applet et class
applet et class - Java - Programmation
Marsh Posté le 13-04-2014 à 15:22:38
salut
j'ai creé une  plateforme avec JApplet form et voici le code de ma plateforme
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package pfe1;
import java.util.HashMap;
import javax.swing.JOptionPane;
 * @author root
public class index extends javax.swing.JApplet {
     * Initializes the applet index
    @Override
    public void init() {
        /* Set the Nimbus look and feel */
        //<editor-fold defaultstate="collapsed" desc=" Look and feel setting code (optional) ">
        /* If Nimbus (introduced in Java SE 6) is not available, stay with the default look and feel.
         * For details see http://download.oracle.com/javase/ [...] /plaf.html
        try {
            for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                if ("Nimbus".equals(info.getName())) {
                    javax.swing.UIManager.setLookAndFeel(info.getClassName());
                    break;
        } catch (ClassNotFoundException ex) {
            java.util.logging.Logger.getLogger(index.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        } catch (InstantiationException ex) {
        } catch (IllegalAccessException ex) {
        } catch (javax.swing.UnsupportedLookAndFeelException ex) {
        //</editor-fold>
        /* Create and display the applet */
        try {
            java.awt.EventQueue.invokeAndWait(new Runnable() {
                public void run() {
                    initComponents();
        } catch (Exception ex) {
            ex.printStackTrace();
     * This method is called from within the init() method to initialize the
     * form. WARNING: Do NOT modify this code. The content of this method is
     * always regenerated by the Form Editor.
    @SuppressWarnings("unchecked" )
    // <editor-fold defaultstate="collapsed" desc="Generated Code">
    private void initComponents() {
        bindingGroup = new org.jdesktop.beansbinding.BindingGroup();
        jLabel1 = new javax.swing.JLabel();
        login = new javax.swing.JTextField();
        jLabel2 = new javax.swing.JLabel();
        jLabel3 = new javax.swing.JLabel();
        jLabel4 = new javax.swing.JLabel();
        jButton1 = new javax.swing.JButton();
        jButton2 = new javax.swing.JButton();
        pass = new javax.swing.JPasswordField();
        outil = new javax.swing.JComboBox();
        jLabel6 = new javax.swing.JLabel();
        org.jdesktop.beansbinding.Binding binding = org.jdesktop.beansbinding.Bindings.createAutoBinding(org.jdesktop.beansbinding.AutoBinding.UpdateStrategy.READ_WRITE, new javax.swing.JLabel(), org.jdesktop.beansbinding.ObjectProperty.create(), this, org.jdesktop.beansbinding.BeanProperty.create("visible" ));
        bindingGroup.addBinding(binding);
        getContentPane().setLayout(null);
        jLabel1.setForeground(java.awt.Color.orange);
        jLabel1.setHorizontalAlignment(javax.swing.SwingConstants.CENTER);
        jLabel1.setText("Bienvennue dans Ma Plateforme " );
        jLabel1.setBorder(null);
        jLabel1.setHorizontalTextPosition(javax.swing.SwingConstants.CENTER);
        jLabel1.setMaximumSize(new java.awt.Dimension(400, 40));
        jLabel1.setName("" ); // NOI18N
        getContentPane().add(jLabel1);
        jLabel1.setBounds(230, 20, 320, 60);
        jLabel1.getAccessibleContext().setAccessibleDescription("" );
        login.addActionListener(new java.awt.event.ActionListener() {
            public void actionPerformed(java.awt.event.ActionEvent evt) {
                loginActionPerformed(evt);
        getContentPane().add(login);
        login.setBounds(360, 120, 160, 26);
        jLabel2.setForeground(java.awt.Color.orange);
        jLabel2.setText("Login" );
        getContentPane().add(jLabel2);
        jLabel2.setBounds(290, 120, 36, 30);
        jLabel3.setForeground(java.awt.Color.orange);
