A quoi sert cette sous cat ?
A quoi sert cette sous cat ? - Langages fonctionnels - Programmation
Marsh Posté le 26-03-2007 à 13:33:00
[:supaire]
Marsh Posté le 26-03-2007 à 13:34:53
À ça:
module Lambdabot (
        MODULE(..), Module(..),
        ModuleT, ModuleLB, ModuleUnit, Mode(..),
        IRCRState(..), IRCRWState(..), IRCError(..),
        module Msg,
        LB(..), lbIO,
        withModule, withAllModules, getDictKeys,
        getRef, getName, bindModule0, bindModule1, bindModule2,
        send, addServer, remServer, addServer',
        ircPrivmsg, ircPrivmsg', -- not generally used
        ircPrivmsgF,
        ircQuit, ircReconnect,
        ircGetChannels,
        ircSignalConnect, Callback, ircInstallOutputFilter, OutputFilter,
        ircInstallModule, ircUnloadModule,
        flushModuleState,
        ircLoad, ircUnload,
        checkPrivs, mkCN, handleIrc, catchIrc, runIrc,
  ) where
import qualified Message as Msg
import qualified Shared  as S
import qualified IRCBase as IRC (IrcMessage, quit, privmsg)
import Lib.Signals
import Lib.Util
import Lib.Serial
import Prelude hiding           (mod, catch)
import Network                  (withSocketsDo)
import System.Exit
import System.IO
#ifndef mingw32_HOST_OS
import System.Posix.Signals
-- n.b comment this out for prof
import System.Posix.Process     ( exitImmediately )
#endif
import Data.Char
import Data.IORef               (newIORef, IORef, readIORef, writeIORef)
import Data.List                (isSuffixOf, inits, tails)
import Data.Maybe               (isJust)
import Data.Map (Map)
import qualified Data.Map as M hiding (Map)
import qualified Data.ByteString.Char8 as P
import Data.ByteString (ByteString)
import Control.Concurrent
import Control.Exception
import Control.Monad.Error (MonadError (..))
import Control.Monad.Reader
import Control.Monad.State
import Control.Monad.Trans      ( liftIO )
#if __GLASGOW_HASKELL__ >= 605
import GHC.Err
#endif
#ifdef mingw32_HOST_OS
-- compatability shim
exitImmediately :: ExitCode -> IO a
exitImmediately = exitWith
#endif
-- Lambdabot state
-- | Global read-only state.
data IRCRState
  = IRCRState {
        ircMainThread  :: ThreadId,
        ircInitDoneMVar:: MVar (),
        ircQuitMVar    :: MVar ()
        -- ^This is a mildly annoying hack.  In order to prevent the program
        -- from closing immediately, we have to keep the main thread alive, but
        -- the obvious infinite-MVar-wait technique doesn't work - the garbage
        -- collector helpfully notices that the MVar is dead, kills the main
        -- thread (which will never wake up, so why keep it around), thus
        -- terminating the program.  Behold the infinite wisdom that is the
        -- Glasgow FP group.
type Callback = IRC.IrcMessage -> LB ()
type OutputFilter = Msg.Nick -> [String] -> LB [String]
-- | Global read\/write state.
data IRCRWState = IRCRWState {
        ircServerMap       :: Map String (String, IRC.IrcMessage -> LB ()),
        ircPrivilegedUsers :: Map Msg.Nick Bool,
        ircChannels        :: Map ChanName String,
            -- ^ maps channel names to topics
        ircModules         :: Map String ModuleRef,
        ircCallbacks       :: Map String [(String,Callback)],
        ircOutputFilters   :: [(String,OutputFilter)],
            -- ^ Output filters, invoked from right to left
        ircCommands        :: Map String ModuleRef,
        ircPrivCommands    :: [String],
        ircStayConnected   :: !Bool,
        ircDynLoad         :: S.DynLoad,
        ircOnStartupCmds   :: [String],
        ircPlugins         :: [String]
-- The virtual chat system.
-- The virtual chat system sits between the chat drivers and the rest of
-- Lambdabot.  It provides a mapping between the String server "tags" and
-- functions which are able to handle sending messages.
