Erreur dans le code natif ???
Erreur dans le code natif ??? - Java - Programmation
Marsh Posté le 25-08-2003 à 11:19:16
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x6D06ADE8
Function=Java_sun_awt_windows_WColor_getDefaultColor+0x203B
Library=C:\JBuilder8\jdk1.4\jre\bin\awt.dll
Current Java thread:
 at sun.awt.windows.WToolkit.eventLoop(Native Method)
 at sun.awt.windows.WToolkit.run(WToolkit.java:253)
 at java.lang.Thread.run(Thread.java:536)
Dynamic libraries:
0x00400000 - 0x00406000  C:\JBuilder8\jdk1.4\bin\javaw.exe
0x77F40000 - 0x77FEE000  C:\WINDOWS\System32\ntdll.dll
0x77E40000 - 0x77F36000  C:\WINDOWS\system32\kernel32.dll
0x77DA0000 - 0x77E3E000  C:\WINDOWS\system32\ADVAPI32.dll
0x78000000 - 0x78086000  C:\WINDOWS\system32\RPCRT4.dll
0x77D10000 - 0x77D9C000  C:\WINDOWS\system32\USER32.dll
0x77C40000 - 0x77C80000  C:\WINDOWS\system32\GDI32.dll
0x77BE0000 - 0x77C33000  C:\WINDOWS\system32\MSVCRT.dll
0x6D330000 - 0x6D45C000  C:\JBuilder8\jdk1.4\jre\bin\client\jvm.dll
0x76AE0000 - 0x76B0E000  C:\WINDOWS\System32\WINMM.dll
0x5D0A0000 - 0x5D0A7000  C:\WINDOWS\System32\serwvdrv.dll
0x5B3C0000 - 0x5B3C7000  C:\WINDOWS\System32\umdmxfrm.dll
0x6D1D0000 - 0x6D1D7000  C:\JBuilder8\jdk1.4\jre\bin\hpi.dll
0x6D300000 - 0x6D30D000  C:\JBuilder8\jdk1.4\jre\bin\verify.dll
0x6D210000 - 0x6D229000  C:\JBuilder8\jdk1.4\jre\bin\java.dll
0x6D320000 - 0x6D32D000  C:\JBuilder8\jdk1.4\jre\bin\zip.dll
0x6D000000 - 0x6D0FA000  C:\JBuilder8\jdk1.4\jre\bin\awt.dll
0x72F50000 - 0x72F73000  C:\WINDOWS\System32\WINSPOOL.DRV
0x76320000 - 0x7633C000  C:\WINDOWS\System32\IMM32.dll
0x77170000 - 0x77291000  C:\WINDOWS\system32\ole32.dll
0x6D180000 - 0x6D1D0000  C:\JBuilder8\jdk1.4\jre\bin\fontmanager.dll
0x736B0000 - 0x736F4000  C:\WINDOWS\System32\ddraw.dll
0x73B10000 - 0x73B16000  C:\WINDOWS\System32\DCIMAN32.dll
0x6DDE0000 - 0x6DE51000  C:\WINDOWS\System32\D3DIM.DLL
0x74690000 - 0x746D4000  C:\WINDOWS\System32\MSCTF.dll
0x1F070000 - 0x1F085000  C:\WINDOWS\system32\jmutil.dll
0x1F1E0000 - 0x1F1ED000  C:\WINDOWS\system32\jmvfw.dll
0x73AD0000 - 0x73AE3000  C:\WINDOWS\System32\AVICAP32.dll
0x77BD0000 - 0x77BD7000  C:\WINDOWS\system32\VERSION.dll
0x73B20000 - 0x73B40000  C:\WINDOWS\System32\MSVFW32.dll
0x77390000 - 0x77B95000  C:\WINDOWS\system32\SHELL32.dll
0x1F1F0000 - 0x1F254000  C:\WINDOWS\system32\SHLWAPI.dll
0x77300000 - 0x7738B000  C:\WINDOWS\system32\COMCTL32.dll
0x78090000 - 0x78174000  C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.10.0_x-ww_f7fb5805\comctl32.dll
0x72C70000 - 0x72C79000  C:\WINDOWS\System32\wdmaud.drv
0x72C60000 - 0x72C68000  C:\WINDOWS\System32\msacm32.drv
0x77BB0000 - 0x77BC4000  C:\WINDOWS\System32\MSACM32.dll
0x77BA0000 - 0x77BA7000  C:\WINDOWS\System32\midimap.dll
0x5B000000 - 0x5B00F000  C:\WINDOWS\System32\vfwwdm32.dll
0x73E30000 - 0x73E34000  C:\WINDOWS\System32\ksuser.dll
0x770E0000 - 0x7716B000  C:\WINDOWS\system32\OLEAUT32.dll
0x76F80000 - 0x76FF8000  C:\WINDOWS\System32\CLBCATQ.DLL
0x77000000 - 0x770D4000  C:\WINDOWS\System32\COMRes.dll
0x73E40000 - 0x73E4F000  C:\WINDOWS\System32\devenum.dll
0x76610000 - 0x766FC000  C:\WINDOWS\System32\setupapi.dll
0x73600000 - 0x73607000  C:\WINDOWS\System32\msdmo.dll
0x58300000 - 0x58320000  C:\WINDOWS\System32\ksproxy.ax
0x584E0000 - 0x5851E000  C:\WINDOWS\System32\camext20.ax
