voila, mon prob avec maven c est que les tests ne passent pas "error" voila sa reponse: test:test: [junit] dir attribute ignored if running in the same VM [junit] Running java.com.lectra.common.i18n.I18nKeyTest [junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 0 sec [junit] [ERROR] TEST java.com.lectra.common.i18n.I18nKeyTest FAILED [junit] dir attribute ignored if running in the same VM [junit] Running java.com.lectra.common.i18n.I18nMessagesTest [junit] Tests run: 1, Failures: 0, Errors: 1, Time elapsed: 0 sec [junit] [ERROR] TEST java.com.lectra.common.i18n.I18nMessagesTest FAILED
BUILD FAILED File...... fileCDocuments and Settings/a.doukkali/.maven/plugins/maven-test-plugin-1.4/ Element... fail Line...... 130 Column.... 54 There were test failures. Total time: 4 seconds Finished at: Wed Mar 03 13:59:31 CET 2004
c est qq'un a la reponse j'en serais tes reconnaissant merci
Marsh Posté le 03-03-2004 à 14:40:04
C
test:test:
BUILD FAILED
File...... file
Element... fail
Line...... 130
Column.... 54