-- When a message is recieved, the chat module is expected to call
-- `LMain.received'.  This is not ideal.
addServer :: String -> (IRC.IrcMessage -> LB ()) -> ModuleT s LB ()
addServer tag sendf = do
    s <- get
    let svrs = ircServerMap s
    name <- getName
    case M.lookup tag svrs of
        Nothing -> put (s { ircServerMap = M.insert tag (name,sendf) svrs})
        Just _ -> fail $ "attempted to create two servers named " ++ tag
-- This is a crutch until all the servers are pluginized.
addServer' :: String -> (IRC.IrcMessage -> LB ()) -> LB ()
addServer' tag sendf = do
    s <- get
        Nothing -> put (s { ircServerMap = M.insert tag ("<core>",sendf) svrs})
remServer :: String -> LB ()
remServer tag = do
    s <- get
        Just _ -> do let svrs' = M.delete tag svrs
                     main <- asks ircMainThread
                     when (M.null svrs') $ io $ throwTo main (ErrorCall "all servers detached" )
                     put (s { ircServerMap = svrs' })
        Nothing -> fail $ "attempted to delete nonexistent servers named " ++ tag
send :: IRC.IrcMessage -> LB ()
send msg = do
    s <- gets ircServerMap
    case M.lookup (Msg.server msg) s of
        Just (_, sendf) -> sendf msg
        Nothing -> io $ hPutStrLn stderr $ "sending message to bogus server: " ++ show msg
newtype ChanName = ChanName { getCN :: Msg.Nick } -- should be abstract, always lowercase
  deriving (Eq, Ord)
instance Show ChanName where show (ChanName x) = show x
-- | only use the "smart constructor":
mkCN :: Msg.Nick -> ChanName
mkCN = ChanName . liftM2 Msg.Nick Msg.nTag (map toLower . Msg.nName)
-- The LB (LambdaBot) monad
-- | The IRC Monad. The reader transformer holds information about the
--   connection to the IRC server.
-- instances Monad, Functor, MonadIO, MonadState, MonadError
newtype LB a = LB { runLB :: ReaderT (IRCRState,IORef IRCRWState) IO a }
    deriving (Monad,Functor,MonadIO)
-- Actually, this isn't a reader anymore
instance MonadReader IRCRState LB where
    ask   = LB $ asks fst
    local = error "You are not supposed to call local"
instance MonadState IRCRWState LB where
    get = LB $ do
        ref <- asks snd
        lift $ readIORef ref
    put x = LB $ do
        ref <- asks snd
        lift $ writeIORef ref x
-- And now a MonadError instance to map IRCErrors to MonadError in LB,
-- so throwError and catchError "just work"
instance MonadError IRCError LB where
  throwError (IRCRaised e)    = io $ throwIO e
  throwError (SignalCaught e) = io $ evaluate (throwDyn $ SignalException e)
  m `catchError` h = lbIO $ \conv -> (conv m
              `catchDyn` \(SignalException e) -> conv $ h $ SignalCaught e)
              `catch` \e -> conv $ h $ IRCRaised e
-- A type for handling both Haskell exceptions and external signals
data IRCError = IRCRaised Exception | SignalCaught Signal deriving Show
-- lbIO return :: LB (LB a -> IO a)
-- CPS to work around predicativiy of haskell's type system.
lbIO :: ((forall a. LB a -> IO a) -> IO b) -> LB b
lbIO k = LB . ReaderT $ \r -> k (\(LB m) -> m `runReaderT` r)
-- | run a computation in the LB monad
evalLB :: LB a -> IRCRState -> IRCRWState -> IO a
evalLB (LB lb) rs rws = do
    ref  <- newIORef rws
    lb `runReaderT` (rs,ref)
-- May wish to add more things to the things caught, or restructure things
-- a bit. Can't just catch everything - in particular EOFs from the socket
-- loops get thrown to this thread and we musn't just ignore them.
handleIrc :: MonadError IRCError m => (IRCError -> m ()) -> m () -> m ()
handleIrc handler m = catchError m handler
-- Like handleIrc, but with arguments reversed
catchIrc :: MonadError IRCError m => m () -> (IRCError -> m ()) -> m ()
catchIrc = flip handleIrc
-- Lambdabot modes, networked , or command line
data Mode = Online | Offline deriving Eq
-- | The Lambdabot entry point.
