CRC16 en java [urgent]
CRC16 en java [urgent] - Java - Programmation
Marsh Posté le 05-12-2003 à 16:40:32
pouvez vous me passez le code java du crc16
je suis en controle la
thx
package calculcrc;
public class Testcalculcrc {
  public static void main(String[] args) {
int crc = 0xffff;
int octet;
int bitsortie;
int n = 0;
char[] message = {0x01,0x05,0x00,0x00,0xff,0x00};
int i = 0;
while (i != 6)  //Test de la fin de la trame
      crc = crc ^ message[i];
while (n < 8)  //Test
            crc = crc >>> 1;  //Décalage à droite d'un bit sans conservation de signe
            bitsortie = crc & 0x01;  //Test logique du bit de sortie
       if (bitsortie == 1)
              crc = crc ^ 0xA001; //Ou exclusif
       else
              n = n + 1;
          i++;
System.out.println("message : "+message);
System.out.println("CRC16 : "+crc);
Message édité par ggeforce le 05-12-2003 à 16:41:24
Marsh Posté le 05-12-2003 à 16:45:54
au revoir [:jpa]
Marsh Posté le 05-12-2003 à 16:50:21
  1. public static String generate()
  2. {
  3.  // Using the MD5 encryption algorithm in order to build the GUID.
  4.  // Since MD5 always returns a 128-bit String, we can put any info we want.
  5.         try
  6.         {
  7.             MessageDigest md = MessageDigest.getInstance("MD5" );
  8.             SecureRandom rand = new SecureRandom();
  9.
  10.             // The String that will contain the raw information
  11.             String rawGUID = InetAddress.getLocalHost().toString() + System.currentTimeMillis() + Long.toString(rand.nextLong());
  12.             // Encryption... may eat some CPU time
  13.             md.update(rawGUID.getBytes());
  14.             byte[] encBytes = md.digest();
  15.
  16.             StringBuffer sb = new StringBuffer();
  17.             // We should get 16 bytes, as expected.
  18.             for(int i=0; i<encBytes.length;i++)
  19.             {
  20.                 // Here, the result of the digest are BYTES (1 byte each) and we want WORDS (2 byte-encoded).
  21.                 // That is why we perform a bitwise AND with 255 (or 11111111 in binary), in order to get the hexadecimal value of the byte.
  22.                 // For example, -30 & 255 will give 226.
  23.                 int b = encBytes[i] & 255;
  24.                 // If the value is inferior to 16, then it means we will get a single character hexadecimal representation of the byte. So we add 0 in front of the hex value.
  25.                 if(b<16) sb.append('0');
  26.                 // Then we get the hexadecimal value and add it to the buffer.
  27.                 sb.append(Integer.toHexString(b));
  28.             }
  29.             return sb.toString();
  30.         }
  31.         catch(NoSuchAlgorithmException nsae)
  32.         {
  33.             nsae.printStackTrace();
  34.         }
  35.         catch(UnknownHostException uhe)
  36.         {
  37.          uhe.printStackTrace();
  38.         }
  39.         return null;
  40. }
Everyone thinks of changing the world, but no one thinks of changing himself  |  It is the peculiar quality of a fool to perceive the faults of others and to forget his own  |  Early clumsiness is not a verdict, it’s an essential ingredient.
Marsh Posté le 05-12-2003 à 16:57:24
bon, Taiche, va voir les télétubbies aussi ! tu lui as filé la solution à son problème, il n'a rien fait par lui même :fou:
Marsh Posté le 05-12-2003 à 17:10:17
efface ce message en suivant les pointillés  :
|                  kikoo lol mdr asv
Message édité par chrisbk le 05-12-2003 à 17:10:55
Marsh Posté le 05-12-2003 à 17:16:21
pourquoi mon mess a été effacé et pas celui de chrisbk [:sisicaivrai]
Marsh Posté le 05-12-2003 à 17:18:27
attends je reessaye :
  1. DWORD ZGCCRC::computeCRC32(const char *lpData,int dataSize)
  2. {
  3. if (!m_bIsChecksumTabComputed)
  4. computeChecksumTable();
  5. if (!dataSize) dataSize = strlen(lpData);
  6. DWORD dwReg = 0;
  7. int i = 0;
  8. while (i<dataSize)
  9. {
  10. //ici une fort interessante boucle
  11. //mais vous avez depassé le tps alloué de la version demo
  12. //désolé
  13. }
  14. return dwReg;
  15. }
Message édité par chrisbk le 05-12-2003 à 17:20:01
Marsh Posté le 05-12-2003 à 17:23:24
[:rofl2]
Marsh Posté le 05-12-2003 à 17:30:19
[:mlc2] j'aurais (presque) tout vu là.... [:rofl]
IVG en france
Marsh Posté le 05-12-2003 à 17:36:18
Du C++ !!!
Au secours !
Light is right
Marsh Posté le 05-12-2003 à 17:42:10
hahahaha et le mien aussi, comment il avait trop honte ce pauvre harkonnen[:ula]
Message édité par the real moins moins le 05-12-2003 à 17:44:30
Hey toi, tu veux acheter des minifigurines Lego, non ?
Marsh Posté le 05-12-2003 à 17:42:38
je crois que t'as pas tout compris
Marsh Posté le 05-12-2003 à 17:49:58
... ou comment casser les gens sans avoir rien compris du tout, uniquement pour le plaisir
t'as rien compris, c'est pas grave, j'ai l'habitude
je ferme
Message édité par Harkonnen le 05-12-2003 à 17:56:23
