petit soucis au lancement de mySQL sous linux (REDHAT 9.0)
petit soucis au lancement de mySQL sous linux (REDHAT 9.0) - SQL/NoSQL - Programmation
Marsh Posté le 01-07-2004 à 17:58:13
voici le message que j'obtiens lorsque je veux me connecter à ma base mySQL
ERROR 2002: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (2)
A quoi cela correspond-t-il?
Marsh Posté le 01-07-2004 à 18:02:17
http://www-fr.mysql.com/doc/fr/Con [...] cting.html
User Comments
Posted by Jey Jegathesan on November 20 2003 10:18am [Delete] [Edit]
Issue the command
mysql -h localhost -u root -p
and if you get an error like "Error 2002: Can't connect to local mysql server through socket ........... (port)"
it means you don't have the mysqld daemon running. Activate it under RedHat by going into the "Services" under "Server Settings" or issue the command "service mysqld start",
and followed by to issuing the "mysql -h localhost -u root -p" command.
EDIT : copier/coller du message d'erreur sur google...
Message édité par jagstang le 01-07-2004 à 18:02:42
What if I were smiling and running into your arms? Would you see then what I see now?
Marsh Posté le 01-07-2004 à 19:01:11
merci !!!