        jLabel3.setText("Password" );
        getContentPane().add(jLabel3);
        jLabel3.setBounds(280, 180, 70, 16);
        jLabel4.setForeground(java.awt.Color.orange);
        jLabel4.setText("choisir l'outil" );
        getContentPane().add(jLabel4);
        jLabel4.setBounds(240, 230, 100, 16);
        jButton1.setText("Valider" );
        jButton1.addActionListener(new java.awt.event.ActionListener() {
                jButton1ActionPerformed(evt);
        getContentPane().add(jButton1);
        jButton1.setBounds(350, 290, 80, 28);
        jButton2.setText("Annuler" );
        jButton2.addActionListener(new java.awt.event.ActionListener() {
                jButton2ActionPerformed(evt);
        getContentPane().add(jButton2);
        jButton2.setBounds(450, 290, 90, 28);
        getContentPane().add(pass);
        pass.setBounds(360, 170, 160, 26);
        outil.setModel(new javax.swing.DefaultComboBoxModel(new String[] { "Nessus", "Nmap" }));
        getContentPane().add(outil);
        outil.setBounds(360, 230, 150, 26);
        jLabel6.setIcon(new javax.swing.ImageIcon(getClass().getResource("/pfe1/kali-linux.jpg" ))); // NOI18N
        getContentPane().add(jLabel6);
        jLabel6.setBounds(0, 0, 750, 370);
        bindingGroup.bind();
    }// </editor-fold>
    private void loginActionPerformed(java.awt.event.ActionEvent evt) {
        // TODO add your handling code here:
    private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
        String ps=new String(this.pass.getPassword());
        String lg=this.login.getText().trim();
        if (((ps.equals("" ))&&(lg.equals("" ))) || (!lg.equals(ps))) {
         JOptionPane.showMessageDialog(null, " Invalid Mot de Pass et Login", "Error", JOptionPane.ERROR_MESSAGE);
        } else  {
            if ( lg.equals("admin" ) && ps.equals("admin" ))
              int nb =outil.getSelectedIndex();
              if (nb==0)
    private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {
        login.setText("" );
        pass.setText("" );
    // Variables declaration - do not modify
    private javax.swing.JButton jButton1;
    private javax.swing.JButton jButton2;
    private javax.swing.JLabel jLabel1;
    private javax.swing.JLabel jLabel2;
    private javax.swing.JLabel jLabel3;
    private javax.swing.JLabel jLabel4;
    private javax.swing.JLabel jLabel6;
    private javax.swing.JTextField login;
    private javax.swing.JComboBox outil;
    private javax.swing.JPasswordField pass;
    private org.jdesktop.beansbinding.BindingGroup bindingGroup;
    // End of variables declaration
je veux s'avoir comment faire appeler une class Nessus  dans  JApplet form et merci pour votre collaboration
voici le class Nessus
package pfe1;
import java.io.BufferedReader;
import java.io.InputStreamReader;
public class Nessus {
 public static void main(String[] args) {
  Nessus obj = new Nessus();
  String command = "/etc/init.d/nessusd start";
  String output = obj.executeCommand(command);
  System.out.println(output);
 private String executeCommand(String command1) {
  StringBuffer output = new StringBuffer();
  Process p;
                Runtime r = Runtime.getRuntime();
  try {
                    r.exec(" iceweasel https://kali:8834/html5.html#/scans" );
   p = Runtime.getRuntime().exec(command1);
   p.waitFor();
   BufferedReader reader =
                            new BufferedReader(new InputStreamReader(p.getInputStream()));
                        String line = "";
   while ((line = reader.readLine())!= null) {
    output.append(line + "\n" );
  } catch (Exception e) {
   e.printStackTrace();
  return output.toString();
Marsh Posté le 14-04-2014 à 01:46:25
si tu veux faire communiquer une applet (dans un navigateur) avec une application, hors d'un contexte serveur d'application/servlet/GET/POST, tu as les sockets.
http://fr.openclassrooms.com/infor [...] -sockets-1