0x582C0000 - 0x582D8000  C:\WINDOWS\System32\kswdmcap.ax
0x73D20000 - 0x73E12000  C:\WINDOWS\System32\MFC42.DLL
0x61D70000 - 0x61D7E000  C:\WINDOWS\System32\MFC42LOC.DLL
0x73620000 - 0x73650000  C:\WINDOWS\System32\qcap.dll
0x73E60000 - 0x73EB5000  C:\WINDOWS\System32\DSOUND.dll
0x73EC0000 - 0x7400B000  C:\WINDOWS\System32\quartz.dll
0x58DB0000 - 0x58DF7000  C:\WINDOWS\System32\msh263.drv
0x1FA80000 - 0x1FA88000  C:\WINDOWS\system32\jmddraw.dll
0x1FAA0000 - 0x1FAAB000  C:\WINDOWS\system32\jmvcm.dll
0x1FE40000 - 0x1FEEC000  C:\WINDOWS\system32\jmvh263.dll
0x6D230000 - 0x6D235000  C:\JBuilder8\jdk1.4\jre\bin\jawt.dll
0x203D0000 - 0x203D9000  C:\WINDOWS\system32\jmfjawt.dll
0x76C40000 - 0x76C62000  C:\WINDOWS\system32\imagehlp.dll
0x6D9E0000 - 0x6DA5D000  C:\WINDOWS\system32\DBGHELP.dll
0x76BA0000 - 0x76BAB000  C:\WINDOWS\System32\PSAPI.DLL
Local Time = Thu Aug 21 15:36:56 2003
Elapsed Time = 8
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.1-b21 mixed mode)
PS : je n'ai eu cette erreur qu'une fois
heu...
Marsh Posté le 25-08-2003 à 11:22:33
oui et que veux tu savoir?
Just because you feel good does not make you right
Marsh Posté le 25-08-2003 à 11:24:07
non rien, ct juste ca
c la premiere fois que ca m'arrivé
heu...
Marsh Posté le 25-08-2003 à 11:28:27
c'est un message exceptionnel, du à JBuilder ou à ton application. SI tu arrives à le reproduire, ouvre un bug chez sun
Marsh Posté le 25-08-2003 à 16:26:20
moi je l'ai souvent ce truc :/
enfin je l ai qd je signe un jar et que j'essaye de le lancer ensuite en double cliquant dessus...
edit:
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x6D2935EB
Function=JNI_OnLoad+0x249
Library=C:\Program Files\Java\j2re1.4.1_04\bin\jpeg.dll
 at sun.awt.image.JPEGImageDecoder.readImage(Native Method)
 at sun.awt.image.JPEGImageDecoder.produceImage(JPEGImageDecoder.java:144)
 at sun.awt.image.InputStreamImageSource.doFetch(InputStreamImageSource.java:257)
 at sun.awt.image.ImageFetcher.fetchloop(ImageFetcher.java:172)
 at sun.awt.image.ImageFetcher.run(ImageFetcher.java:136)
Dynamic libraries:
0x00400000 - 0x00406000  C:\WINNT\system32\java.exe
0x77F80000 - 0x77FFF000  C:\WINNT\System32\ntdll.dll
0x77DA0000 - 0x77DFA000  C:\WINNT\system32\ADVAPI32.dll
0x77E70000 - 0x77F31000  C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77D9F000  C:\WINNT\system32\RPCRT4.DLL
0x78000000 - 0x78046000  C:\WINNT\system32\MSVCRT.dll
0x6D340000 - 0x6D46B000  C:\Program Files\Java\j2re1.4.1_04\bin\client\jvm.dll
0x77E00000 - 0x77E65000  C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7C000  C:\WINNT\system32\GDI32.DLL
0x77540000 - 0x77571000  C:\WINNT\system32\WINMM.dll
0x6D1E0000 - 0x6D1E7000  C:\Program Files\Java\j2re1.4.1_04\bin\hpi.dll
0x6D310000 - 0x6D31E000  C:\Program Files\Java\j2re1.4.1_04\bin\verify.dll
0x6D220000 - 0x6D239000  C:\Program Files\Java\j2re1.4.1_04\bin\java.dll
0x6D330000 - 0x6D33D000  C:\Program Files\Java\j2re1.4.1_04\bin\zip.dll
0x6D000000 - 0x6D105000  C:\Program Files\Java\j2re1.4.1_04\bin\awt.dll
0x777F0000 - 0x7780D000  C:\WINNT\system32\WINSPOOL.DRV
0x75E00000 - 0x75E1A000  C:\WINNT\system32\IMM32.dll
0x77A40000 - 0x77B35000  C:\WINNT\system32\ole32.dll
0x6D190000 - 0x6D1E0000  C:\Program Files\Java\j2re1.4.1_04\bin\fontmanager.dll
