Bonjour! J'ai trouvé un tuto pour insérer un Guestbook ...Tout est OK, à part un détail qui me dérange: le message posté "mange" les é et les remplace par un point. Je mets ici le .php <?php
// ################################################################################### // ########## Reading and Writing the new data to the GuestBook Database #############
if ($Submit == "Yes" ) { // Next line tells the script which Text file to open. $filename = "GuestBook.txt";
/* This Line adds the '&GuestBook=' part to the front of the data that is stored in the text file. This is important because without this the Flash movie would not be able to assign the variable 'GuestBook' to the value that is located in this text file */
// ################################################################################### // ######### Formatting and Printing the Data from the Guestbook to the Flash Movie ##
Marsh Posté le 03-12-2006 à 15:11:07
Bonjour!
<?php
$Submit = $_POST["Submit"];
$Name = $_POST["Name"];
$Email = $_POST["Email"];
$Website = $_POST["Website"];
$Comments = $_POST["Comments"];
$NumLow = $_REQUEST["NumLow"];
$NumHigh = $_REQUEST["NumHigh"];
// Replace special characters - you can remove the next 5 lines if wanted.
$Name = ereg_replace("[^A-Za-z0-9 ]", "", $Name);
$Comments = ereg_replace("[^A-Za-z0-9 \@\.\/\']", "", $Comments);
$Website = eregi_replace("http://", "", $Website);
$Website = ereg_replace("[^A-Za-z0-9 \@\.\/\'\~\:]", "", $Website);
// Remove slashes.
$Name = stripslashes($Name);
$Email = stripslashes($Email);
$Website = stripslashes($Website);
$Comments = stripslashes($Comments);
// Opens up the file declared above for reading
$fp = fopen( $filename,"r" );
$OldData = fread($fp, 80000);
fclose( $fp );
// Gets the current Date of when the entry was submitted
$Today = (date ("l dS of F Y" ));
$Input = "Name: <b>$Name</b>
Email: <b><u><a href=\"mailto:$Email\">$Email</a></u></b>
Website: <b><u><a href=\"http://$Website\" target=\"_blank\">$Website</a></u></b>
Comments: <b>$Comments</b><br>
<i><font size=\"-1\">Date: $Today</font>
$New = "$Input$OldData";
// Opens and writes the file.
$fp = fopen( $filename,"w" );
fwrite($fp, $New, 800000);
fclose( $fp );
echo '&load=loaded&';
$Data = fread($fp, 800000);
fclose( $fp );
// Splits the Old data into an array anytime it finds the pattern .:::.
$DataArray = split (".:::.", $Data);
// Counts the Number of entries in the GuestBook
$NumEntries = count($DataArray) - 1;
print "&load=loaded&&TotalEntries=$NumEntries&NumLow=$NumLow&NumHigh=$NumHigh&GuestBook=";
for ($n = $NumLow; $n < $NumHigh; $n++) {
print $DataArray[$n];
if (!$DataArray[$n]) {
Print "<br><br><br><b>No More entries</b>";
exit;
Merci de me renseigner!
