien d'anormal.
Marsh Posté le 13-11-2013 à 20:29:15
bah j'ai tester j'ai commencer a  1.22 et j'ai monter de 0.01 en 0.01 donc 1.23 puis 1.24 comme ca jusqu'a 1.3 mais il n’étais pas stable , et plus j'augmenter et moins il étais stable je trouve
une mise a jour de mon bois ne m'aiderais pas ?
Marsh Posté le 13-11-2013 à 21:38:23
C'est assez étonnant car rien dans ton bios ne semble étrange.
As tu essayé de faire la même chose en laissant la load line calibration sur "auto"
Sinon, tu peux tenter la mise à jour du bios, mais c'est un peu la loterie : tu as 99% de chance que ça ne change rien mais ça peut aussi avoir l'effet inverse : Quand j'ai mis à jour le bios de ma MSI Z77-A GD65, j'ai ensuite eu besoin d'un peu plus de vcore à fréquence égale, sans modifier aucun autre paramètres.
Essaie d'abord sans la load-line calibration, et ensuite tu peux tenter la maj du bios mais sans aucune certitude.
Marsh Posté le 13-11-2013 à 22:14:32
j' essayer avec le load line en auto est c'est encore pire qu'en high a 1.23 il ne démarrer pas et a 1.24/1.25 il tenais la charge mais 10 seconde pas plus et a 1.27 il ne démarrer pas nonplus
lorsque j’étais en high  a 1.25v il  tenais la charge environ 2 a 3 min
mon processeur n'aimerais pas les tension élever?
Marsh Posté le 13-11-2013 à 22:21:38
enfait c a 4344 mhz qu'il tenais 2 a 3 min pas a 44 ghz
