GTX 660TI OC 2048MB 2G GIGABYTE
GTX 660TI OC 2048MB 2G GIGABYTE - GPU - Overclocking, Cooling & Modding
Marsh Posté le 25-09-2014 à 12:52:59
Bonjour aider moi a boosté ma carte au maxi que je puise profiter surtout que je puise changer avec mon GIGABYTE OC_GURU.
https://imagizer.imageshack.us/v2/451x477q90/r/905/ybyQbx.png
que je doit changer merci;
System Information
Time of this report: 9/24/2014, 21:57:59
       Machine name: ANTONIO-PC
   Operating System: Windows 7 Édition Familiale Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.140303-2144)
           Language: French (Regional Setting: French)
System Manufacturer: MSI
       System Model: MS-7808
               BIOS: BIOS Date: 09/30/13 09:16:33 Ver: 04.06.05
          Processor: Intel(R) Core(TM) i5-2450P CPU @ 3.20GHz (4 CPUs), ~3.2GHz
             Memory: 8192MB RAM
Available OS Memory: 8126MB RAM
          Page File: 4182MB used, 12069MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 660 Ti
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 660 Ti
           DAC type: Integrated RAMDAC
         Device Key: Enum\PCI\VEN_10DE&DEV_1183&SUBSYS_35521458&REV_A1
     Display Memory: 4038 MB
   Dedicated Memory: 1989 MB
      Shared Memory: 2048 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Moniteur Plug-and-Play générique
      Monitor Model: SONY TV
         Monitor Id: SNYA401
        Native Mode: 1920 x 1080(p) (60.000Hz)
merci encore les expert.
Marsh Posté le 25-09-2014 à 18:45:35
Alors salut a toi,
En premier télécharge ce logiciel (de Benchmark) pour tester la stabilité de ton OC : http://www.guru3d.com/files-get/un [...] oad,1.html
Ensuite télécharge GPU-Z (pour permettre de faire du monitoring) : http://www.techpowerup.com/downloa [...] -z-v0-7-9/
Après avoir télécharger et installer ces deux logiciel tu peut commencer par lancer GPU-Z et aller dans l'onglet "sensors" ensuite lance valley et choisi le preset Extrême HD, après le chargement lance le test avec F9.
A la fin du test va dans GPU-Z et clique sur la fréquence de la ligne "GPU core clock" jusqu'à que "max" apparaisse a coté de la fréquence : c'est ta fréquence max que ta carte monte en normal.
Pour commencer l'overclocking dans OC GURU monte le POWER TARGET a fond (112%) et augmente 13 par 13 le GPU CLOCK, a chaque fois que tu augmente de 13 tu refait un test dans le benchmark.
A partir d'un certain palier tu trouvera des artefacts ou le driver Nvidia crashera (écran noir pendant un cour instant) et a partir de la tu ira chercher ta fréquence max dans GPU-Z (que tu aura laisser tourner pendant le bench) et tu poura augmenter la MEMORY CLOCK de 100 par 100 jusqu’à que tu trouve artefacts/crash.
Et voila j'attend ton retour
Message édité par quentincc le 25-09-2014 à 18:46:48
Mon topic d'achat/vente :)
Marsh Posté le 26-09-2014 à 12:20:51
test benchamark
grafique - 1320MHZ
memorie - 3004MHZ
temperature - 70
fps 90
https://imageshack.com/i/kqeAu4ekp
https://imageshack.com/i/hli2fOlLp
je change quoi maintenant merci quentincc
Message édité par antonio vilas le 26-09-2014 à 12:27:29
Marsh Posté le 26-09-2014 à 20:31:13
Ta tester de monter la mémoire?
Si tu peut pas monter plus sans avoir des crash ou autres c'est que tu as fini d'overclocker ta carte graphique et maintenant il faudrait que tu joue a un jeu (sans quitté) pendant une dizaine d'heure histoire de savoir si c'est stable en H24.
