(XML/XSL également) Manipulation DOM2 en DHTML
Manipulation DOM2 en DHTML (XML/XSL également) - HTML/CSS - Programmation
Marsh Posté le 25-11-2003 à 13:20:23
Bonjour j'ai un tableau qui ressemble a ca:
<table id="style2" width="100%" cellpadding="0" cellspacing="0">
  <tr class="InterfaceHeader" id="example45">
   <TD ><font class="InterfaceHeader_SubText" >Selection</font></TD>
    <TD ><font class="InterfaceHeader_SubText" >Name</font></TD>
    <TD><font class="InterfaceHeader_SubText" >Company</font></TD>
    <TD><font class="InterfaceHeader_SubText" >Mail</font></TD>
    <TD><font class="InterfaceHeader_SubText">Report format</font></TD>
  </tr>
  <tr id="TR0" class="InterfaceHeader2">
  <td><input type=checkbox id="Check0" IndexVal="TR0"></td>
  <td>Jean Clusote</td>
  <td>Alicanos</td>
  <td>Jean.Clusote@Alicanos.net</td>
  <td>IATA chapter 7</td>
  </tr>
  <tr id="example4" class="InterfaceHeader2">
  </tr>
</table>
j'aimerais editer et rajouter des lignes pour ajouter je fais ca:
 function insertTD(){
 var myObject=null;
 VarArray=window.showModalDialog ('ReportForm.html',myObject,"dialogWidth:450px;dialogHeight:270px;status: no;unadorned: yes;help: no;scroll:no" );
 if (VarArray!=null){
 var newTR = document.createElement("tr" );
 newTR.setAttribute("id",("TR"+TRcount));
 //alert(newTR.getAttribute("id" ))
 if (parity == true){
 newTR.style.backgroundColor="#F2ECDE";
 parity=false;
 }else{
 parity=true;
 //Create the check box
 var newTDSelection = document.createElement("td" );
 var newInputSel = document.createElement("input" );
 newInputSel.setAttribute("id",("Check"+TRcount));
 newInputSel.setAttribute("type","checkbox" );
 newInputSel.setAttribute("IndexVal",newTR.getAttribute("id" ));
 newTDSelection.appendChild(newInputSel);
 var newTDName = document.createElement("td" );
 var newTDCompany = document.createElement("td" );
 var newTDMail = document.createElement("td" );
 var newTDReport = document.createElement("td" );
 var newTextName = document.createTextNode(VarArray.Name);
 var newTextCompany = document.createTextNode(VarArray.Company);
 var newTextMail = document.createTextNode(VarArray.Email);
 var newTextReport = document.createTextNode(VarArray.Report);
 //newTDSelection.appendChild(newTextSel);
 newTDName.appendChild(newTextName);
 newTDCompany.appendChild(newTextCompany);
 newTDMail.appendChild(newTextMail);
 newTDReport.appendChild(newTextReport);
 newTR.appendChild(newTDSelection);
 newTR.appendChild(newTDName);
 newTR.appendChild(newTDCompany);
 newTR.appendChild(newTDMail);
 newTR.appendChild(newTDReport);
 TRcount++;
 var TbElm = document.getElementById("example4" );
 TbElm.insertBefore(newTR,null);
au fait mon probleme se situe au niveau de l'edition:
je voudrais a l'aide d'une CheckBox editer un message checke:
pour cela j'ai une boucle qui test si l'element est checke
Ma question est simple:
Comment recuperer le parent a savoir la ligne (TR0 ici par exemple) e t recuperer ensuite la valeur de ces fils (ici les TD):
j'ai essayer des truc comme ca mais ca marche pas trop:
 function EditTR(){
 var i=0;
 while(document.getElementById("Check"+i)!=null){
 var element=document.getElementById("Check"+i);
 if (element.checked==true){
 var myMom=element.parentElement;
 var myLine=document.getElementById(element.IndexVal);
 var myParent=myLine.parentElement;
 alert(myLine.id);
 alert(myParent.id);
 alert(myMom.id);
 alert("Check"+i);
 alert(document.getElementsByTagName("TR" ).nodeValue);
 alert(myLine.length)
 alert(myLine.childNodes[3].nodeValue);
 var aReturn=myLine;//.parentElement.getElementsByTagName
 alert(aReturn[0].childNodes[0].nodeValue);
 alert(aReturn[aReturn.length-1].childNodes[0].nodeValue);
 alert(aReturn.length);
 i++;
Message édité par PETOZAK le 25-11-2003 à 16:12:48
Marsh Posté le 25-11-2003 à 19:13:34
Attention, pas de _ dans les noms de classes
Il sort d'où cet attribut IndexVal ?? En tout cas il n'existe pas dans les specs du HTML...
Et pourquoi pas :
myParent = element.parentElement.parentElement; :??:
De toute façon ta boucle me paraît superflue. Pourquoi tu n'ajoutes pas un évènement onchange sur ton <input> ? Comme ça tu pourrais récupérer directement le input, et donc la ligne, dans ta fonction.
Incongru : une FAQ abandonnée sur les Standards du Web - FAQ périmée de blabla@Prog
Marsh Posté le 26-11-2003 à 09:47:51
tu as l'air sympas mais tu ne m'aides pas ;)
tu peux placer les attributs que tu veux en HTML du moment qu'ils ne sont pas en conflit avec les habituels
Et pourquoi pas :
parce que j'ai besoin des 2 apres myParent et myLine.
Je veux pouvoir en editer plusieurs a la fois
Marsh Posté le 26-11-2003 à 09:49:08
ma questiion est simple recuperer la valeur des colonnes?
<TD>je veux le texte qui est ici</TD>
Marsh Posté le 26-11-2003 à 09:54:06
Et la marmotte...
Marsh Posté le 26-11-2003 à 10:33:42
c'est pas plus simple d'écrire
   <TD class="InterfaceHeader_SubText" >Selection</TD>
? :o
mes programmes ·· les voitures dans les films ·· apprenez à écrire
Marsh Posté le 26-11-2003 à 11:42:34
Au fait la bonne reponse est:
innerHTML
c'est tout bete
