Comment utiliser les css sous PHP
Comment utiliser les css sous PHP - PHP - Programmation
Marsh Posté le 01-08-2005 à 02:51:16
voilou, je n'arrive pas à integrer mon fichier style.css.
j'ai essayé
echo "<html><head><link rel='stylesheet' type='text/css' href='style.css'></head><body>";
mais cela ne marche pas
j'ai verifier c'est la bonne syntaxe.
include ("connexion.php" ) ;
mysql_connect($hostname,$mysqluser,$mysqlpswd);
mysql_selectdb($database) or die($diemessage);
$req = mysql_query("SELECT quartier, prix12, prix34, prix5 FROM quartier" );
echo "<FORM name='monform' action='page.php' method='post'>
<table>
while ($list = mysql_fetch_object($req))
 echo "<tr>
    <td><INPUT type='text' name='quartier' value='$list->quartier' maxlength='50' size='50'></td>
    <td><input type='text' name='prix12'   value='$list->prix12'   maxlength='20' size='20'></td>
    <td><input type='text' name='prix34'   value='$list->prix12'   maxlength='20' size='20'></td>
    <td><input type='text' name='prix5'    value='$list->prix5'    maxlength='20' size='20'></td>
  </tr>";
echo "
<table>
<INPUT type='submit' value='Envoyer'>
</form>
</body></html>
echo "listing des prix au m2";
Message édité par weed le 01-08-2005 à 02:56:09
Marsh Posté le 01-08-2005 à 03:08:37
  1. <html>
  2. <head>
  3. <link rel='stylesheet' type='text/css' href='style.css'>
  4. </head>
  5. <body>
  6. <?
  7. include ("connexion.php" ) ;
  8. mysql_connect($hostname,$mysqluser,$mysqlpswd);
  9. mysql_selectdb($database) or die($diemessage);
  10. echo "<html><head><link rel='stylesheet' type='text/css' href='style.css'></head><body>";
  11. $req = mysql_query("SELECT quartier, prix12, prix34, prix5 FROM quartier" );
  12. echo "<FORM name='monform' action='page.php' method='post'>
  13. <table>
  14. ";
  15. while ($list = mysql_fetch_object($req))
  16. {
  17. echo "<tr>
  18.     <td><INPUT type='text' name='quartier' value='$list->quartier' maxlength='50' size='50'></td>
  19.     <td><input type='text' name='prix12'   value='$list->prix12'   maxlength='20' size='20'></td>
  20.     <td><input type='text' name='prix34'   value='$list->prix12'   maxlength='20' size='20'></td>
  21.     <td><input type='text' name='prix5'    value='$list->prix5'    maxlength='20' size='20'></td>
  22.   </tr>";
  23. }
  24. echo "
  25. <table>
  26. <INPUT type='submit' value='Envoyer'>
  27. </form>
  28. </body></html>
  29. ";
  30. echo "listing des prix au m2";
  31. ?>
  32. </body>
  33. </html>
Feaks Forum
Marsh Posté le 01-08-2005 à 12:23:27
cela fonctionne nickel, merci
Marsh Posté le 01-08-2005 à 12:32:21
:jap: :)
EDIT : j'ai fait les balises simples, mais apres euh pense a mettre tout le blabla pour qu'elles soient valides xhtml :d
Message édité par Multinickname le 01-08-2005 à 12:33:01
Feaks Forum
Marsh Posté le 01-08-2005 à 14:41:53
Quel rapport avec PHP ?
Marsh Posté le 01-08-2005 à 14:56:34
Multinickname a écrit :
  1. <html>
  2. <head>
  4. </head>
  5. <body>
  6. <?
uhm, c'est quoi le but de la maneouvre ? parce que là, à la sortie, il y a deux fois <html> et deux entetes <head>
my flick r - Just Tab it !
Marsh Posté le 01-08-2005 à 19:41:36
euhh oui en effet y a des balises html en double.
Multinickname m'avait montré rapidemment comment il fallait faire pour j'integre mon fichier dans ma page php. Il a juste oublié de retiré les balises html que j'avais deja mises, c'est tout :)
Sinon le but de la maneuvre et de pour l'instant de lire une table. C'est tout ;)
Marsh Posté le 02-08-2005 à 17:07:06
Oui j'ai fait un c/c rapide, désolé :d
Feaks Forum
Marsh Posté le 02-08-2005 à 19:10:09
y a pas de mal, y a juste la ligne que j'avais rajouté à retirer :
