Probleme OPENGL , affichage des couleurs en non transparence
Probleme OPENGL , affichage des couleurs en non transparence - C++ - Programmation
Marsh Posté le 09-07-2002 à 17:14:00
voila mon pobleme , je me suis crévé le cul à dessiner 3 axes (x,y,z) en polygone afin d'attibuer une couleur à chacun .le probleme est que la couleur rouge de l'axe x prédomine sur les autre et l'on est vite perdu .
aidez moi svp
 //axe y
 //arriere
  glBegin(GL_POLYGON);
   glNormal3d(0.0,0.0,1.0);
   glColor3ub(0,0,255);
    glVertex3d( -petite_distance, petite_distance ,longue_distance  );
    glVertex3d( 0 ,petite_distance , longue_distance );
    glVertex3d(0, 0 , longue_distance );
    glVertex3d(-petite_distance , 0 , longue_distance);
  glEnd();
 //avant
   glNormal3d(0.0,0.0,-1.0);
    glVertex3d( -petite_distance ,petite_distance  ,petite_distance );
    glVertex3d( 0 , petite_distance , petite_distance );
    glVertex3d(0 , 0 , petite_distance );
    glVertex3d(-petite_distance, 0  , petite_distance );
  glEnd();
 //dessus
   glNormal3d(0.0,1.0,0.0);
  glEnd();
 //dessous
   glNormal3d(0.0,-1.0,0.0);
    glVertex3d( -petite_distance , 0 , longue_distance );
    glVertex3d( 0 , 0 , longue_distance );
    glVertex3d( 0 , 0 ,  petite_distance);
    glVertex3d( -petite_distance , 0, petite_distance );
  glEnd();
 //gauche
   glNormal3d(-1.0,0.0,0.0);
    glVertex3d(-petite_distance,petite_distance,petite_distance);
    glVertex3d(-petite_distance,petite_distance,longue_distance);
    glVertex3d( -petite_distance,0,longue_distance);
    glVertex3d(-petite_distance,0,petite_distance);
  glEnd();
 //droite
   glNormal3d(1.0,0.0,0.0);
    glVertex3d( 0,0,petite_distance );
    glVertex3d(0,0,longue_distance);
    glVertex3d( 0,petite_distance,longue_distance);
    glVertex3d(0,petite_distance,petite_distance);
  glEnd();
 //Axe Z
 //arriere
   glVertex3d(-petite_distance,longue_distance,petite_distance);
   glColor3ub(0,255,0);
   glVertex3d( 0,longue_distance,petite_distance);
   glVertex3d(0,0,petite_distance);
  glEnd();
 //avant
   glVertex3d(-petite_distance,longue_distance,0);
   glVertex3d(0,longue_distance,0);
   glVertex3d(0,0,0);
   glVertex3d(-petite_distance,0,0);
  glEnd();
 //dessus
   glVertex3d(0,longue_distance,petite_distance);
   glVertex3d( -petite_distance,longue_distance,0);
  glEnd();
 //dessous
   glVertex3d( 0,0,petite_distance);
   glVertex3d(0,0,0);
   glVertex3d( -petite_distance,0,0);
  glEnd();
 //gauche
   glVertex3d( -petite_distance,longue_distance,petite_distance);
  glEnd();
 //droite
   glVertex3d(0,0,0);
  glEnd();
 //Axe -X
 //arriere
   glVertex3d(-longue_distance,petite_distance,petite_distance);
   glColor3ub(255,0,0);
   glVertex3d( -petite_distance,petite_distance,petite_distance);
   glVertex3d(-longue_distance,0,petite_distance);
  glEnd();
 //avant
/*   glBegin(GL_POLYGON);
   glVertex3d(0,0,0);
  glEnd();*/
 //dessus
   glVertex3d(-longue_distance,petite_distance,0);
   glVertex3d(-petite_distance,petite_distance,0);
   glVertex3d( -longue_distance,0,0);
  glEnd();
 //dessous
   glVertex3d( -petite_distance,0,petite_distance);
  glEnd();
 //gauche
   glVertex3d( -longue_distance,petite_distance,petite_distance);
   glVertex3d(-longue_distance,0,0);
  glEnd();
 //droite
   glVertex3d(0,0,0);
  glEnd();*/
Marsh Posté le 09-07-2002 à 18:02:09
As-tu pensé a activer le test du Z-Buffer ??
glEnable( GL_DEPTH_TEST );
rendu des axes...
