Mais il m'affiche a la compilation ceci dans le build log et je n'y comprends RIEN ...
Spoiler :
Project : GTK+ application Compiler : GNU GCC Compiler (called directly) Directory : C:\Documents and Settings\Lecusto\Bureau\gtk\ -------------------------------------------------------------------------------- Switching to target: default Compiling: main.c Usage: mingw32-gcc.exe [options] file... mingw32-gcc.exe: ./configure: No such file or directory Options: -pass-exit-codes Exit with highest error code from a phase --help Display this information --target-help Display target specific command line options (Use '-v --help' to display command line options of sub-processes) -dumpspecs Display all of the built in spec strings -dumpversion Display the version of the compiler -dumpmachine Display the compiler's target processor -print-search-dirs Display the directories in the compiler's search path -print-libgcc-file-name Display the name of the compiler's companion library -print-file-name=<lib> Display the full path to library <lib> -print-prog-name=<prog> Display the full path to compiler component <prog> -print-multi-directory Display the root directory for versions of libgcc -print-multi-lib Display the mapping between command line options and multiple library search directories -print-multi-os-directory Display the relative path to OS libraries -Wa,<options> Pass comma-separated <options> on to the assembler -Wp,<options> Pass comma-separated <options> on to the preprocessor -Wl,<options> Pass comma-separated <options> on to the linker -Xassembler <arg> Pass <arg> on to the assembler -Xpreprocessor <arg> Pass <arg> on to the preprocessor -Xlinker <arg> Pass <arg> on to the linker -save-temps Do not delete intermediate files -pipe Use pipes rather than intermediate files -time Time the execution of each subprocess -specs=<file> Override built-in specs with the contents of <file> -std=<standard> Assume that the input sources are for <standard> -B <directory> Add <directory> to the compiler's search paths -b <machine> Run gcc for target <machine>, if installed -V <version> Run gcc version number <version>, if installed -v Display the programs invoked by the compiler -### Like -v but options quoted and commands not executed -E Preprocess only; do not compile, assemble or link -S Compile only; do not assemble or link -c Compile and assemble, but do not link -o <file> Place the output into <file> -x <language> Specify the language of the following input files Permissible languages include: c c++ assembler none 'none' means revert to the default behavior of guessing the language based on the file's extension Options starting with -g, -f, -m, -O, -W, or --param are automatically passed on to the various sub-processes invoked by mingw32-gcc.exe. In order to pass other options on to these processes the -W<letter> options must be used. For bug reporting instructions, please see: <URL:http://www.mingw.org/bugs.shtml>. Linking executable: C:\Documents and Settings\Lecusto\Bureau\gtk\GTKapp.exe mingw32-g++.exe: .objs\main.o: No such file or directory
Message édité par Lecusto le 15-07-2006 à 11:21:39
Marsh Posté le 14-07-2006 à 14:28:35
Ayant lu quelques tutoriaux c et c++ j'ai voulu essayer la librairie gtk+ mais deja a l'installation c'est pas rose
J'ai donc suivi les conseils de ce site : http://blog.developpez.com/index.p [...] &tb=1&pb=1
Compiling: main.c
Options:
