Problème avec Ganttproject ...
Problème avec Ganttproject ... - Java - Programmation
Marsh Posté le 12-08-2006 à 20:34:09
J'ai installé GanttProject sous une debian sid avec la version java jdk1.5.0_08.
A chaque fois que je lance GanttProject, j'ai ce message d'erreur :
  1. 11 août 2006 22:13:40 org.bardsoftware.impl.eclipsito.BootImpl run
  2. INFO: Eclipsito platform is running.
  3. 11 août 2006 22:13:41 org.bardsoftware.impl.eclipsito.ApplicationLauncher launchApplication
  4. ATTENTION: / by zero
  5. java.lang.ArithmeticException: / by zero
  6. at sun.awt.X11.XIconWindow.calcIconSize(XIconWindow.java:79)
  7. at sun.awt.X11.XIconWindow.getIconSize(XIconWindow.java:168)
  8. at sun.awt.X11.XFramePeer.setIconImage(XFramePeer.java:206)
  9. at sun.awt.X11.XFramePeer.postInit(XFramePeer.java:75)
  10. at sun.awt.X11.XBaseWindow.init(XBaseWindow.java:117)
  11. at sun.awt.X11.XBaseWindow.<init>(XBaseWindow.java:150)
  12. at sun.awt.X11.XWindow.<init>(XWindow.java:86)
  13. at sun.awt.X11.XComponentPeer.<init>(XComponentPeer.java:101)
  14. at sun.awt.X11.XCanvasPeer.<init>(XCanvasPeer.java:22)
  15. at sun.awt.X11.XPanelPeer.<init>(XPanelPeer.java:27)
  16. at sun.awt.X11.XWindowPeer.<init>(XWindowPeer.java:53)
  17. at sun.awt.X11.XDecoratedPeer.<init>(XDecoratedPeer.java:36)
  18. at sun.awt.X11.XFramePeer.<init>(XFramePeer.java:41)
  19. at sun.awt.X11.XToolkit.createFrame(XToolkit.java:349)
  20. at java.awt.Frame.addNotify(Frame.java:491)
  21. at java.awt.Window.pack(Window.java:484)
  22. at net.sourceforge.ganttproject.GanttSplash.setVisible(Unknown Source)
  23. at net.sourceforge.ganttproject.GanttProject.main(Unknown Source)
  24. at net.sourceforge.ganttproject.application.MainApplication.run(Unknown Source)
  25. at org.bardsoftware.impl.eclipsito.ApplicationLauncher.launchApplication(ApplicationLauncher.java:29)
  26. at org.bardsoftware.impl.eclipsito.BootImpl$2.run(BootImpl.java:45)
  27. 11 août 2006 22:13:41 org.bardsoftware.impl.eclipsito.BootImpl shutdown
  28. INFO: Eclipsito platform is shut down.
Lorsque je demarre l'application freemind, j'obtiens un message similaire.
  1. User properties found.
  2. Default (System) Look & Feel: javax.swing.plaf.metal.MetalLookAndFeel
  3. Warning: the font you have set as standard - null - is not available.
  4. Exception in thread "main" java.lang.ArithmeticException: / by zero
  5. at sun.awt.X11.XIconWindow.calcIconSize(XIconWindow.java:79)
  6. at sun.awt.X11.XIconWindow.getIconSize(XIconWindow.java:168)
  7. at sun.awt.X11.XFramePeer.setIconImage(XFramePeer.java:206)
  8. at sun.awt.X11.XFramePeer.postInit(XFramePeer.java:75)
  9. at sun.awt.X11.XBaseWindow.init(XBaseWindow.java:117)
  10. at sun.awt.X11.XBaseWindow.<init>(XBaseWindow.java:150)
  11. at sun.awt.X11.XWindow.<init>(XWindow.java:86)
  12. at sun.awt.X11.XComponentPeer.<init>(XComponentPeer.java:101)
  13. at sun.awt.X11.XCanvasPeer.<init>(XCanvasPeer.java:22)
  14. at sun.awt.X11.XPanelPeer.<init>(XPanelPeer.java:27)
  15. at sun.awt.X11.XWindowPeer.<init>(XWindowPeer.java:53)
  16. at sun.awt.X11.XDecoratedPeer.<init>(XDecoratedPeer.java:36)
  17. at sun.awt.X11.XFramePeer.<init>(XFramePeer.java:41)
  18. at sun.awt.X11.XToolkit.createFrame(XToolkit.java:349)
  19. at java.awt.Frame.addNotify(Frame.java:491)
  20. at java.awt.Window.pack(Window.java:484)
  21. at freemind.main.FreeMind.main(FreeMind.java:533)
J'ai déinstallé et réinstallé jdk, GP et freemind et rien a changé.
Java fonctionne correctement lorsque j'utilise OpenOffice et Eclipse.
Tout idée sera la bienvenue.