0x51000000 - 0x5104B000  C:\WINNT\system32\ddraw.dll
0x72810000 - 0x72816000  C:\WINNT\system32\DCIMAN32.dll
0x5C000000 - 0x5C0C7000  C:\WINNT\system32\D3DIM700.DLL
0x10000000 - 0x10010000  C:\Program Files\Trend Micro\PC-cillin 2002\JavaHook.DLL
0x77810000 - 0x77817000  C:\WINNT\system32\VERSION.dll
0x75950000 - 0x75956000  C:\WINNT\system32\LZ32.DLL
0x6D290000 - 0x6D2AE000  C:\Program Files\Java\j2re1.4.1_04\bin\jpeg.dll
0x77910000 - 0x77932000  C:\WINNT\system32\imagehlp.dll
0x72970000 - 0x7299D000  C:\WINNT\system32\DBGHELP.dll
0x68EA0000 - 0x68EAB000  C:\WINNT\system32\PSAPI.DLL
Local Time = Mon Aug 25 16:29:06 2003
Elapsed Time = 15
# Java VM: Java HotSpot(TM) Client VM (1.4.1_04-b01 mixed mode)
Message édité par veryfree le 25-08-2003 à 16:29:17
Marsh Posté le 25-08-2003 à 16:30:19
et bien ouvre un bug chez SUN avec l'ensemble des infos
Marsh Posté le 25-08-2003 à 16:34:33
je suis en train de me crée un compte pour ca [:dawa]
Marsh Posté le 25-08-2003 à 17:11:52
ouais enfin avant de les noyer ça serait quand meme bien de verifier que la faute vient pas de chez lui
du genre un jpeg corrompu  :sarcastic:
Hey toi, tu veux acheter des minifigurines Lego, non ?
Marsh Posté le 25-08-2003 à 17:18:24
où t'as vu qu'un jpeg corrompu doit faire planter la VM toi ? :o
ma vie, mon oeuvre - HomePlayer
Marsh Posté le 25-08-2003 à 17:18:59
certes, mais je voulais dire que ça serait bien de mieux cerner le problème avant de crier au bug :o
Marsh Posté le 25-08-2003 à 17:19:40
un plantage comme ca, c'est un bug !
Marsh Posté le 25-08-2003 à 17:22:01
sans blague[:kiki]
tu le fais expres ou quoi?
je dis que dire "mr, y'a un bug à cause de CE jpeg corrompu", ou "mr, y'a un bug", ça fait une difference.
:o
Marsh Posté le 25-08-2003 à 17:24:05
je te promets, c'est un bug :o
[:ddr555]
Marsh Posté le 25-08-2003 à 18:36:00
voilà :o
il me prend pour qui le --
[:rofl2] [:quoted]
Message édité par darklord le 25-08-2003 à 18:36:31
Marsh Posté le 25-08-2003 à 19:14:27
ca arrive a chaque fois que je veux lancer le "main" d'un jar qui signé...
je precise "main" parce que qd je le lance a partie d'un page web ( sous forme d'applet donc) ca tourne niquel ...
Message édité par veryfree le 25-08-2003 à 19:15:36
Marsh Posté le 25-08-2003 à 19:18:39
c'est louche ta trace qui part dans le JPEGImageDecoder, spour ça :o
Marsh Posté le 25-08-2003 à 19:19:34
c'est parce que c'est un bug :o
Marsh Posté le 25-08-2003 à 19:20:48
ui mais il a bien une origine ce bug non :o
Marsh Posté le 25-08-2003 à 19:21:20
ouais : une erreur dans le code :o
Marsh Posté le 25-08-2003 à 19:30:20
veryfree a écrit :
c'est peut etre le fait de signer le jar qui corromp les images de l'archive qui fait que ca plante
t'as des jpeg dans ton jar?
essaie, decompresse là une fois signée et mate les jpegs :o
(fc original.jpg signed.jar)
Marsh Posté le 25-08-2003 à 19:50:28
j'ai décompressé et tout est ok :o
Marsh Posté le 25-08-2003 à 19:51:40
voila c'est fait
la vache ce que c'est long a remplir leur truc  :sweat:
Marsh Posté le 25-08-2003 à 20:38:20
veryfree a écrit :
voila c'est fait
ouais :/
Marsh Posté le 28-08-2003 à 11:46:35
c'etait bien un bug
http://developer.java.sun.com/deve [...] 75817.html
et il avait déja été rapporté :o
Marsh Posté le 28-08-2003 à 12:02:54
veryfree a écrit :
c'etait bien un bug
