Bonjour J'ai un erreur "ORA-02049: temporisation : la transaction distribuée attend un verrou" sur mon application java ejb3, jpa, qui arrive 20 fois par mois.
ATTENTION: Local Exception Stack: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException Internal Exception: java.sql.SQLSyntaxErrorException: ORA-02049: temporisation : la transaction distribuée attend un verrou Error Code: 2049 Call: UPDATE MANAGE SET END_DATE = ? WHERE (((ID_HOST = ?) AND (BEGIN_DATE = ?)) AND (EMPLOYEE = ?)) bind => [4 parameters bound] Query: UpdateObjectQuery(com.agarik.operia.orm.Manage2@1b55825) at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:840) at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:906) at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:592) at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:535) at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1717) at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:253) at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207) at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193) at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.updateObject(DatasourceCallQueryMechanism.java:749) at org.eclipse.persistence.internal.queries.StatementQueryMechanism.updateObject(StatementQueryMechanism.java:432) at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.updateObjectForWriteWithChangeSet(DatabaseQueryMechanism.java:1042) at org.eclipse.persistence.queries.UpdateObjectQuery.executeCommitWithChangeSet(UpdateObjectQuery.java:84) at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:287) at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:58) at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:844) at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:743) at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:108) at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:85) at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2871) at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1516) at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1498) at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1449) at org.eclipse.persistence.internal.sessions.CommitManager.commitChangedObjectsForClassWithChangeSet(CommitManager.java:265) at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:128) at org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:3799) at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1415) at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:636) at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithPreBuiltChangeSet(UnitOfWorkImpl.java:1561) at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.writeChanges(RepeatableWriteUnitOfWork.java:447) at org.eclipse.persistence.internal.jpa.EntityManagerImpl.flush(EntityManagerImpl.java:780) at org.eclipse.persistence.internal.jpa.EJBQueryImpl.performPreQueryFlush(EJBQueryImpl.java:1298) at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:434) at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getSingleResult(EJBQueryImpl.java:773) at....rdbms.RDBMSEquipmentDAO.getEquipment(RDBMSEquipmentDAO.java:45) at ...s.RDBMSManageDAO.stopManage(RDBMSManageDAO.java:117) at ....monitoring.manage.ManageBean.stopManage(ManageBean.java:473)
@Stateless( @TransactionAttribute(value = TransactionAttributeType.SUPPORTS) public class ManageBean{
@TransactionAttribute(value = TransactionAttributeType.REQUIRED) public void stopManage(){ manageDAO.stopManage(); }
import javax.inject.Inject; import javax.persistence.EntityManager; import javax.persistence.PersistenceContext; import javax.persistence.Query; public class RDBMSManageDAO{ @PersistenceContext private EntityManager em; @Inject private EquipmentDAO hostDAO;
public void stopManage(){ Host host = hostDAO.getEquipment(manage.getEquipment()); } }
import javax.inject.Inject; import javax.persistence.EntityManager; import javax.persistence.PersistenceContext; import javax.persistence.Query; public abstract class RDBMSEquipmentDAO{ @PersistenceContext private EntityManager em; public Host getEquipment(String equipment) throws DAOException { Query query = em.createNamedQuery(... try { return (Host)query.getSingleResult();// DEBUT DE LA STACK D'ERREUR
Le type 'TransactionAttributeType.REQUIRED' propagé dans les différentes méthode par EJB est il compatible avec l'entityManager injecté par javax.inject.Inject (c'est du cdi, je crois)? Faut il faire un flush quelquepart car c'est un update? Faut il créer un singleton pour entityManager ou utiliser entityManagerFactory?
Marsh Posté le 20-09-2012 à 12:53:58
Error Code: 2049
@Stateless(
@PersistenceContext
@Inject
@PersistenceContext
try
catch (NoResultException e)
return null;
