Script php dans une page php, problem apre le script - HTML/CSS - Programmation
Marsh Posté le 07-11-2002 à 03:01:55
Mon code:
<HTML>
<HEAD>
<TITLE>V A N I L A</TITLE>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
<script language="JavaScript">
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#" )!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.0
var p,i,x; if(!d) d=document; if((p=n.indexOf("?" ))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && document.getElementById) x=document.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</HEAD>
<style type="text/css">
body { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: xx-small}
table { font-family: Verdana, Arial, Helvetica, sans-serif; font-size: x-small}
</style>
<BODY BGCOLOR=#FFFFFF onLoad="MM_preloadImages('../images/test_15_over.jpg','../images/test_17_over.jpg'">
<div align="center">
<TABLE WIDTH=781 BORDER=0 CELLPADDING=0 CELLSPACING=0>
<TR>
<TD>
<IMG SRC="../images/test_01.jpg" WIDTH=15 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_02.jpg" WIDTH=12 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_03.jpg" WIDTH=444 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_04.jpg" WIDTH=12 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_05.jpg" WIDTH=35 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_06.jpg" WIDTH=95 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_07.jpg" WIDTH=34 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_08.jpg" WIDTH=102 HEIGHT=169></TD>
<TD>
<IMG SRC="../images/test_09.jpg" WIDTH=32 HEIGHT=169></TD>
</TR>
<TR>
<TD>
<IMG SRC="../images/test_10.jpg" WIDTH=15 HEIGHT=34></TD>
<TD>
<IMG SRC="../images/test_11.jpg" WIDTH=12 HEIGHT=34></TD>
<TD>
<IMG SRC="../images/test_12.jpg" WIDTH=444 HEIGHT=34></TD>
<TD>
<IMG SRC="../images/test_13.jpg" WIDTH=12 HEIGHT=34></TD>
<TD>
<IMG SRC="../images/test_14.jpg" WIDTH=35 HEIGHT=34></TD>
<TD><a href="../intro.htm" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('INTRO','','../images/test_15_over.jpg',1)"><img name="INTRO" border="0" src="../images/test_15.jpg" width="95" height="34" align="middle"></a></TD>
<TD>
<IMG SRC="../images/test_16.jpg" WIDTH=34 HEIGHT=34></TD>
<TD><a href="../photos.htm" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('PHOTOS','','../images/test_17_over.jpg',1)"><img name="PHOTOS" border="0" src="../images/test_17_on.jpg" width="102" height="34" align="middle"></a></TD>
<TD>
<IMG SRC="../images/test_18.jpg" WIDTH=32 HEIGHT=34></TD>
</TR>
<TR>
<TD>
<IMG SRC="../images/test_19.jpg" WIDTH=15 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_20.jpg" WIDTH=12 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_21.jpg" WIDTH=444 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_22.jpg" WIDTH=12 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_23.jpg" WIDTH=35 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_24.jpg" WIDTH=95 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_25.jpg" WIDTH=34 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_26.jpg" WIDTH=102 HEIGHT=24></TD>
<TD>
<IMG SRC="../images/test_27.jpg" WIDTH=32 HEIGHT=24></TD>
</TR>
<TR>
<TD>
