[Topic Officiel] DFI NFII (Mod) - "THE NEW 8KA BIOS rev 2"
DFI NFII (Mod) - "THE NEW 8KA BIOS rev 2" [Topic Officiel] - CPU - Overclocking, Cooling & Modding
Marsh Posté le 19-01-2004 à 14:31:40
http://www.lanparty.com.tw/LP/bank_images/lp_NFII_03b.jpg
Voici la nouvelle réference des NFORCE II , la DFI NF II .
existe en 4 versions :
-DFI NFII 400-AL (Nvidia nForce2 ATA/133 DDR400 AGPX8 Son + Lan intégrés ) = 63€
-DFI NFII Ultra-AL (Nvidia nForce2 SATA DDR400 AGPX8 USB 2.0 Son+LAN intégrés ) = 72€
-DFI NFII Ultra Infinity (Nvidia nForce2 SATA DDR400 AGPX8 USB 2.0 Son+LAN+IEEE1394 intégrés) = 85€
-DFI Lanparty NFII Ultra (DFI LanParty NFIIUltra400 DDR Raid I3E ..) = 133€
Lanparty / Ultra Infinity
Vcore max :2v  :sweat:
Vdd max   :1.9v :love:
Vddr max  :3.3v :love:
400-AL /Ultra-AL
Vcore max : 2v  :sweat:
Vdd max   : 1.9v :love:
Vddr max  : 2.8v  :(
Quelques caractéristiques:
CPU
AMD Athlon XP 266/333/400MHz FSB
AMD Athlon 200/266MHz FSB
AMD Duron 200/266MHz FSB
CPU Socket
Socket A
Chipset
nVIDIA® nForce2 chipset
 - nForce2 Ultra 400
 - nForce2 MCP-T
Memory
Supports dual channel memory interface
Supports up to 3GB memory (unbuffered DIMM)
Supports PC1600 (DDR200), PC2100 (DDR266), PC2700 (DDR333) and PC3200 (DDR400)
DDR SDRAM DIMM, 2.5V type
Three 184-pin DDR SDRAM DIMM sockets
BIOS
Award BIOS, Windows® 95/98/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
 - CPU/DRAM/AGP overclocking
 - CPU/AGP/DRAM/Chipset overvoltage
4Mbit flash memory
CMOS Reloaded
Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
 - Wake-On-PS/2 Keyboard/Mouse
 - Wake-On-USB
 - Wake-On-Ring (external modem)
 - Wake-On-LAN
 - RTC timer to power-on the system
AC power failure recovery
Hardware Monitor
Monitors CPU/system temperature
Monitors ±12V/5V/3.3V/VBAT(V)/5VSB(V) voltages
Monitors CPU/chassis fan speed
Read back capability that displays temperature, voltage and fan speed
CPU Temperature Protection function monitors CPU temperature during system boot-up
Audio
Realtek ALC650
AC'97 2.2 S/PDIF extension compliant codec
Supports Microsoft® DirectSound/DirectSound 3D
AC?97 supported with full duplex, independent sample rate converter for audio recording and playback
S/PDIF-in/out interface
6-channel audio output
LAN
nVIDIA® nForce2 MCP-T and ICS1893 Phy chips
Integrated IEEE 802.3, 10BASE-T and 100BASE-TX compatible PHY
Full duplex support at both 10 and 100 Mbps
PCI IDE
Supports ATA/33, ATA/66, ATA/100 and ATA/133 hard drives
UDMA Modes 3, 4, 5 and 6 Enhanced IDE (data  transfer rate up to 133MB/sec.)