-- Initialise plugins, connect, and run the bot in the LB monad
-- Also, handle any fatal exceptions (such as non-recoverable signals),
-- (i.e. print a message and exit). Non-fatal exceptions should be dealt
-- with in the mainLoop or further down.
runIrc :: [String] -> LB a -> S.DynLoad -> [String] -> IO ()
runIrc evcmds initialise ld plugins = withSocketsDo $ do
    rost <- initRoState
    r <- try $ evalLB (do withDebug "Initialising plugins" initialise
                          withIrcSignalCatch mainLoop)
                       rost (initState ld plugins evcmds)
    -- clean up and go home
    case r of
        Left er -> do putStrLn "exception:"
                      print er
                      exitWith (ExitFailure 1) -- won't happen.  exitImmediately cleans it all up
        Right _ -> exitWith ExitSuccess
-- | Default ro state
initRoState :: IO IRCRState
initRoState = do
    threadmain <- io myThreadId
    quitMVar <- io newEmptyMVar
    initDoneMVar <- io newEmptyMVar
    return $ IRCRState {
                 ircQuitMVar    = quitMVar,
                 ircInitDoneMVar= initDoneMVar,
                 ircMainThread  = threadmain
-- | Default rw state
initState :: S.DynLoad -> [String] -> [String] -> IRCRWState
initState ld plugins evcmds = IRCRWState {
        ircPrivilegedUsers = M.singleton (Msg.Nick "offlinerc" "null" ) True,
        ircChannels        = M.empty,
        ircModules         = M.empty,
        ircServerMap       = M.empty,
        ircCallbacks       = M.empty,
        ircOutputFilters   = [
            ([],cleanOutput),
            ([],lineify),
            ([],cleanOutput),
        --  ([],reduceIndent),
            ([],checkRecip) ],
        ircCommands        = M.empty,
        ircPrivCommands    = [],
        ircStayConnected   = True,
        ircDynLoad         = ld,
        ircPlugins         = plugins,
        ircOnStartupCmds   = evcmds
-- Actually, this isn't a loop anymore.  FIXME: better name.
mainLoop :: LB ()
mainLoop = do
    catchIrc
       (do asks ircInitDoneMVar >>= io . flip putMVar ()
           asks ircQuitMVar >>= io . takeMVar
           fail "don't write to the quitMVar!" )
       (\e -> do -- catch anything, print informative message, and clean up
                       (case e of
                            IRCRaised ex   -> "Exception: " ++ show ex
                            SignalCaught s -> "Signal: " ++ ircSignalMessage s)
        --  withDebug "Running exit handlers"    runExitHandlers
        --  withDebug "Writing persistent state" flushModuleState
            runExitHandlers >> flushModuleState
      -- this kills profiling output:
            io $ exitImmediately (ExitFailure 1))
      --    throwError e)
-- | run 'exit' handler on modules
runExitHandlers:: LB ()
runExitHandlers = withAllModules moduleExit >> return ()
-- | flush state of modules
flushModuleState :: LB ()
flushModuleState = do
    withAllModules (\m -> getName >>= writeGlobalState m)
    return ()
-- | The Module type class.
-- Minimal complete definition: @moduleHelp@, @moduleCmds@, and
-- either @process@ or @process_@
class Module m s | m -> s where
    -- | If the module wants its state to be saved, this function should
    --   return a Serial.
    --   The default implementation returns Nothing.
    moduleSerialize :: m -> Maybe (Serial s)
    -- | If the module maintains state, this method specifies the default state
    --   (for example in case the state can't be read from a state).
    --   The default implementation returns an error and assumes the state is
    --   never accessed.
    moduleDefState  :: m -> LB s
    -- | Is the module sticky? Sticky modules (as well as static ones) can't be
    --   unloaded. By default, modules are not sticky.
    moduleSticky    :: m -> Bool
    -- | The commands the module listenes to.
    moduleCmds      :: m -> [String]
    -- | This method should return a help string for every command it defines.
    moduleHelp      :: m -> String -> String
    -- | The privileged commands the module listenes to.
    modulePrivs     :: m -> [String]
    -- | Initialize the module. The default implementation does nothing.
    moduleInit      :: m -> ModuleT s LB ()
    -- | Finalize the module. The default implementation does nothing.
    moduleExit      :: m -> ModuleT s LB ()
    -- | Process a command a user sent, the resulting string is draw in
    -- some fashion. If the `process' function doesn't exist, we catch
    -- an exception when we try to call it, and instead call `process_'
    -- which is guaranteed to at least have a default instance.
