Server Error in '/nutrinet-beta' Application. --------------------------------------------------------------------------------
The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.InvalidOperationException: The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[InvalidOperationException: The command 'MoveComplete' is not valid for the previous step, make sure the step type is not changed between postbacks.] System.Web.UI.WebControls.Wizard.OnBubbleEvent(Object source, EventArgs e) +1650930 System.Web.UI.WebControls.WizardChildTable.OnBubbleEvent(Object source, EventArgs args) +17 System.Web.UI.Control.RaiseBubbleEvent(Object source, EventArgs args) +35 System.Web.UI.WebControls.LinkButton.OnCommand(CommandEventArgs e) +115 System.Web.UI.WebControls.LinkButton.RaisePostBackEvent(String eventArgument) +163 System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +7 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +174 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5102
-------------------------------------------------------------------------------- Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
Marsh Posté le 17-11-2008 à 15:09:16
je suis sur visual studio team system pour configurer le module de test par rapport à un projet:
test de charge sur un site web (en l'occurence un formulaire dinscription, un asp_form)
J'arrive à passer toutes les etapes sauf la derniere qui me dit ceci :
_________________________________________________________________
Source Error:
Stack Trace:
Si quelqu'un a une idée, elle serai etudiée avec bienveillance
