Web Intelligence : java.lang.NoClassDefFoundError
Web Intelligence : java.lang.NoClassDefFoundError - SQL/NoSQL - Programmation
Marsh Posté le 15-04-2010 à 11:37:45
Je souhaite utiliser Web Intelligence dans ma console d'InfoView (Nouveau--> Web Intelligence) mais lorsque je sélectionne un univers, une erreur Tomcat s'affiche.
Une idée ?
J4utilise BOXI release 2
Le log :
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
root cause
com.businessobjects.wp.tpi.TPPFactory.createProvider(TPPFactory.java:110)
com.businessobjects.wp.om.OMFactory.getProvider(OMFactory.java:73)
com.businessobjects.wp.om.OMFactory.init(OMFactory.java:60)
com.businessobjects.wp.tpi.TPPFactory.init(TPPFactory.java:45)
com.businessobjects.rebean.occa.OccaReportEngineComAdapter.initResources(OccaReportEngineComAdapter.java:290)
com.businessobjects.rebean.occa.OccaReportEngineComAdapter.getServerInstance(OccaReportEngineComAdapter.java:635)
com.businessobjects.rebean.wi.ReportEngineImpl.createServerInstance(ReportEngineImpl.java:626)
com.businessobjects.rebean.wi.occa.WebiReportEngine.createServerInstance(WebiReportEngine.java:408)
com.crystaldecisions.ePortfolio.plugin.crystalenterprise.webi.WebiCreateAction.gotoApplet(WebiCreateAction.java:142)
com.crystaldecisions.ePortfolio.plugin.crystalenterprise.webi.WebiCreateAction.autoWrapExceptionPerform(WebiCreateAction.java:107)
com.crystaldecisions.ePortfolio.framework.common.AutoWrapExceptionAction.process(AutoWrapExceptionAction.java:62)
com.crystaldecisions.webapp.struts.framework.AbstractEnterpriseAction.perform(AbstractEnterpriseAction.java:38)
com.crystaldecisions.ePortfolio.framework.common.IdentityAwareAction.perform(IdentityAwareAction.java:53)
org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1787)
org.apache.struts.action.ActionServlet.process(ActionServlet.java:1586)
com.crystaldecisions.webapp.struts.framework.CrystalUTF8InputActionServlet.process(CrystalUTF8InputActionServlet.java:29)
org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:510)
javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