    -- This magic (well, for Haskell) occurs in Base.hs
    process :: Msg.Message a
        => m                                -- ^ phantom     (required)
        -> a                                -- ^ the message (uneeded by most?)
        -> Msg.Nick                         -- ^ target
        -> String                           -- ^ command
        -> String                           -- ^ the arguments to the command
        -> ModuleLB s                       -- ^ maybe output
    -- | Process contextual input. A plugin that implements 'contextual'
    -- is able to respond to text not part of a normal command.
    contextual :: Msg.Message a
        -> String                           -- ^ the text
    -- | Like process, but uncommonly used args are ignored
    -- Lambdabot will attempt to run process first, and then fall back
    -- to process_, which in turn has a default instance.
    process_ :: m                           -- ^ phantom
             -> String -> String            -- ^ command, args
    -- A bytestring version
    fprocess_ :: m                        -- ^ phantom
              -> ByteString -> ByteString -- ^ command, args
              -> ModuleF s                -- ^ maybe output
    contextual _ _ _ _ = return []
    process_ _ _ _     = return []
    moduleHelp m _     = concat (map ('@':) (moduleCmds m))
    modulePrivs _      = []
    moduleCmds      _  = []
    moduleExit _       = return ()
    moduleInit _       = return ()
    moduleSticky _     = False
    moduleSerialize _  = Nothing
    moduleDefState  _  = return $ error "state not initalized"
-- | An existential type holding a module, used to represent modules on
-- the value level, for manipluation at runtime by the dynamic linker.
data MODULE = forall m s. (Module m s) => MODULE m
data ModuleRef = forall m s. (Module m s) => ModuleRef m (MVar s) String
-- | This transformer encodes the additional information a module might
--   need to access its name or its state.
newtype ModuleT s m a = ModuleT { moduleT :: ReaderT (MVar s, String) m a }
    deriving (Functor, Monad, MonadTrans, MonadIO, MonadError IRCError, MonadState t)
getRef :: Monad m => ModuleT s m (MVar s)
getRef  = ModuleT $ ask >>= return . fst
getName :: Monad m => ModuleT s m String
getName = ModuleT $ ask >>= return . snd
-- | bind an action to the current module so it can be run from the plain
--   `LB' monad.
bindModule0 :: ModuleT s LB a -> ModuleT s LB (LB a)
bindModule0 act = bindModule1 (const act) >>= return . ($ ())
-- | variant of `bindModule0' for monad actions with one argument
bindModule1 :: (a -> ModuleT s LB b) -> ModuleT s LB (a -> LB b)
bindModule1 act = ModuleT $
    ask >>= \st -> return (\val -> runReaderT (moduleT $ act val) st)
-- | variant of `bindModule0' for monad actions with two arguments
bindModule2 :: (a -> b -> ModuleT s LB c) -> ModuleT s LB (a -> b -> LB c)
bindModule2 act = bindModule1 (uncurry act) >>= return . curry
-- | A nicer synonym for some ModuleT stuffs
type ModuleLB s = ModuleT s LB [String]
-- | And for packed output
type ModuleF  s = ModuleT s LB [ByteString]
type ModuleUnit s = ModuleT s LB ()
-- Handling global state
-- | Peristence: write the global state out
writeGlobalState :: Module m s => m -> String -> ModuleT s LB ()
writeGlobalState mod name = case moduleSerialize mod of
  Nothing  -> return ()
  Just ser -> do
    state <- getRef >>= (io . readMVar) -- readMS
    case serialize ser state of
        Nothing  -> return ()   -- do not write any state
        Just out -> io $ P.writeFile (toFilename name) out
-- | Read it in
readGlobalState :: Module m s => m -> String -> IO (Maybe s)
readGlobalState mod name
    | Just ser <- moduleSerialize mod  = do
        state <- Just `fmap` P.readFile (toFilename name) `catch` \_ -> return Nothing
        catch (evaluate $ maybe Nothing (Just $!) (deserialize ser =<< state)) -- Monad Maybe)
