[php-gtk]problemes a l'installation
problemes a l'installation [php-gtk] - Divers - Programmation
Marsh Posté le 31-07-2003 à 11:44:03
y'en a qui l'utilisent et qui ont réussi à l'installer sans problèmes ?
checking for PHP executable in /usr/bin... found
./configure: line 3397: syntax error near unexpected token `debug,'
./configure: line 3397: `PHP_GTK_ARG_ENABLE(debug, whether to include debugging symbols,'
bon en commentant ces lignes,
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking whether -lc should be explicitly linked in... no
creating libtool
mkdir: too few arguments
Try `mkdir --help' for more information.
configure: creating ./config.status
config.status: creating config.h
config.status: config.h is unchanged
bash-2.05b# make
Build complete.
(It is safe to ignore warnings about tempnam and tmpnam).
bash-2.05b#
bref, c'est pas super.
Y'en a qui l'ont installé sans problèmes ?