<IMG SRC="../images/test_28.jpg" WIDTH=15 HEIGHT=18></TD>
<TD>
<IMG SRC="../images/test_29.jpg" WIDTH=12 HEIGHT=18></TD>
<TD>
<IMG SRC="../images/test_30.jpg" WIDTH=444 HEIGHT=18></TD>
<TD>
<IMG SRC="../images/test_31.jpg" WIDTH=12 HEIGHT=18></TD>
<TD colspan="4" background="../images/test34-36.jpg"></TD>
<TD>
<IMG SRC="../images/test_36.jpg" WIDTH=32 HEIGHT=18></TD>
</TR>
<TR>
<TD>
<IMG SRC="../images/test_37.jpg" WIDTH=15 HEIGHT=330></TD>
<TD background="../images/test_38.jpg"> </TD>
<TD valign="middle">
[#b84600]<?php
require ("_admin/conf.php" );
// ouverture du dossier contenant les fichiers --> nbphotos
function nb_ph($fdirectory){
$handle=opendir($fdirectory);
$nb_photos = 0;
while ($file = readdir($handle)) {
if ($file != "." && $file != ".." && $file != "_commentaire.txt" && $file != "thumbs" && $file != "_com_img.txt" ) {
// $file contient le nom d'un fichier
$nb_photos = $nb_photos + 1;
closedir($handle);
return ($nb_photos);
// fin ouverture du dossier contenant les fichiers --> nbphotos
// NAME
function no_ext($t_file){
$pt = strrpos($t_file, "." );
$s_file = substr($t_file, 0, $pt);
return $s_file;
// FIN NAME
// THUMBS NAME
function t_name($file){
$pt = strrpos($file, "." );
$s_file = substr($file, 0, $pt);
$file_ext = substr($file, $pt + 1, strlen($file) - $pt - 1);
$file_ext = strtolower($file_ext);
$s_file = $s_file . "_m." . $file_ext;
return $s_file;
// FIN THUMBS NAME
// NB COMMENTAIRES
function get_nb_com($dir, $img){
$file = $dir . "/_com_img.txt";
if (!$op_file = @fopen($file,"r" )){
$nb_com = 0; // Problème ouverure fichier de commentaire
} else {
$nb_com = 0;
while (!feof($op_file)){
$line = fgets($op_file, 4096);
$arr_data = explode("/", $line);
// 0:nom image
if ($arr_data[0] == $img){
$nb_com++;
fclose($op_file);
return($nb_com);
// END NB COMMENTAIRES
// Construction du tableau html
function constr_tab($fnb_photos, $fint_nb_pages, $fint_no_page, $fhnamep, $fnb_lim, $ffirst, $fall_nb_photos, $fdirectory, $jnb_phpage){
if ($fint_no_page < $fint_nb_pages){
$fnb_photos = $fnb_lim ;
else{
$fnb_photos = $fnb_photos - ($fnb_lim * ($fint_no_page - 1));
$cpt_init = ($fint_no_page - 1) * $fnb_lim + 1;
include ("head.php" );
echo "$head_jbrowser";
if ($fnb_photos == 0){
echo "<center><font face=\"Verdana, Arial, Helvetica\" size=\"2\">Dossier vide<br><br><a href=\"photos.php\">Retour</a></font></center>";
include("foot.php" );
die;
else {
echo "<table border=\"0\" width=\"$table_width\" cellspacing=\"1\" cellpadding=\"1\" align=\"center\" bgcolor=\"$bodybgcolor\">";
echo "<tr><td colspan=\"$jnb_phpage\" align=\"center\" bgcolor=\"$bgcolor_titre\"><font size=\"$titre_size\" color=\"$titre_color\" face=\"$titre_face\"><b><u>$st_texte</u></b></font></td></tr>";
$reste = $fnb_photos % $jnb_phpage;
$juste = $fnb_photos - $reste;
$quotient = $juste / $jnb_phpage;
echo "<tr><td colspan=\"1\"><font size=\"1\" face=\"$titre_face\">";
echo "Page : $fint_no_page/$fint_nb_pages </font></td>";
$photo_start = 1 + ($fint_no_page - 1) * $fnb_lim;
$photo_end = $photo_start + $fnb_photos - 1;
$cjnb_phpage = $jnb_phpage-1;
echo "<td colspan=\"$cjnb_phpage\" align=\"right\"><font size=\"1\" face=\"$titre_face\">";
