from c function func(double (*g(char*))) to cpp cool object design
from c function func(double (*g(char*))) to cpp cool object design - C++ - Programmation
Marsh Posté le 03-09-2008 à 09:43:29
I want to convert a c function
void func(double (*g(char*))) ;
to a cpp object where we could specifie the function pointer per object instance.
I try functor ,member function pointer but the only paramater this function like to have is a static member function:(
Can someone help me deal with this problem?
Marsh Posté le 03-09-2008 à 11:02:16
   I think that boost::function can help you.
Marsh Posté le 03-09-2008 à 11:39:02
a member function is different from a function.
For a given object A, the type of int A::f(int) is in fact :
int (A::*)(int);
or int (*)(A*,int);
use boost::function as stated.
Marsh Posté le 03-09-2008 à 11:42:19
I would like not to add external dependencies to my project...There's no other solution:/?
It seems to be a quite complex to solve the problem no?
Marsh Posté le 03-09-2008 à 12:10:50
well, the dichotomy between function function member IS a hard problem. Boost solves it properly in allc ases of compiler/platform/type of function.
By dependencies, you mean at runtime ? If so, don't fear, boost is mostly headers only. If you want to minimize the boost packages needed for compilation , look at boost::BCP
Marsh Posté le 03-09-2008 à 13:39:40
Ok, I've test a few things, but my c function don't want a boost::function as argument, it's incompatible. So can you explain moreover what you think?
Marsh Posté le 03-09-2008 à 15:41:37
I was thinking the other way around.
You can't pass a C++ object to a C function anyway.
Best shot is making a class with a static method which encapsulates the actual method member into a boost::function.
Marsh Posté le 04-09-2008 à 11:26:45
class CPP{
   static void CPPFunc(function1<double,char*> f){
           double (*fprim)(char*)=f;
           cfunc(fprim);
no I dont understand...:((
Marsh Posté le 04-09-2008 à 14:32:15
or
class CPP{
private:
function2<double,CPP*,char*>* g;
public:
static double gcall(char*c){
return g(c);
virtual double gimpl(char*){blabla}
void exec(){
     g=new function2<double,CPP*,char*>(bind(CPP::gimpl,this,_1));
     cfunc(gcall);
Is it more like you're thinking?
No there's always a problem...arg
Message édité par mp3butcher le 04-09-2008 à 14:41:36
Marsh Posté le 04-09-2008 à 19:58:26
WTF
Marsh Posté le 05-09-2008 à 10:10:00
Excuse me I don't know what to do with function<> for my problem...:(