SATA IDE with RAID
Silicon Image Sil3114 PCI to Serial ATA controller
Supports four SATA (Serial ATA) interfaces which are compliant with SATA 1.0
specification (1.5Gbps interface)
Supports RAID 0 and RAID 1
IEEE 1394
nVIDIA® nForce2 MCP-T and Agere FW803 Phy chips
Supports three 100/200/400 Mb/sec ports
AGP
Supports AGP 8x up to 2132MB/sec. and AGP 4x up to 1066MB/sec. bandwidth
for 3D graphics applications
Rear Panel I/O Ports
1 PS/2 mouse port
1 PS/2 keyboard port
1 DB-9 serial port
1 DB-25 parallel port
4 USB 2.0/1.1 ports
1 RJ45 LAN port
2 S/PDIF RCA jacks (S/PDIF-in and S/PDIF-out)
3 audio jacks: line-out, line-in and mic-in
2 audio jacks for center/bass and rear out
I/O Connectors
1 connector for 2 additional external USB 2.0/1.1 ports
3 connectors for 3 external IEEE 1394 ports
1 front audio connector for external line-out and mic-in jacks
2 internal audio connectors (AUX-in and CD-in)
1 S/PDIF connector for optical cable connection
1 connector for IrDA interface
4 Serial ATA connectors
2 IDE connectors
1 floppy connector
2 ATX power supply connectors
3 fan connectors for CPU fan, chassis fan and 2nd fan
Expansion Slots
1 AGP slot that supports 8x/4x AGP
5 PCI slots
PCB
4 layers, ATX form factor
30.5cm (12" ) x 24.5cm (9.64" )
OVERCLOCKING:
Bios:
-LANPARTY NFII ULTRA B 2004/1/21 BETA BIOS
-NFII ULTRA INFINITY 2004/1/21 BETA BIOS
-N24ID217.b01 NFII ultra infinity with 12-18
-N24ID217.b02 NFII ultra infinity with 01-31
-N24LD217.b01 LP NFII ultra B with 12-18
-N24lD217.b02 LP NFII ultra B with 01-31
NOUVEAU BIOS BETA: 19/6
-Bios 19/06 pr LP NFII ultra B
-Bios 19/06 pr Ultra Infinity
*For Live update:
To solve the occasionally auto reboot issue.
To solve the cold-boot bug after removing and re-plugging power cord.
To solve the Bug of S3 Resuming. (YAISSE !!!)
To also Support "Boot Menu" feature.
To also include the micro codes of mobile CPUs.
To improve the BIOS writing-back process to minimize the possibility in getting BIOS crashed.
To add new RAID BIOS of Sil 3114 in version 5.0.35.
Mod:
Vcore
http://membres.lycos.fr/boblemagnifique/Overclocking/DFI/Dfivcore.jpg
Vdd & Vddr
http://upl.silentwhisper.net/uplfolders/upload0/vddandvdimmmodds.jpg
Message édité par boblemagnifique le 24-02-2005 à 23:49:11
Marsh Posté le 19-01-2004 à 14:58:34
drapal :love:
des news de tanker avec cette mobo ?
Marsh Posté le 19-01-2004 à 17:07:16
Bon, alors plus besoin de modder le vdimm, mais maintenant il faut recommencer à modder le vcore.  [:benou_suisse]  [:arg]
Marsh Posté le 19-01-2004 à 17:12:13
Quelqu'un a cette mobo ????
drapal aussi :hello:
Dommage que le vcore s'arrête a 2V !!
elle est vendu autre part que chez yourland cette mobo ?
DFI NFII : 101.00 ? (662.52 Fr) chez yourland donc :D
Message édité par popol_55 le 19-01-2004 à 17:18:44
Philips HUE || Ikea Hack
Marsh Posté le 19-01-2004 à 17:51:30
bob: si tu pouvais expliquer la difference entre les 4 modeles thx;)
heu nivo coeff c une nf7 like ou alors elle monte pas haut dessus de 12.5 ?
Marsh Posté le 19-01-2004 à 20:33:21
elle m interesse bien cette carte , je pense que le mois prochain , je la prends a moins que je vends ma NF7-S , c vrai que pour le vcore , ca va etre + chaud , il me reste encore mon 1800+ DLT qui aime pas au dessus de 2v , donc je testerais bien ...
Marsh Posté le 19-01-2004 à 22:16:37
moi aussi je pense la prendre incesament sous peu car la dfi nf2 ultra revb moii je l'adore mais le voltage cpu berk doit y'avoir un chtit mod possible pour augmenter le voltage cpu :)
Marsh Posté le 19-01-2004 à 23:23:53
ptin elle rox dommage que le vcore soit pas plus haut :cry:
je me la prendrais bien si y a un mod vcore v d abord tester ma nf7-s rev2 de sav :D
Marsh Posté le 19-01-2004 à 23:28:13
idem vais envoyer ma NF7-S en sav et si ca marche , je vends ma NF7 et me prends un chtite DFI  :D
Marsh Posté le 19-01-2004 à 23:28:32
faut changer le 4258
c plus dactualite
http://upl.mine.nu/uplfolders/upload4/278sisofthyperx.jpg
Marsh Posté le 19-01-2004 à 23:31:22
;) jsuis impatient de la monter avec ma BH5  :)
Marsh Posté le 19-01-2004 à 23:35:45
vous vous plaigner du vcore  1.850 sur mon asus :cry:
Marsh Posté le 19-01-2004 à 23:36:01
Y'a pas de risque de mettre de la ram @3,3V pour de la mushkin par exemple ?.
