[workblog]mountain mod ufo
mountain mod ufo [workblog] - Water & Xtreme Cooling - Overclocking, Cooling & Modding
Marsh Posté le 05-03-2012 à 16:23:49
voila mon mod quasi terminé encore quelques regalges et affinements oc
details de la config:
boitier:mountain mod ascension black mirror
processeur:intel i7 2600k
carte mere:asus maximus 4 extreme
ram:16go corsair dominator
gpu:quad sli gtx 590
alim:enermax 1250w
dd:ssd revodrive x2 100go+ vertex3 100go+ vertex 2 120go+3 *2to samsung
watercooling:4 rad slim 360 xspc pompe; laing d5 + top;reservoir baie xspc
WaterBlock CPU EK-SUPREME HF FULL NICKEL,waterblock gpu ek +backplate noir acetal
embouts bitspower 13mn,tuyau 13/19 tygon blanc
ecran:tri ecran 3d vion surround acer
http://img543.imageshack.us/img543/975/1kjpu.jpg
http://img818.imageshack.us/img818/4012/6n911.jpg
http://img813.imageshack.us/img813/4016/41e7j.jpg
http://img684.imageshack.us/img684/5250/cn92o.jpg
http://img525.imageshack.us/img525/1212/ddwhx.jpg
http://img99.imageshack.us/img99/9989/dit9t.jpg
http://img201.imageshack.us/img201/7788/gexaf.jpg
http://img210.imageshack.us/img210/7201/gigzm.jpg
http://img577.imageshack.us/img577/2580/goqhq.jpg
http://img585.imageshack.us/img585/5159/hgzzu.jpg
http://img12.imageshack.us/img12/687/hyknv.jpg
http://img171.imageshack.us/img171/713/i3bsg.jpg
http://img708.imageshack.us/img708/1893/img1718q.jpg
http://img4.imageshack.us/img4/34/img1719l.jpg
http://img35.imageshack.us/img35/9537/img1720t.jpg
http://img705.imageshack.us/img705/7964/img1721dv.jpg
http://img577.imageshack.us/img577/6492/img1740j.jpg
http://img402.imageshack.us/img402/5778/img2005ka.jpg
http://img594.imageshack.us/img594/3685/img2006j.jpg
http://img585.imageshack.us/img585/4907/img2007u.jpg
http://img17.imageshack.us/img17/7633/img2008ha.jpg
http://img802.imageshack.us/img802/1509/img2115d.jpg
http://img855.imageshack.us/img855/1011/img2116k.jpg
http://img444.imageshack.us/img444/936/img2117qy.jpg
http://img842.imageshack.us/img842/3189/img2118ux.jpg
http://img405.imageshack.us/img405/3558/img2120yi.jpg
http://img18.imageshack.us/img18/6209/img2121aq.jpg
http://img841.imageshack.us/img841/3903/img2123uh.jpg
http://img821.imageshack.us/img821/2484/img2124qe.jpg
http://img141.imageshack.us/img141/3562/img2125d.jpg
http://img837.imageshack.us/img837/5013/jgkw9.jpg
http://img836.imageshack.us/img836/2395/jsl7y.jpg
http://img26.imageshack.us/img26/5973/mlsot.jpg
http://img3.imageshack.us/img3/1066/ncv3l.jpg
http://img585.imageshack.us/img585/3356/otnig.jpg
http://img856.imageshack.us/img856/3964/pzq7s.jpg
http://img813.imageshack.us/img813/6310/qrx3h.jpg
http://img190.imageshack.us/img190/9536/r7nyz.jpg
http://img576.imageshack.us/img576/1293/sa2hi.jpg
http://img192.imageshack.us/img192/4879/t8k9v.jpg
http://img191.imageshack.us/img191/6313/tjrlu.jpg
http://img138.imageshack.us/img138/1034/wi6wj.jpg
http://img21.imageshack.us/img21/2640/xb7jb.jpg
http://img812.imageshack.us/img812/5646/zdrfz.jpg
http://img99.imageshack.us/img99/2876/zmj9s.jpg
Message édité par ambroisec le 05-03-2012 à 17:03:36
Marsh Posté le 05-03-2012 à 16:33:04
Sympa tout ça mais des photos plus grandes ne seraient pas du luxe.
Marsh Posté le 05-03-2012 à 17:04:02
voila qui est fait
Marsh Posté le 05-03-2012 à 17:19:14
Beaucoup mieux.
C'est encore plus sympa avec des photos de bonne tailles.
Très belle intégration.
Marsh Posté le 05-03-2012 à 17:52:45
par contre petite question je trouve mes températures un peu haute surtout que je n ai rien oc
en idle ca irait encore a peu pres mes gpu sont a  40-45 et full 60-70
et le cpu en idle 35-40 et full monte assez haut jusqu a 60-70 et sous bf3 apres une heure de jeux le cpu s est coupé atteignant 90 degre
tres etrange
des idées ?
Marsh Posté le 05-03-2012 à 17:59:04
Tu as un SLI de 590 je te rappelle. Donc 4GPU.
Les 17 chauffent également pas mal.
Sinon fait les vérification standards (pâte thermique, waterblock ...).
Si tu n'as pas peur du bruit tu peux mettre touts tes radiateur en push/pull.
Marsh Posté le 05-03-2012 à 18:04:02
:ouch: la taille !
Ta du déposer un permis de construire à la mairie ?!
Très belle intégration en tout cas  :sol:
G5-yufi - Apple Cube
Marsh Posté le 05-03-2012 à 18:11:08
je vais refaire la pate de mon cpu deja pour voir
etsinon je croisqueje vais rajouter un rad 120 juste apres mes gpu pour aller alimenter le cpu ou l eau n arrive pas trop a refroidir entre les deux car il est vrai les 4 gpu chauffent quand meme pas mal
Marsh Posté le 05-03-2012 à 18:17:37
Faire deux circuit pourrait aussi aidé, mais il faut les moyens (quoi que juste une pompe et de nouveaux tuyaux).
Marsh Posté le 05-03-2012 à 18:19:44
j y ai pensé aussi
Marsh Posté le 05-03-2012 à 18:24:19
Vu qu’apparemment c'est processeur qui souffre à cause de tes cartes graphiques et que les températures de ces dernières sont acceptables, je crois que c'est la meilleure solution.
