valeur et prix d'un site web - PHP - Programmation
Marsh Posté le 06-11-2009 à 19:50:15
en plus du spam, ton site merde
A PHP Error was encountered
Severity: Notice
Message: Undefined offset: 2
Filename: models/rank.php
Line Number: 45
Marsh Posté le 06-11-2009 à 19:57:07
ah oui j'ai pas vu ça t'inquiète je vais corriger cela!!! bon je suis pas monsieur php
Marsh Posté le 06-11-2009 à 20:03:04
je vais revenir a la charge mais comment tu a obtenu cette erreur ? car moi je la vois pas , et je pense en désactivant l'affichage des erreurs je vais régler ce problème !
Marsh Posté le 06-11-2009 à 20:06:31
non, tu desactive pas les erreurs, tu corriges
c'est la moindre des choses avant d'aller spammer
message d'erreur complet :
Severity: Notice
Line Number: 45
Severity: Warning
Message: Division by zero
Filename: controllers/website.php
Line Number: 410
Severity: Warning
Line Number: 411
Severity: Warning
Line Number: 412
Severity: Warning
Message: file_get_contents() [function.file-get-contents]: php_network_getaddresses: getaddrinfo failed: Name or service not known
Filename: models/remoteconnector.php
Line Number: 58
Severity: Warning
Message: file_get_contents(http://www.annegaland.com) [function.file-get-contents]: failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known
Line Number: 58
Severity: Warning
Message: get_meta_tags() [function.get-meta-tags]: php_network_getaddresses: getaddrinfo failed: Name or service not known
Line Number: 94
Severity: Warning
Message: get_meta_tags(http://www.annegaland.com) [function.get-meta-tags]: failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known
Line Number: 94
A Database Error Occurred
Error Number: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' -- no title found -- ','','',DATE_FORMAT(NOW(),"%Y/%m/%d" ),,0,)' at line 3
INSERT INTO worth (domain,alexa,google_back,yahoo_back,altavista_back,alltheweb_back,msn_back, pagerank,title,keyword,description,datetime,worth,dpview,dearn) VALUES('annegaland.com',0,0, 0,0,0,0,,' -- no title found -- ','','',DATE_FORMAT(NOW(),"%Y/%m/%d" ),,0,)
Marsh Posté le 07-11-2009 à 22:11:46
On est bientôt en 2010 .. quand je vois tous ces gens qui sont incapables d'utiliser des méthodes simples et actuelles pour se connecter à une base de donnée ... T1 ça me déprime
Utilise les prepared statements de MySQL ou bien un truc genre DBO
Marsh Posté le 08-11-2009 à 08:01:51
ReplyMarsh Posté le 08-11-2009 à 10:12:34
| Citation : |
![[:dawak] [:dawak]](https://forum-images.hardware.fr/images/perso/dawak.gif)
Marsh Posté le 08-11-2009 à 15:21:47
| midelti a écrit : je vais revenir a la charge mais comment tu a obtenu cette erreur ? car moi je la vois pas , et je pense en désactivant l'affichage des erreurs je vais régler ce problème ! |
Sinon avant de mettre en ligne un site, on le test ![[:prodigy] [:prodigy]](https://forum-images.hardware.fr/images/perso/prodigy.gif)
Marsh Posté le 06-11-2009 à 19:48:53
Si vous avez un site web et vous voulez savoir sa valeur ou simplement pour connaitre la valeur et les gains de n'importe quel site par curiosité alors , je viens de mettre en ligne un petit service pour calculer le prix et les gains des sites c'est sur :
http://fr.valuatemywebsite.com/
merci de me faire vos retours et impressions, et améliorations sur ce forum,