              (\e -> do hPutStrLn stderr $ "Error parsing state file for: "
                                        ++ name ++ ": " ++ show e
                        hPutStrLn stderr $ "Try removing: "++show (toFilename name)
                        return Nothing) -- proceed irregardless
    | otherwise = return Nothing
-- | helper
toFilename :: String -> String
toFilename = ("State/"++)
-- | Register a module in the irc state
ircInstallModule :: MODULE -> String -> LB ()
ircInstallModule (MODULE mod) modname = do
    savedState <- io $ readGlobalState mod modname
    state      <- maybe (moduleDefState mod) return savedState
    ref        <- io $ newMVar state
    let modref = ModuleRef mod ref modname
    flip runReaderT (ref, modname) . moduleT $ do
        moduleInit mod
        let cmds  = moduleCmds mod
            privs = modulePrivs mod
        s <- get
        let modmap = ircModules s
            cmdmap = ircCommands s
        put $ s {
          ircModules = M.insert modname modref modmap,
          ircCommands = addList [ (cmd,modref) | cmd <- cmds++privs ] cmdmap,
          ircPrivCommands = ircPrivCommands s ++ privs
        io $ hPutStr stderr "." >> hFlush stderr
-- | Unregister a module's entry in the irc state
ircUnloadModule :: String -> LB ()
ircUnloadModule modname = withModule ircModules modname (error "module not loaded" ) (\m -> do
    when (moduleSticky m) $ error "module is sticky"
    moduleExit m
    writeGlobalState m modname
    s <- get
        cbs    = ircCallbacks s
        ofs    = ircOutputFilters s
    put $ s { ircCommands      = M.filter (\(ModuleRef _ _ name) -> name /= modname) cmdmap }
            { ircModules       = M.delete modname modmap }
            { ircCallbacks     = filter ((/=modname) . fst) `fmap` cbs }
            { ircServerMap     = M.filter ((/=modname) . fst) svrs }
            { ircOutputFilters = filter ((/=modname) . fst) ofs }
-- | Binding to dynamic loader functions (stored as a bundle in state)
-- passed from Boot. DynamicModule goes through here to get at them.
ircLoad :: FilePath -> S.Symbol -> LB (S.Module, a)
ircLoad mod sym = do
    s <- get
    let fn  = S.dynload (ircDynLoad s)
    io $ (fn mod sym)
-- | Dynamically unload a module
ircUnload :: FilePath -> LB ()
ircUnload mod = do
    s <- get
    io $ (S.unload (ircDynLoad s)) (S.Module mod)
ircSignalConnect :: String -> Callback -> ModuleT s LB ()
ircSignalConnect str f = do
    s <- get
    let cbs = ircCallbacks s
    name <- getName
    case M.lookup str cbs of -- TODO
        Nothing -> put (s { ircCallbacks = M.insert str [(name,f)]    cbs})
        Just fs -> put (s { ircCallbacks = M.insert str ((name,f):fs) cbs})
ircInstallOutputFilter :: OutputFilter -> ModuleT s LB ()
ircInstallOutputFilter f = do
    name <- getName
    modify $ \s ->
        s { ircOutputFilters = (name, f): ircOutputFilters s }
-- | Checks if the given user has admin permissions and excecute the action
--   only in this case.
checkPrivs :: IRC.IrcMessage -> LB Bool
checkPrivs msg = gets (isJust . M.lookup (Msg.nick msg) . ircPrivilegedUsers)
-- Some generic server operations
ircGetChannels :: LB [Msg.Nick]
ircGetChannels = (map getCN . M.keys) `fmap` gets ircChannels
-- Send a quit message, settle and wait for the server to drop our
-- handle. At which point the main thread gets a closed handle eof
-- exceptoin, we clean up and go home
ircQuit :: String -> String -> LB ()
ircQuit svr msg = do
    modify $ \state -> state { ircStayConnected = False }
    send  $ IRC.quit svr msg
    liftIO $ threadDelay 1000
    io $ hPutStrLn stderr "Quit"
ircReconnect :: String -> String -> LB ()
ircReconnect svr msg = do
-- | Send a message to a channel\/user. If the message is too long, the rest
--   of it is saved in the (global) more-state.
ircPrivmsg :: Msg.Nick      -- ^ The channel\/user.
           -> String        -- ^ The message.