echo "Photos : $photo_start à $photo_end / $fall_nb_photos</font></td></tr>";
if ($quotient == 0){ // moins de cinq
$cpt_empty = 0;
for ($i = $cpt_init; $i <= ($reste + $cpt_init - 1); $i++){
$filetoopen = "$fdirectory/" . $fhnamep[$i];
$size_ph = getimagesize($filetoopen); // taille de l image
$wnd_w = $size_ph[0] + 60;
$wnd_h = $size_ph[1] + 60;
if ($c_aff == 0){
$ts_name = no_ext($fhnamep[$i]);
} else {
$ts_name = $size_ph[0] . "x" . $size_ph[1];
$th_name = t_name($fhnamep[$i]);
$th_name = $fdirectory . "/thumbs/" . $th_name;
$th_size = getimagesize($th_name);
echo"<td bgcolor=\"$tabbgcolor\" width=\"10%\" align=\"center\"><a href=\"#\" onClick=\"MM_openBrWindow('window.php?img_name=$fdirectory/$fhnamep[$i]&img_w=$size_ph[0]&img_h=$size_ph[1]','photo','scrollbars=yes,resizable=yes,width=$wnd_w,height=$wnd_h'\"><img src=\"$th_name\" align=\"center\" border=\"0\" $th_size[3] alt=\"$fhnamep[$i]\"></a><br><font size=\"1\" face=\"Verdana, Arial, Helvetica\">$ts_name ";
if ($use_com == 1){
$nb_com = get_nb_com($fdirectory, $fhnamep[$i]);
if ($nb_com != 0)
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$i]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><br><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Voir ou ajouter des commentaire à l'image $fhnamep[$i]\" border=\"0\">$nb_com Commentaires</a>";
else
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$i]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><br><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Ecrire un commentaire sur $fhnamep[$i]\" border=\"0\">Commentaire</a>";
echo "</font></td>";
$cpt_empty++;
for ($ce=$cpt_empty ; $ce < $jnb_phpage ; $ce++){
echo"<td width=\"10%\"> </td>";
echo "</tr>";
}else{ // plus de cinq ou egale
for ($i = 1; $i <= $quotient; $i++){
echo "<tr>";
for ($j = 1; $j <= $jnb_phpage; $j++){
$k =($cpt_init - 1) + ($i - 1) * $jnb_phpage + $j;
$filetoopen = "$fdirectory/" . $fhnamep[$k];
if ($c_aff == 0){
$ts_name = no_ext($fhnamep[$k]);
} else {
$th_name = t_name($fhnamep[$k]);
echo"<td bgcolor=\"$tabbgcolor\" width=\"10%\" align=\"center\"><a href=\"#\" onClick=\"MM_openBrWindow('window.php?img_name=$fdirectory/$fhnamep[$k]&img_w=$size_ph[0]&img_h=$size_ph[1]','photo','scrollbars=yes,resizable=yes,width=$wnd_w,height=$wnd_h'\"><img src=\"$th_name\" align=\"center\" border=\"0\" $th_size[3] alt=\"$fhnamep[$k]\"></a><br><font size=\"1\" face=\"Verdana, Arial, Helvetica\">$ts_name ";
if ($use_com == 1){
$nb_com = get_nb_com($fdirectory, $fhnamep[$k]);
if ($nb_com != 0)
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$k]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><br><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Voir ou ajouter des commentaire à l'image $fhnamep[$k]\" border=\"0\">$nb_com Commentaires</a>";
else
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$k]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Ecrire un commentaire sur $fhnamep[$k]\" border=\"0\">Commentaire</a>";
echo "</tr>";
echo "<tr>";
for ($l = 1; $l <= $reste; $l++){
$m = $k + $l;
$filetoopen = "$fdirectory/" . $fhnamep[$m];
if ($c_aff == 0){
$ts_name = no_ext($fhnamep[$m]);
} else {
