jaaavaaaaa!!!!! help :((((
jaaavaaaaa!!!!! help :(((( - Java - Programmation
Marsh Posté le 31-05-2012 à 12:22:56
bonjour,
mon application comprend l'enregistrement des données sur PHPMYAdmin via netbeans, et donc tout marche bien du moin pour les premiére valeurs enregistrées puis ben une exeption est affiché du genre:
Exception in thread "AWT-EventQueue-0" java.lang.IndexOutOfBoundsException: Index: 1082429, Size: 1082429
 at java.util.ArrayList.RangeCheck(ArrayList.java:547)
 at java.util.ArrayList.get(ArrayList.java:322)
 at memoire.MemoireView.jButton1ActionPerformed(MemoireView.java:663)
 at memoire.MemoireView.access$800(MemoireView.java:49)
 at memoire.MemoireView$4.actionPerformed(MemoireView.java:154)
 at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
 at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
 at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
 at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
 at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
 at java.awt.Component.processMouseEvent(Component.java:6263)
 at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
 at java.awt.Component.processEvent(Component.java:6028)
 at java.awt.Container.processEvent(Container.java:2041)
 at java.awt.Component.dispatchEventImpl(Component.java:4630)
 at java.awt.Container.dispatchEventImpl(Container.java:2099)
 at java.awt.Component.dispatchEvent(Component.java:4460)
 at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
 at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
 at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
 at java.awt.Container.dispatchEventImpl(Container.java:2085)
 at java.awt.Window.dispatchEventImpl(Window.java:2478)
 at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
 at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
 at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
 at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
 at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
 at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
de l'aide SVP! merci d'avance
Marsh Posté le 31-05-2012 à 13:29:31
for (i=0 ; i<tableau_vachement_long.size(); i++)
tu noteras le <, et non pas <=
HFR - Mes sujets pour Chrome - Firefox - vérifie les nouveaux posts des topics suivis/favoris
Marsh Posté le 31-05-2012 à 15:02:59
Et on peut même dire que tableau_vachement_long.size() vaut 1082429 :whistle:
Lire la première ligne d'un log d'erreur, c'est pas si dur...
A+,
There's more than what can be linked! --  Le capitaine qui ne veut pas obéir à la carte finira par obéir aux récifs. -- No jab ? No job ! -- (╯°□°)╯︵ ┻━┻
Marsh Posté le 31-05-2012 à 15:13:00
Mercii ! effectivement ...sté ça le probléme !
Marsh Posté le 31-05-2012 à 15:20:45
cool :)
le prochain coup, tu nous mets un titre descriptif ?
