déployer asp.net problème d'hébergement
déployer asp.net problème d'hébergement - C#/.NET managed - Programmation
Marsh Posté le 14-08-2015 à 10:11:13
Hi All,
My apologize if I write in English because I just migrated to France and my French is not so good. I just keep learning. :) :)
I have hosted my asp.net site with hostforlife.eu windows hosting. I am getting error 500 internal server error
In the web.config file I have included
<system.webServer>
<httpErrors errorMode="Detailed" />
<asp scriptErrorSentToBrowser="true"/>
</system.webServer>
<system.web>
<customErrors mode="Off"/>
<compilation debug="true"/>
</system.web>
this is my web.config file<connectionStrings>
<add name="conn" connectionString=" Server=xxx.db.xxxx.hostedresource.com; Database=xxx; User ID=xxx; Password=xxx; Trusted_Connection=False" providerName="System.Data.SqlClient" /> <remove name="LocalSqlServer"/> <add name="LocalSqlServer" connectionString=" Server=xxx.db.xxxx.hostedresource.com; Database=xxx; User ID=xxx; Password=xxx; Trusted_Connection=False" providerName="System.Data.SqlClient" />
    </connectionStrings>
    <configuration>
    <system.webServer>
    </system.webServer>
    <system.web>
    </system.web>
    </configuration>
This is my code behind
using System;
    using System.Data;
    using System.Configuration;
    using System.Collections;
    using System.Web;
    using System.Web.Security;
    using System.Web.UI;
    using System.Web.UI.WebControls;
    using System.Web.UI.WebControls.WebParts;
    using System.Web.UI.HtmlControls;
    using System.Data.SqlClient;
    public partial class _Default : System.Web.UI.Page
        protected void Page_Load(object sender, EventArgs e)
        protected void Button1_Click(object sender, EventArgs e)
            string aa = ConfigurationManager.ConnectionStrings["conn"].ConnectionString;
            SqlConnection con = new SqlConnection(aa);
            con.Open();
            string name = TextBox1.Text;
            string pwd = TextBox2.Text;
            string str = "insert into login values('" + name + "', '" + pwd + "', '" + pwd + "', '" + pwd + "')";
            SqlCommand cmd = new SqlCommand(str, con);
            cmd .ExecuteNonQuery ();
Could you please kindly point what is the issue? Any suggesstion?
Thank you
