programmation java
programmation java - Java - Programmation
Marsh Posté le 01-10-2010 à 14:46:07
svp ,comment ajouter un button qui permet d'ajouter une ligne a un tableau swing
je suis débutante
voici mon code:
import javax.swing.JFrame;
import javax.swing.JPanel;
import javax.swing.JScrollPane;
import javax.swing.JTable;
import javax.swing.table.AbstractTableModel;
import java.awt.Dimension;
import java.awt.*;
import java.awt.GridLayout;
import javax.swing.JLabel;
import javax.swing.*;
import javax.swing.table.TableModel;
import javax.swing.event.*;
import java.awt.event.*;
import java.lang.*;
public class hh extends JPanel implements TableModelListener {
    private boolean DEBUG = false;
    public hh() {
        super(new FlowLayout());
        JTable table = new JTable(new MyTableModel());
        table.setPreferredScrollableViewportSize(new Dimension(800, 700));
        table.setFillsViewportHeight(true);
table.getModel().addTableModelListener(this);
        //Create the scroll pane and add the table to it.
        JScrollPane scrollPane = new JScrollPane(table);
        //Add the scroll pane to this panel.
        add(scrollPane);
        //JLABEL
         JLabel REMPLIR = new JLabel("Remplir les valeurs " );
       add(REMPLIR);
       //LES BUTTONS
       JButton CALCULER;
      CALCULER=new JButton("CALCULER" );
      add(CALCULER);
      JButton Ajouter;
      Ajouter=new JButton("AJOUTER" );
      add(Ajouter);
    public void tableChanged(TableModelEvent e) {
        int row = e.getFirstRow();
        int column = e.getColumn();
        TableModel model = (TableModel)e.getSource();
        String columnName = model.getColumnName(column);
        Object data = model.getValueAt(row, column);
    class MyTableModel extends AbstractTableModel {
        private String[] columnNames = {"V", "R",  "Cl", "T","F",  "C", "N", "C", "F",  "T", "P", "C"};
        private Object[][] data = {{" 1", "", "", "","","", "", "", "","","","",""},
   {" 2", "", "", "","","", "", "", "","","","",""},
   {" 3", "", "", "","","", "", "", "","","","",""}};
        public int getColumnCount() {
            return columnNames.length;
        public int getRowCount() {
            return data.length;
        public String getColumnName(int col) {
            return columnNames[col];
        public Object getValueAt(int row, int col) {
            return data[row][col];
        public Class getColumnClass(int c) {
            return getValueAt(0, c).getClass();
        public boolean isCellEditable(int row, int col) {
            if (col < 1) {
                return false;
            } else {
                return true;
        public void setValueAt(Object value, int row, int col) {
            if (DEBUG) {
                System.out.println("Setting value at " + row + "," + col
                                   + " to " + value
                                   + " (an instance of "
                                   + value.getClass() + " )" );
            data[row][col] = value;
            fireTableCellUpdated(row, col);
            if (DEBUG) {
                System.out.println("New value of data:" );
                printDebugData();
        private void printDebugData() {
            int numRows = getRowCount();
            int numCols = getColumnCount();
            for (int i=0; i < numRows; i++) {
                System.out.print("    row " + i + ":" );
                for (int j=0; j < numCols; j++) {
                    System.out.print("  " + data[i][j]);
                System.out.println();
            System.out.println("SSS" );
     // Create the GUI and show it.  For thread safety,
    private static void createAndShowGUI() {
        //Create and set up the window.
        JFrame frame = new JFrame("Outil versionnement" );
        frame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        //Create and set up the content pane.
      hh newContentPane = new hh();
        newContentPane.setOpaque(true); //content panes must be opaque
        frame.setContentPane(newContentPane);
        //Display the window.
        frame.pack();
        frame.setVisible(true);
    public static void main(String[] args) {
        //Schedule a job for the event-dispatching thread:
        //creating and showing this application's GUI.
        javax.swing.SwingUtilities.invokeLater(new Runnable() {
            public void run() {
                createAndShowGUI();
Marsh Posté le 01-10-2010 à 15:12:21
Et?
Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
Marsh Posté le 01-10-2010 à 15:14:57
je rien compris
Marsh Posté le 01-10-2010 à 15:21:49
Non mais d'accord mais c'est quoi que tu nous demandes?
Marsh Posté le 01-10-2010 à 16:29:22
De finir son TP
Marsh Posté le 01-10-2010 à 17:42:46
Je cherche des tutoriels swing( l'évenement  sur les button)
Marsh Posté le 01-10-2010 à 18:03:04
je ne cherche pas "de finir mon tp" mais d'avoir des idées car c'est la première fois que je manipule les interfaces swing
merci d'avance pour ton aide
Marsh Posté le 05-10-2010 à 00:51:10
Marsh Posté le 05-10-2010 à 08:52:57
MERCI POUR TON AIDE
