Pb frequence mémoire
Pb frequence mémoire - CPU - Overclocking, Cooling & Modding
Marsh Posté le 21-04-2008 à 20:28:53
Bonjour a tous
Je suis débutant et j'ai déjà un problème :)
Sous CPU-Z ma ram est considéré comme de la 5300 alors que j ai acheté de la 6400.
http://valid.x86-secret.com/show_oc.php?id=349932
Que dois je faire pour rectifier le tir :)
Merci :)
ps: voila les caractéristiques de la mémoire :)
Memory type:   DDR2 SDRAM
Error correction:   NONE
Voltage interface level:  SSTL (1.8V)
Data width:   64 bits
Number of physical banks:  2 (double sided)
Number of logical banks:  4
Number of row addresses:  14       14
Number of col addresses:  10       10
Bank density:   512  512 MB
Primary RAM Width:  8        8 bits
Error checking RAM Width:  0        0 bits
Module density:   1024 MB
Refresh rate:   7812.500 us
Self-refresh:   Oui
Burst lengths supported:     4 8
CAS 3.0:
 Cycle time (tCYC) =    5.000 ns fMax =  200.000 Mhz
 Access time (tAC) =    0.600 ns fMax = 1666.667 MHz
CAS 4.0:
 Cycle time (tCYC) =    4.300 ns fMax =  232.558 Mhz
 Access time (tAC) =    0.500 ns fMax = 2000.000 MHz
CAS 5.0:
 Cycle time (tCYC) =    3.000 ns fMax =  333.333 Mhz
 Access time (tAC) =    0.450 ns fMax = 2222.222 MHz
InconnuInconnuMin delay, Bk/Bk random cols: 0 clocks
Min row precharge time (tRP): 15.000   ns
Min row active delay (tRRD):  7.500    ns
Min RAS to CAS delay (tRCD): 15.000   ns
Min Actv to precharge (tRAS): 45.000   ns
Addr/Cmd setup time:  0.200    ns
Addr/Cmd hold time:  0.270    ns
Data setup time:   0.100    ns
Data hold time:   0.170    ns
Write recovery time (tWR)  15.000   ns
Int Wr to Rd Cmd Dly (tWTR)  7.500    ns
Int Rd to Pchg Cmd Dly (tRTP) 7.500    ns
Min Act/Auto-Rfrsh Time (tRC) 60.000   ns
Min Auto-Rfrsh/Act Cmd (tRFC) 105.000  ns
Max Dev Cycle time (tCK max) 8.000    ns
Max DQS-DQ Skew (tDQSQ max) 2.400    ns
Rd data hold skew Fctr (tQHS) 3.400    ns
PLL relock time   0.000    ns
Memory analysis probe chars:  00
DIMM type:                   UDIMM (module width = 133.35mm)
FET switch external enable:  Non
Analysis probe installed:  Non
Includes weak driver:  Oui
Manufacturer's JEDEC ID code: 00000000 0000987f
Module manufacturing location: 4 (manufacture dependant)
Module part number:  99C5316-019.A00LF
Module revision code:  0 (manufacture dependant)
Module manufacturing date:  Wk 7  of 2008
Module serial number:  78cc1c8c
SPD revision:   1.1
Message édité par nene9134 le 21-04-2008 à 21:00:24
Marsh Posté le 21-04-2008 à 22:02:16
up :)
Marsh Posté le 22-04-2008 à 13:09:04
C'est pas au niveau du BIOS que tu as un soucis ?
La vitesse ddr est en Auto dans le bios ?
