pb ligne de code debutant
pb ligne de code debutant - PHP - Programmation
Marsh Posté le 01-08-2007 à 16:53:07
Salut a tous
Je viens d'installer un script pour mon projet de site,mais un pb apparait a l'accés de mon admin:
Parse error: syntax error, unexpected '}' in /home.10.3/annuairext/www/france-libertins/admin/index.php on line 34
Voici le code:
1 <?
2 /*
3 (C) AEwebworks Software Development Ltd., 2002-2003
4 IMPORTANT: This is a commercial software product and any kind of using it must agree
5 to the AEwebworks Software Development Ltd. license agreement. It can be found at
6 http://www.aewebworks.com/license.htm
7 This notice may not be removed from the source code.
8 */
9
10 require_once( "../inc/header.inc.php" );
11 require_once( "{$dir['inc']}db.inc.php" );
12 require_once( "{$dir['inc']}admin.inc.php" );
13 require_once( "{$dir['inc']}profiles.inc.php" );
14 require_once( "{$dir['inc']}design.inc.php" );
15 require_once( "{$dir['inc']}admin_design.inc.php" );
16 require_once( "{$dir['inc']}utils.inc.php" );
17
18 if ( $_POST['ID'] )
19 {
20 $admin_id = process_db_input( $_POST['ID'] );
21 $admin_pass = process_db_input( $_POST['Password'] );
22 $result = db_res( "SELECT * FROM `Admins` WHERE `Name` = '$admin_id'
23 AND `Password`= '$admin_pass'" );
24    if ( mysql_num_rows( $result ) != 1 )
25  login_form( '<center><b><font color="#ff0000">Login Failed! Try again</font></b></center>', 1 );
26 } else {
27 setcookie ("adminID", $_POST[ID], 0, "/" );setcookie ("adminPassword", crypt( $_POST[Password], 'secret_string' ), 0, "/" );
28
29 ?>
30 Welcome back, <b><? echo $admin_id; ?></b>. Logging you in...
31 <script language="Javascript">location.href='<? echo $_SERVER[PHP_SELF]; ?>';</script>
32 <?
33  exit;
34 }
35 }
36 if ( !$_COOKIE['adminID'] || !$_COOKIE['adminPassword'] )
37 {
38 // this is dynamic page -  send headers to do not cache this page
39 send_headers_page_changed();
40 login_form( "", 1 );
41 }
42
43 $logged['admin'] = member_auth( 1 );
44
45 $free_mode = getParam("free_mode" ) == "on" ? 1 : 0;
Merci a vous
Marsh Posté le 01-08-2007 à 16:56:14
tu fermes une accolade de trop
Marsh Posté le 01-08-2007 à 16:57:22
Il n'y a même pas de ?> final :D
Jette ce code PHP et apprends a le faire toi même :o
"I can cry like Roger. It's just a shame I can't play like him" - Andy Murray, 2010
Marsh Posté le 01-08-2007 à 16:59:04
Merci a toi
J'ai enlevé l'accolade de la ligne 34 et exactement meme erreur
Wiids , je ne vous ais pas donné la page entiere,pour cela que tu ne vois pas le final
Message édité par LOCO27 le 01-08-2007 à 17:02:35
Marsh Posté le 01-08-2007 à 17:13:12
LOCO27 a écrit :
Merci a toi
Pas bête [:transparency]
La même erreur mais pas la même ligne, si ?
Message édité par WiiDS le 01-08-2007 à 17:13:46
Marsh Posté le 01-08-2007 à 17:15:41
si si meme ligne 34 et maintenant c'est ca ligne 34 :
Marsh Posté le 01-08-2007 à 17:18:47
Essayes ça :
if (( !$_COOKIE['adminID'] ) || ( !$_COOKIE['adminPassword'] ))
Marsh Posté le 01-08-2007 à 17:21:36
Toujours pareil..meme erreur ...bizarre ce truc...
Marsh Posté le 01-08-2007 à 17:27:06
sérieux, tu pourrais pas mettre ton code dans des balises codes pour que ce soit plus lisible...Parce que là, c'est pas évident si faut chercher un couple {} mal fermé ou autre :/...
Marsh Posté le 01-08-2007 à 17:30:33
  1. <?
  2. /*
  3. (C) AEwebworks Software Development Ltd., 2002-2003
  4. IMPORTANT: This is a commercial software product and any kind of using it must agree
  5. to the AEwebworks Software Development Ltd. license agreement. It can be found at
  6. http://www.aewebworks.com/license.htm
  7. This notice may not be removed from the source code.
  8. */
  9. require_once( "../inc/header.inc.php" );
  10. require_once( "{$dir['inc']}db.inc.php" );
  11. require_once( "{$dir['inc']}admin.inc.php" );
  12. require_once( "{$dir['inc']}profiles.inc.php" );
  13. require_once( "{$dir['inc']}design.inc.php" );
  14. require_once( "{$dir['inc']}admin_design.inc.php" );
  15. require_once( "{$dir['inc']}utils.inc.php" );
  16. if ( $_POST['ID'] )
  17. {
  18. $admin_id = process_db_input( $_POST['ID'] );
  19. $admin_pass = process_db_input( $_POST['Password'] );
  20. $result = db_res( "SELECT * FROM `Admins` WHERE `Name` = '$admin_id' AND `Password` = '$admin_pass'" );
  21.     if ( mysql_num_rows( $result ) != 1 )
  22.  login_form( '<center><b><font color="#ff0000">Login Failed! Try again</font></b></center>', 1 );
  23. } else {
  24. setcookie ("adminID", $_POST[ID], 0, "/" );setcookie ("adminPassword", crypt( $_POST[Password], 'secret_string' ), 0, "/" );
  25. ?>
  26. Welcome back, <b><? echo $admin_id; ?></b>. Logging you in...
  27. <script language="Javascript">location.href='<? echo $_SERVER[PHP_SELF]; ?>';</script>
  28. <?
  29.  exit;
  30. }
  31. if (( !$_COOKIE['adminID'] ) || ( !$_COOKIE['adminPassword'] ))
  32. {
  33. // this is dynamic page -  send headers to do not cache this page
  34. send_headers_page_changed();
  35. login_form( "", 1 );
  36. }
  37. $logged['admin'] = member_auth( 1 );
  38. $free_mode = getParam("free_mode" ) == "on" ? 1 : 0;
Marsh Posté le 01-08-2007 à 17:39:15
Commente des lignes progressivement et regarde où ça foire... je sais c'est porc mais dans les cas désespérés...
Marsh Posté le 01-08-2007 à 17:41:27
??? desolé mais je capte pas ce que tu veux me dire...
Marsh Posté le 01-08-2007 à 17:42:39
Oups je dois partir,merci de votre aide et bon courage si vous trouvez...
Je reviens...
Marsh Posté le 01-08-2007 à 18:10:41
Ben commente de la ligne 1 à 34 par exemple, puis regarde si l'erreur est toujours là. Si c'est pas le cas c'est que elle est dans la partie commentée, et sinon dans l'autre.
Rinse and repeat.
Marsh Posté le 01-08-2007 à 21:37:26
exit();
ça marche pas mieux comme ça ?
The Rom's, à votre service