Marsh Posté le 19-01-2004 à 23:37:16
non justement elle demande que ca
Marsh Posté le 19-01-2004 à 23:38:08
ben a 3v , elle est tiede ... dc bon je la laisse tjrs a donf pour monter + haut  :ange:
Marsh Posté le 19-01-2004 à 23:39:04
:love:  :love:
" Quel est le but du capital ? Le but du capital c'est produire pour le capital. L'objectif, lui, est illimité. L'objectif du capital c'est produire pour produire." - Deleuze || André Gorz - Vers la société libérée
Marsh Posté le 19-01-2004 à 23:40:58
3v sur NF7 ? mod inside  :ange:
Marsh Posté le 19-01-2004 à 23:41:46
2.9v bios - 3.02/3.07v réel
Message édité par boblemagnifique le 19-01-2004 à 23:42:01
Marsh Posté le 19-01-2004 à 23:42:41
sur ma leadtek , c pareil la ram est sur le 5v , je peux mettre 4v je pense g deja ete a 3,92v mais ca sert a rien.
le max que j aie fait c est 272 de fsb synchro avec 3,60v. j ai pas pu screen alors ca ma saoulé , je screen 265 facile apres j ai pas voulu me faire chier ca m a vener ptet le chip qui veut des volts mais j ai pas trouvé de mod  :cry: .
Message édité par misteroa2ster le 19-01-2004 à 23:45:35
Marsh Posté le 19-01-2004 à 23:44:36
chipset qui limite ? vdd ?
Marsh Posté le 19-01-2004 à 23:45:57
bah y a 1,9v ds le bios qd mm.
Marsh Posté le 19-01-2004 à 23:46:50
ba alors c naze, mes BH5 pc3500 mushkin tiennent tout juste le 228 en 2-2-2-11  :o
Marsh Posté le 19-01-2004 à 23:52:23
230 moi  :sweat: , j espere tenir les 250/260 en 2-2-2-11 avec la DFI  :ange:
Marsh Posté le 20-01-2004 à 00:23:14
quand vous dites que c'est raccordé sur le 5volt je vois pas là ?:sweat:
Marsh Posté le 20-01-2004 à 01:02:39
bah c est plus limité par les 3,3v de l alim koi
Marsh Posté le 20-01-2004 à 01:06:35
clair mon 3.3v de la dfi traine a 3.15v....merci antec
mon topic de vente
Marsh Posté le 20-01-2004 à 01:12:06
noooky a écrit :
drapal :love:
ouaip, il a screene 265, mais il etait un peu feignant ce week end :d il a pas bcp essaye
Marsh Posté le 20-01-2004 à 07:04:53
 :D
Marsh Posté le 20-01-2004 à 14:11:23
upi
Marsh Posté le 20-01-2004 à 15:47:21
Marsh Posté le 20-01-2004 à 17:47:31
ou sont les beta bios et Vdimm mod ? :P
(trop paresseux pr voir ou qu'ils sont ;))
Marsh Posté le 21-01-2004 à 16:46:30
Sur toutes les reviews que je matte , je voit nul part qu'on peut monter le voltage ddr aussi haut ........
je voit seulement jusqu'a 2,8v alors rassurez moi ou je garde ma AN7 , en + le vcore jusq'a 2v seulement ca suuuuux ....
Marsh Posté le 21-01-2004 à 16:52:55
ça monte a 3.3v je confirme
mod vcore possible  :)
mon topic de vente
Marsh Posté le 21-01-2004 à 16:55:14
ca donne koi avec ta BH5 alors ?
Marsh Posté le 21-01-2004 à 17:20:45
3,3v d'origine donc , et sur les 2 versions ? la A et la B ?
j'ai peur de faire une boulette en la prenant (B) .
sinon le mod vcore semble easy ?
Marsh Posté le 21-01-2004 à 17:23:56
Marsh Posté le 21-01-2004 à 17:28:25
suffisant pr un DLT ;)
Marsh Posté le 21-01-2004 à 17:34:36
yo mon dlt prend 2,3v  :p
alors sur toutes les dfi nf2 c vddr a 3,3v d'origine ?
Marsh Posté le 21-01-2004 à 17:36:02
Elle a l'air vraiment pas mal cette mobo ;)
Tanker il l'a HT ou la sienne ?
Faudrais que je passe chez lui histoire de me marrer j'habite po loin ...
Marsh Posté le 21-01-2004 à 17:43:51
a yourland mais c une reve a+
c pas la meme rev que le gars qui f 284