           -> LB ()
ircPrivmsg who msg = do
    filters   <- gets ircOutputFilters
    sendlines <- foldr (\f -> (=<< ) (f who)) ((return . lines) msg) $ map snd filters
    mapM_ (\s -> ircPrivmsg' who (take textwidth s)) (take 10 sendlines)
-- A raw send version
ircPrivmsg' :: Msg.Nick -> String -> LB ()
ircPrivmsg' who ""  = ircPrivmsg' who " "
ircPrivmsg' who msg = send $ IRC.privmsg who msg
ircPrivmsgF :: Msg.Nick -> ByteString -> LB ()
ircPrivmsgF who s= ircPrivmsg who (P.unpack s) -- TODO
rawPrivmsgF :: String -> Maybe ByteString -> LB ()
rawPrivmsgF _   Nothing  = send Nothing
rawPrivmsgF who (Just s) | P.null s  = ircPrivmsg' who (Just " " )
                         | otherwise = send . Just $ IRC.privmsgF who msg
-- Module handling
-- | Interpret an expression in the context of a module.
-- Arguments are which map to use (@ircModules@ and @ircCommands@ are
-- the only sensible arguments here), the name of the module\/command,
-- action for the case that the lookup fails, action if the lookup
-- succeeds.
withModule :: (Ord k)
           => (IRCRWState -> Map k ModuleRef)
           -> k
           -> LB a
           -> (forall mod s. Module mod s => mod -> ModuleT s LB a)
           -> LB a
withModule dict modname def f = do
    maybemod <- gets (M.lookup modname . dict)
    case maybemod of
      -- TODO stick this ref stuff in a monad instead. more portable in
      -- the long run.
      Just (ModuleRef m ref name) -> do
          runReaderT (moduleT $ f m) (ref, name)
      _                           -> def
-- | Interpret a function in the context of all modules
withAllModules :: (forall mod s. Module mod s => mod -> ModuleT s LB a) -> LB [a]
withAllModules f = do
    mods <- gets $ M.elems . ircModules :: LB [ModuleRef]
    (`mapM` mods) $ \(ModuleRef m ref name) -> do
getDictKeys :: (MonadState s m) => (s -> Map k a) -> m [k]
getDictKeys dict = gets (M.keys . dict)
-- | Print a debug message, and perform an action
withDebug :: String -> LB a -> LB ()
withDebug s a = do
    io $ hPutStr stderr (s ++ " ..." )  >> hFlush stderr
    a
    io $ hPutStrLn stderr " done." >> hFlush stderr
-- Output filters
textwidth :: Int
textwidth = 200 -- IRC maximum msg length, minus a bit for safety.
-- | For now, this just checks for duplicate empty lines.
cleanOutput :: OutputFilter
cleanOutput _ msg = return $ remDups True msg'
    where
        remDups True  ([]:xs) =    remDups True xs
        remDups False ([]:xs) = []:remDups True xs
        remDups _     (x: xs) = x: remDups False xs
        remDups _     []      = []
        msg' = map dropSpaceEnd msg
-- | wrap long lines.
lineify :: OutputFilter
lineify = const (return . mlines . unlines)
-- | break into lines
mlines :: String -> [String]
mlines = (mbreak =<< ) . lines
    where
        mbreak :: String -> [String]
        mbreak xs
            | null bs   = [as]
            | otherwise = (as++cs) : filter (not . null) (mbreak ds)
            where
                (as,bs) = splitAt (w-n) xs
                breaks  = filter (not . isAlphaNum . last . fst) $ drop 1 $
                                  take n $ zip (inits bs) (tails bs)
                (cs,ds) = last $ (take n bs, drop n bs): breaks
                w = textwidth
                n = 10
-- | Don't send any output to alleged bots.
checkRecip :: OutputFilter
checkRecip who msg
--  FIXME: this doesn't work with plugin protocols :(
--  | who == Config.name Config.config                   = return []
    | "bot" `isSuffixOf` lowerCaseString (Msg.nName who) = return []
    | otherwise                                          = return msg
:o
I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing?
Marsh Posté le 26-03-2007 à 14:04:03
j'adore c'te sous cat ! 3 topics, dont 2 fermés, c'est géant [:petrus75]
edit: ah non, c'est dans l'autre
Message édité par Harkonnen le 26-03-2007 à 14:04:37
