Overclocker un P4 de 1.6 Ghz : possible ?
Overclocker un P4 de 1.6 Ghz : possible ? - CPU - Overclocking, Cooling & Modding
Marsh Posté le 15-04-2009 à 15:35:18
Salut à tous  :hello:
Je précise tout de suite, je n'ai jamais overclocké un CPU.
Mais la question m'intéresse.
J'ai une vieille config à base de Pentium 4 à 1.6 GHz :
Rapport d'Everest
Type de processeur : Intel Pentium 4, 1600 MHz (16 x 100)
Nom de la carte mère : Gigabyte GA-8IDMNF (3 PCI, 1 AGP, 1 CNR, 2 DIMM, Audio)
Chipset de la carte mère : Intel Brookdale i845
Mémoire système : 512 Mo (PC133 SDRAM)
Alimentation : Fortron de 245W
Rapport de CPU-Z
Processor(s)
Number of processors 1
Number of cores 1 per processor
Number of threads 1 per processor
Name Intel Pentium 4
Code Name Willamette
Specification Intel(R) Pentium(R) 4 CPU 1.60GHz
Package Socket 478 mPGA
Family/Model/Stepping F.1.2
Extended Family/Model F.1
Brand ID 8
Core Stepping D0
Technology 0.18 um
Core Speed 1599.9 MHz
Multiplier x Bus speed 16.0 x 100.0 MHz
Rated Bus speed 400.0 MHz
Stock frequency 1600 MHz
Instruction sets MMX, SSE, SSE2
L1 Data cache (per processor) 8 KBytes, 4-way set associative, 64-byte line size
Trace cache (per processor) 12 Kuops, 8-way set associative
L2 cache (per processor) 256 KBytes, 8-way set associative, 64-byte line size
Chipset & Memory
Northbridge Intel i845 rev. A3
Southbridge Intel 82801BA (ICH2) rev. 12
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 4x
AGP Side Band Addressing supported, enabled
Memory Type SDRAM
Memory Size 512 MBytes
Memory Frequency 133.3 MHz (3:4)
CAS# Latency (tCL) 3.0 clocks
RAS# to CAS# (tRCD) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 7 clocks
System
System Manufacturer Packard Bell NEC
System Name 00000000000000000000000
System S/N CV44900493
Mainboard Vendor NEC COMPUTERS INTERNATIONAL
Mainboard Model Intel i845
BIOS Vendor American Megatrends Inc.
BIOS Version 1.0K
BIOS Date 01/18/2002
Memory SPD
Module 1 SDRAM, PC133 (133 MHz), 256 MBytes, Micron Technology
Module 2 SDRAM, PC133 (133 MHz), 256 MBytes, unknown brand
Est-il possible d'overclocker cette config ?
Le refroidissement du CPU est passif, donc mis à part l'achat d'un ventirad s'adaptant au socket 478, que dois-je prévoir comme achat ?
Quel gain puis-je espérer ?
Dois-je abandonner l'idée ?
Mon Topic de Vente Hardware
