HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! - Overclocking, Cooling & Modding
Marsh Posté le 18-06-2001 à 19:34:18
Marsh Posté le 18-06-2001 à 19:36:01
Mettre un lien dans chaque forum vers tes conneries...
Pfff P I T O Y A B L E
L'ingénieur chipset nortiaux : Une iFricandelle svp ! "Spa du pâté, hin!" ©®Janfynette | "La plus grosse collec vivante de bans abusifs sur pattes" | OCCT v12 OUT !
Marsh Posté le 18-06-2001 à 19:37:16
pas de lien vers un autre post !!!!
copier coller tu connais ?
 :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :bounce:  :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot: :hot:  :hot:  :hot:  :hot:  :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie: :spookie:
"Phildar t'es vraiment une pute pas finie toi! Et Manu le gros porc arrete de t'marrer!"