$th_name = t_name($fhnamep[$m]);
echo"<td bgcolor=\"$tabbgcolor\" width=\"10%\" bgcolor=\"$tabbgcolor\" align=\"center\"><a href=\"#\" onClick=\"MM_openBrWindow('window.php?img_name=$fdirectory/$fhnamep[$m]&img_w=$size_ph[0]&img_h=$size_ph[1]','photo','scrollbars=yes,resizable=yes,width=$wnd_w,height=$wnd_h'\"><img src=\"$th_name\" align=\"center\" border=\"0\" $th_size[3] alt=\"$fhnamep[$m]\"></a><br><font size=\"1\" face=\"Verdana, Arial, Helvetica\">$ts_name ";
if ($use_com == 1){
$nb_com = get_nb_com($fdirectory, $fhnamep[$m]);
if ($nb_com != 0)
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$m]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><br><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Voir ou ajouter des commentaire à l'image $fhnamep[$m]\" border=\"0\">$nb_com Commentaires</a>";
else
echo "<br><a href=\"#\" onClick=\"MM_openBrWindow('commentaire.php?img_dir=$fdirectory&img_name=$fhnamep[$m]','com','scrollbars=yes,resizable=yes,width=320,height=500'\"><img src=\"img_src/com.gif\" width=\"17\" height=\"16\" align=\"absmiddle\" alt=\"Ecrire un commentaire sur $fhnamep[$m]\" border=\"0\">Commentaire</a>";
if ($reste != 0){
for ($kl=$reste ; $kl < $jnb_phpage ; $kl++){
echo "</tr>";
echo "<tr><td width=\"10 %\" colspan=\"1\" align=\"left\"><font size=\"1\" face=\"$titre_face\"><a href=\"photos.php\">Menu</a> ";
// liens page
$other_cpt_l = 0;
$other_cpt_r = 0;
for ($cpt = 1 ; $cpt <= $fint_nb_pages ; $cpt++){
if ($cpt <= $fint_no_page + 3 && $cpt >= $fint_no_page - 3){
if ($fint_no_page != $cpt)
echo " | <a href=\"browser.php?first=$ffirst&int_nb_photos=$fnb_photos&int_nb_pages=$fint_nb_pages&int_no_page=$cpt&directory=$fdirectory\">$cpt</a>";
else
echo " | <b>$cpt</b>";
else{
if ($cpt < $fint_no_page && $other_cpt_l < 3){
$other_cpt_l++;
echo " .";
} else if ($cpt > $fint_no_page && $other_cpt_r < 3){
$other_cpt_r++;
echo " .";
// lien page
echo "</font></td><td colspan=\"$cjnb_phpage\" width=\"20 %\" align=\"center\"><font size=\"2\">";
// prev next
if (($fint_no_page - $fint_nb_pages) <= 0 && $fint_no_page != 1){ // prev
$fnb_photos = $fall_nb_photos - ($fnb_lim * ($fint_no_page - 1));
$fint_no_page = $fint_no_page - 1;
echo "<a href=\"browser.php?first=$ffirst&int_nb_photos=$fnb_photos&int_nb_pages=$fint_nb_pages&int_no_page=$fint_no_page&directory=$fdirectory\"><img src=\"img_src/prev.gif\" border=\"0\" alt=\"Page précédente\"></a> ";
$fint_no_page = $fint_no_page + 1;
if (($fint_nb_pages - $fint_no_page) > 0){ // next
echo " <a href=\"browser.php?first=$ffirst&int_nb_photos=$fnb_photos&int_nb_pages=$fint_nb_pages&int_no_page=$fint_no_page&directory=$fdirectory\"><img src=\"img_src/next.gif\" border=\"0\" alt=\"Prochaine page\"></a>";
// prev next
echo "</font></td></tr><tr><td width=\"10 %\" colspan=\"$jnb_phpage\" align=\"center\" height=\"4\" bgcolor=\"$bgcolor_titre\"></td></tr></table>";
die;
// fin Construction du tableau html
// affichage
$nb_lim = $jnb_phpage * $nb_line;
// rempli tableau des noms
$handle=opendir($directory);
$nb_photos = 0;
$nb_photos++;
$hnamep[$nb_photos] = $file;
$hnamep[$nb_photos+1] = "";
sort($hnamep);
closedir($handle);
// fin rempli tableau des noms
