waterblock zalman 8800 gtx [avis] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 19-02-2010 à 00:10:43
tit up
j ai trouver ca sur le site de zalmann ca vous inspire quoi ??
visiblement c est de l alu c est pas trop mal ??
a 30 roro le block vous prendriez ??
ZM-GWB8800 Ultra/GTX
VGA water-block produced with dimple-processing, designed for use with NVIDIA Geforce 8800 Ultra/GTX series.
 Zalman’s innovative dimple-type processing technology allows lightness in weight and excellent cooling performance.
 Pure aluminum-base material water bock provides excellent heat transfer, and anodized base prevents corrosion.
 High performance thermal pads with excellent elasticity provide great adhesion to all heat-generating components.
 The optimized design allows easy installation and direct cooling of RAM, FET, and I/O chipset.
*  Notice
This CPU water block is a component for water cooling systems for CPUs and cannot be used independently. It must be used with a water cooling system such as ZALMAN's RESERATOR 1 Plus/ RESERATOR 1 V2/RESERATOR 2/ RESERATOR XT Water Cooling System.
Dimensions  93(W) x 183(L) x 31(H) mm
Weight  420g
Base Material  1) Water Block Cover / Base : Pure Aluminum 2) Fitting : Brass
Compatible Tubes (Outer x Inner)  13 x 9mm, 12 x 8mm, 11 x 8mm, 10 x 8mm
- VGA Water Block Assembly
- Nine (9) Nipples
- Nine (9) Nuts
- Two (2) PVC Washer Plates
- Ten (10) Springs
- Ten (10) O-rings
- Two (2) Tube Clamps
- Thermal Grease
- Thermal Pads
   One (1) 14 x 14 x 1T (for I/O Chipset Contact)
   Four (4) 7 x 23 x 1T (for FET Contact)
   Three (3) 16 x 70 x 1T (for RAM Contact)
- User’s Manual
Marsh Posté le 17-02-2010 à 14:28:18
Bonjours
j ai trouver une bonne occasion pour acheter des waterblock GPU zalmann pour 8800 gtx je voulais savoir votre avis la dessus
dans le but de me faire un water cooling pour gpu *2 + cpu + mosfet carte mere
