MySQL et Linux : déplacer le repertoire de stockage des bases ?
MySQL et Linux : déplacer le repertoire de stockage des bases ? - SQL/NoSQL - Programmation
Marsh Posté le 21-03-2003 à 23:57:46
Est ce possible ?
actuellement, mes tables sont stockées dans /var/lib/mysql/
j'aimerai déplacer le bazar ailleurs, et que mysql les lis a leur nouvel emplacement.
Dans le my.cnf, je n'ai pas vu de telle rubrique, donc est ce possible ? :'(
Marsh Posté le 22-03-2003 à 00:00:23
si je ne m'abuse, il y a une directive datadir dans ce fichier
Marsh Posté le 22-03-2003 à 00:02:35
# Example mysql config file.
# You can copy this to one of:
# /etc/my.cnf to set global options,
# mysql-data-dir/my.cnf to set server-specific options (in this
# installation this directory is @localstatedir@) or
# ~/.my.cnf to set user-specific options.
# One can use all long options that the program supports.
# Run the program with --help to get a list of available options
# This will be passed to all mysql clients
[client]
port            = 4500
socket          = /tmp/mysql_2.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# The MySQL server
[mysqld]
default-character-set   = latin1
port            = 4500
language        = /usr/local/mysql/share/mysql/english/
base            = /usr/local/mysql
skip-locking
set-variable    = key_buffer=64M
set-variable    = max_allowed_packet=1M
set-variable    = thread_stack=128K
set-variable    = table_cache=200
set-variable    = read_buffer_size=256K
set-variable    = read_rnd_buffer_size=256K
set-variable    = back_log=300
set-variable    = thread_cache=200
set-variable    = query_cache_size=16M
set-variable    = sort_buffer_size=256K
set-variable    = delayed_insert_timeout=150
set-variable    = wait_timeout=20
set-variable    = max_connections=320
set-variable    = myisam_sort_buffer_size=128M
set-variable    = thread_concurrency=2
innodb_data_file_path = ibdata1:10M:autoextend
set-variable = innodb_buffer_pool_size=140M
set-variable = innodb_additional_mem_pool_size=40M
set-variable = innodb_log_file_size=5M
set_variable = innodb_log_buffer_size=16M
innodb_flush_log_at_trx_commit=1
## Start logging
#log
[mysqldump]
#quick
#set-variable   = max_allowed_packet=16M
[mysql]
#no-auto-rehash
[isamchk]
#set-variable   = key_buffer=16M
Marsh Posté le 22-03-2003 à 00:04:29
package ? compilé d'apres les souces ? c le seul fichier my.cnf que tu as ? dans le mien, dans la section [mysqld] y a une directive datadir qui me permet de specifier le repertoire data, comme son nom l'indique [:spamafote]
Marsh Posté le 22-03-2003 à 00:05:35
MySQL 3.23.49 installé d'origine avec Mandrake 8.2
C'est bien le fichier my.cnf qu'il faut configurer ?
Message édité par skylight le 22-03-2003 à 00:05:52
Marsh Posté le 22-03-2003 à 00:18:29
Tu peux ajouter la directive si elle n'y est pas :)