$int_nb_photos = nb_ph($directory); // nombre de photos
$all_nb_photos = $int_nb_photos;
$tmp_reste = $int_nb_photos % $nb_lim;
if ($tmp_reste == 0){
$int_nb_pages = $int_nb_photos / $nb_lim;
else{
$tmp_juste = $int_nb_photos - $tmp_reste;
$int_nb_pages = $tmp_juste / $nb_lim + 1; // nombre de pages
if ($first != "NO" ){
$first = "NO";
$int_no_page = 1;
constr_tab($int_nb_photos, $int_nb_pages, $int_no_page, $hnamep, $nb_lim, $first, $all_nb_photos, $directory, $jnb_phpage);
// fin affichage
?></TD>
[#b84600]<TD background="../images/test_40.jpg"> </TD>
<TD background="../images/test_41-2.jpg"> </TD>
<TD background="../images/test_42-2.jpg" valign="top">
<br>
<p><font size="1" face="Verdana, Arial, Helvetica, sans-serif">**PHOTOS**</font>
<div align="center"><img src="../images/yokos.gif" width="37" height="25"></div>
</TD>
<TD background="../images/test_43-2.jpg"> </TD>
<TD background="../images/test_44-2.jpg"> </TD>
<TD background="../images/test_45.jpg"> </TD>
</TR>
<TR>
<TD>
<IMG SRC="../images/test_46.jpg" WIDTH=15 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_47.jpg" WIDTH=12 HEIGHT=25></TD>
<TD> <IMG SRC="../images/test_48.jpg" WIDTH=444 HEIGHT=25 usemap="#Map" border="0"></TD>
<TD>
<IMG SRC="../images/test_49.jpg" WIDTH=12 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_50.jpg" WIDTH=35 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_51.jpg" WIDTH=95 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_52.jpg" WIDTH=34 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_53.jpg" WIDTH=102 HEIGHT=25></TD>
<TD>
<IMG SRC="../images/test_54.jpg" WIDTH=32 HEIGHT=25></TD>
</TR>
</TABLE>
</div>
<map name="Map">
<area shape="rect" coords="326,10,446,26" href="mailto:asiantcho@hotmail.com">
</map>
</BODY>
</HTML>
Marsh Posté le 07-11-2002 à 10:39:24
Juste un truc à la con : as-tu bien vérifié que tes IF étaient bien écrits?
Si une condition IF n'est pas remplie, et qu'il y a un petit souci de syntaxe, il n'ira pas jusqu'au bout du script... Et ne lira pas non plus le HTML que tu as en-dessous.
Rajoute une ligne de debug tout en bas du script pour savoir s'il y va
Marsh Posté le 07-11-2002 à 18:52:00
Fred999 a écrit a écrit : Juste un truc à la con : as-tu bien vérifié que tes IF étaient bien écrits? Si une condition IF n'est pas remplie, et qu'il y a un petit souci de syntaxe, il n'ira pas jusqu'au bout du script... Et ne lira pas non plus le HTML que tu as en-dessous. Rajoute une ligne de debug tout en bas du script pour savoir s'il y va ![]() |
cmt je fé stp?
je pense ke tt est bien écri car javé ce script sur une autre page ki marche c ca ke jtrouve louche
Marsh Posté le 08-11-2002 à 11:05:14
Les lignes de debug, c'est, par exemple :
<? echo "étape 1"; ?>
Rajoutes-en un peu partout, histoire de savoir à quel endroit ça plante.
Marsh Posté le 07-11-2002 à 03:00:18
bonjour
g mi du php dans une page avec du code html
mé enregistré en extension .php
et en fait tout le html se load bien et le script php ossi, mais kan je referme le php ?> et continu le HTML
il ne ve plus safficher
donc c comm si apres le ?> c t la fin de la page, plu rien se load
cmt faire?? merci..
