vous connaissez elina fan?
vous connaissez elina fan? - Overclocking, Cooling & Modding
Marsh Posté le 08-09-2001 à 02:05:37
paske y font des produit assez marrant ; jai choper un chti 5*5*15 ki ma marque par sa puissance (marche en 5v a 4000/4500 t kan jle passe en 12 ca fait helicoptere) avec armature en metal ..bref ca ma interpele et voila ce ke je trouve :
http://www.indek.com/products/stylefan/images/s18f.jpg
18*18*65 303CFM 63dB :>
ou encore des machins zarb genre :le miniblow et le radial cooler
http://www.indek.com/products/cpucooler/images/mb_lis.jpg
http://www.indek.com/products/cpucooler/images/rc_lis.jpg
pire le therm-a-pipe...je ne peut ke vous faire un copier coller...
****Indek's Therm-A-Pipe heat pipe is an ideal heat
          transfer medium for high density micro devices such as notebook computers,or where space is a problem.
Therm-A-Pipe absorbs heat generated by components such as CPUs deep
          inside the enclosed chassis, then transfers the heat to a convenient
          location for discharge. With no power-consuming mechanical parts, heat
          pipe is a silent, light weight, space-saving, and maintenance-free solution.
Therm-A-Pipe is constructed of nickle plated compact copper. Every
          heat pipe contains a small amount of a purified water under vacuum conditions,
          and has a wick structure inside to provide the best thermal conduction,
          quickest thermal response and uniformed thermal distribution.
Therm-A-Pipe can be formed into a variety of shapes and sizes to meet
          specific heat dissipation requirements, and to fit end users' applications.
          Practical application of Therm-A-Pipe in micro devices often requires
          integration with conventional cooling technology such as cooling fans
          and heat sinks.
le site :http://www.indek.com/
