création composant [vb.net] - C#/.NET managed - Programmation
MarshPosté le 18-03-2005 à 14:23:12
Bonjours,
j'ai créer dans un userform, un label deplaçable et redimensionnable en hauteur : je voudrais pouvoir créer simplement autant d'element de ce type que je veux. Comment faire ? je crois qu'il faut que je crée un controle mais je n'y arrive pas : pouvez-vous m'aidez ?
voici le code complet de mon userfrom :
Code: Imports System Imports System.Drawing Imports System.Windows.Forms
Namespace zone1
Public Class MainForm Inherits System.Windows.Forms.Form Private labelmilieu As System.Windows.Forms.Label Private labelhaut As System.Windows.Forms.Label Private labelbas As System.Windows.Forms.Label
Public Shared Sub Main Dim fMainForm As New MainForm fMainForm.ShowDialog() End Sub
Public Sub New() MyBase.New ' ' The Me.InitializeComponent call is required for Windows Forms designer support. ' Me.InitializeComponent ' ' TODO : Add constructor code after InitializeComponents ' End Sub
#Region " Windows Forms Designer generated code " ' This method is required for Windows Forms designer support. ' Do not change the method contents inside the source code editor. The Forms designer might ' not be able to load this method if it was changed manually. Private Sub InitializeComponent() Me.labelbas = New System.Windows.Forms.Label Me.labelhaut = New System.Windows.Forms.Label Me.labelmilieu = New System.Windows.Forms.Label Me.SuspendLayout ' 'labelbas ' Me.labelbas.BackColor = System.Drawing.Color.Gray Me.labelbas.Location = New System.Drawing.Point(160, 216) Me.labelbas.Name = "labelbas" Me.labelbas.Size = New System.Drawing.Size(128, 8) Me.labelbas.TabIndex = 1 Me.labelbas.Text = "label2" AddHandler Me.labelbas.MouseUp, AddressOf Me.LabelbasMouseUp AddHandler Me.labelbas.MouseMove, AddressOf Me.LabelbasMouseMove AddHandler Me.labelbas.MouseDown, AddressOf Me.LabelbasMouseDown ' 'labelhaut ' Me.labelhaut.BackColor = System.Drawing.Color.IndianRed Me.labelhaut.Location = New System.Drawing.Point(160, 120) Me.labelhaut.Name = "labelhaut" Me.labelhaut.Size = New System.Drawing.Size(128, 8) Me.labelhaut.TabIndex = 2 Me.labelhaut.Text = "label3" AddHandler Me.labelhaut.MouseMove, AddressOf Me.LabelhautMouseMove AddHandler Me.labelhaut.MouseDown, AddressOf Me.LabelhautMouseDown ' 'labelmilieu ' Me.labelmilieu.BackColor = System.Drawing.SystemColors.ActiveCaption Me.labelmilieu.Location = New System.Drawing.Point(160, 128) Me.labelmilieu.Name = "labelmilieu" Me.labelmilieu.Size = New System.Drawing.Size(128, 88) Me.labelmilieu.TabIndex = 0 Me.labelmilieu.Text = "label1" AddHandler Me.labelmilieu.MouseUp, AddressOf Me.LabelmilieuMouseUp AddHandler Me.labelmilieu.MouseMove, AddressOf Me.LabelmilieuMouseMove AddHandler Me.labelmilieu.MouseDown, AddressOf Me.LabelmilieuMouseDown ' 'MainForm ' Me.AutoScaleBaseSize = New System.Drawing.Size(5, 13) Me.ClientSize = New System.Drawing.Size(608, 398) Me.Controls.Add(Me.labelhaut) Me.Controls.Add(Me.labelbas) Me.Controls.Add(Me.labelmilieu) Me.Name = "MainForm" Me.Text = "MainForm" AddHandler Load, AddressOf Me.MainFormLoad Me.ResumeLayout(false) End Sub #End Region
Private Xp, Yp As Integer
Private Sub LabelMilieuMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) Xp = e.x Yp = e.y End Sub
Private Sub LabelHautMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) Xp = e.x Yp = e.y End Sub
Private Sub LabelBasMouseDown(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) Xp = e.x Yp = e.y End Sub
Private Sub LabelMilieuMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) 'deplace le label
Dim LabelTop, LabelLeft as integer 'MessageBox.Show("Bonjour" )
If e.Button = MouseButtons.Left Then LabelTop = LabelMilieu.Top - Yp + e.y LabelLeft = LabelMilieu.Left - Xp + e.x
Me.LabelBas.Top = LabelTop + LabelMilieu.Height Me.LabelBas.Left = LabelLeft end if End Sub
Private Sub LabelHautMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) 'redimensionne le label
Dim AgrandissementY as Integer Dim NewHeight As Integer
If e.Button = MouseButtons.Left Then AgrandissementY = - Yp + e.y NewHeight = Me.LabelMilieu.Height - AgrandissementY
if NewHeight < 16 then 'empeche que le label soit inférieur à 16px Me.LabelMilieu.Top = Me.LabelBas.Top - 16 Me.LabelMilieu.Height = 16 Me.LabelHaut.Top = Me.LabelMilieu.Top - 8 Else Me.LabelHaut.Top = Me.LabelHaut.Top + AgrandissementY Me.LabelMilieu.Top = Me.LabelMilieu.Top + AgrandissementY Me.LabelMilieu.Height = NewHeight end if End if End Sub
Private Sub LabelBasMouseMove(sender As System.Object, e As System.Windows.Forms.MouseEventArgs) 'redimensionne le label
If e.Button = MouseButtons.Left Then AgrandissementY = - Yp + e.y NewHeight = Me.LabelMilieu.Height + AgrandissementY
if NewHeight < 16 then 'empeche que le label soit inférieur à 16px Me.LabelBas.Top = Me.LabelMilieu.Top + 16 Me.LabelMilieu.Height = 16 Else Me.LabelBas.Top = Me.LabelBas.Top + AgrandissementY Me.LabelMilieu.Height = NewHeight End if End if End Sub
Private Sub LabelmilieuMouseUp(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
End Sub
Private Sub LabelbasMouseUp(sender As System.Object, e As System.Windows.Forms.MouseEventArgs)
End Sub
Private Sub MainFormLoad(sender As System.Object, e As System.EventArgs)
SetStyle(ControlStyles.DoubleBuffer Or ControlStyles.UserPaint Or ControlStyles.AllPaintingInWmPaint , True) SetStyle(ControlStyles.ResizeRedraw, True) 'le controle est redissiné lors de son redimensionnement SetStyle(ControlStyles.SupportsTransparentBackColor, True) 'gère les couleurs transparentes
End Sub
Private Sub AlphaBlendTextBox1TextChanged(sender As System.Object, e As System.EventArgs)
Marsh Posté le 18-03-2005 à 14:23:12
Bonjours,
Code:
Imports System
Namespace zone1
End Sub
Public Sub New()
MyBase.New
End Sub
Me.SuspendLayout
'labelbas
'labelhaut
'labelmilieu
'MainForm
End Sub
#End Region
Xp = e.x
Yp = e.y
End Sub
Xp = e.x
Yp = e.y
End Sub
Xp = e.x
Yp = e.y
End Sub
'deplace le label
Me.LabelMilieu.Top = LabelTop
Me.LabelMilieu.Left = LabelLeft
Me.LabelHaut.Top = LabelTop - 8
Me.LabelHaut.Left = LabelLeft
end if
End Sub
Else
end if
End if
End Sub
Else
End if
End if
End Sub
End Sub
End Sub
End Sub
End Sub
End Class
End Namespace
