C++ Builder répertoire problème !!
C++ Builder répertoire problème !! - C++ - Programmation
Marsh Posté le 13-05-2012 à 21:23:25
Bonjour à tous ,
j'ai une question concernant c++ builder, i made a program which plays mp3 and wav files but in FileName propriety i have to type the full path is there any function or a modification which allows me to play songs from the Exe (project) Directory the same as Delphi which uses ('\\YourSong.mp3');
thanks.
Marsh Posté le 14-05-2012 à 14:37:03
U mean you have kind of an openfiledialog and you want it to open at your exe location?
You just have to initialize your dialog with your exe path!
Seul Google le sait...
Marsh Posté le 14-05-2012 à 21:12:21
no its not like that okay let me explain better:
http://i49.tinypic.com/34r8xh0.jpg
u see those buttons i made, i wanna make them play sounds when user clicks them, so i created a MediaPlayer(visible=false) and the problem Was in MediaPlayer->FileName  it doesn't support \\Sounds\Music.mp3 (Sounds Folder contains music and sounds) which is included with the project.exe Because when i finish this program I'll use Install-shield to Copy Folders (music ..) with The Exe program to C:\Programs\MyProgram......(for Example) and create a shortcut in desktop.
So is there are any way to do that !
thanks.
Marsh Posté le 14-05-2012 à 22:05:21
something like
MediaPlayer->FileName ="Sound\\music.mp3";
or
MediaPlayer->FileName =".\\sound\\music.mp3";
but that suppose the current working directory si the exe directory...
Marsh Posté le 14-05-2012 à 22:46:23
tried it but it doesn't work Error bla bla bla...
