Optimiser mon My.cnf pour un gros forum
Optimiser mon My.cnf pour un gros forum - SQL/NoSQL - Programmation
Marsh Posté le 23-04-2010 à 07:49:23
Je souhaite optimiser mon my.cnf pour un gros forum phpbb, je dispose d'un serveur puissant avec 4GB de RAM mais je doute fortement que ma conf soit optimisee
des conseils?
  1. # The MySQL database server configuration file.
  2. #
  3. # You can copy this to one of:
  4. # - "/etc/mysql/my.cnf" to set global options,
  5. # - "~/.my.cnf" to set user-specific options.
  6. #
  7. # One can use all long options that the program supports.
  8. # Run program with --help to get a list of available options and with
  9. # --print-defaults to see which it would actually understand and use.
  10. #
  11. # For explanations see
  12. # http://dev.mysql.com/doc/mysql/en/ [...] ables.html
  13. # This will be passed to all mysql clients
  14. # It has been reported that passwords should be enclosed with ticks/quotes
  15. # escpecially if they contain "#" chars...
  16. # Remember to edit /etc/mysql/debian.cnf when changing the socket location.
  17. [client]
  18. port            = 3306
  19. socket          = /var/run/mysqld/mysqld.sock
  20. # Here is entries for some specific programs
  21. # The following values assume you have at least 32M ram
  22. # This was formally known as [safe_mysqld]. Both versions are currently parsed.
  23. [mysqld_safe]
  24. socket          = /var/run/mysqld/mysqld.sock
  25. nice            = 0
  26. [mysqld]
  27. #
  28. # * Basic Settings
  29. #
  30. user            = mysql
  31. pid-file        = /var/run/mysqld/mysqld.pid
  32. socket          = /var/run/mysqld/mysqld.sock
  33. port            = 3306
  34. basedir         = /usr
  35. datadir         = /var/lib/mysql
  36. tmpdir          = /tmp
  37. language        = /usr/share/mysql/english
  38. skip-external-locking
  39. #
  40. # Instead of skip-networking the default is now to listen only on
  41. # localhost which is more compatible and is not less secure.
  42. bind-address            = 127.0.0.1
  43. #
  44. # * Fine Tuning
  45. #
  46. key_buffer              = 128M
  47. max_allowed_packet      = 16M
  48. thread_stack            = 128K
  49. thread_cache_size       = 8
  50. # This replaces the startup script and checks MyISAM tables if needed
  51. # the first time they are touched
  52. myisam-recover          = BACKUP
  53. max_connections        = 1100
  54. table_cache            = 400
  55. # This replaces the startup script and checks MyISAM tables if needed
  56. # the first time they are touched
  57. myisam-recover          = BACKUP
  58. max_connections        = 1100
  59. table_cache            = 400
  60. #thread_concurrency     = 10
  61. #
  62. # * Query Cache Configuration
  63. #
  64. query_cache_limit       = 1M
  65. query_cache_size        = 16M
  66. #
  67. # * Logging and Replication
  68. #
  69. # Both location gets rotated by the cronjob.
  70. # Be aware that this log type is a performance killer.
  71. #log            = /var/log/mysql/mysql.log
  72. #
  73. # Error logging goes to syslog. This is a Debian improvement :)
  74. #
  75. # Here you can see queries with especially long duration
  76. #log_slow_queries       = /var/log/mysql/mysql-slow.log
  77. #long_query_time = 2
  78. #log-queries-not-using-indexes
  79. #
  80. # The following can be used as easy to replay backup logs or for replication.
  81. # note: if you are setting up a replication slave, see README.Debian about
  82. #       other settings you may need to change.
  83. #server-id              = 1
  84. #log_bin                        = /var/log/mysql/mysql-bin.log
  85. expire_logs_days        = 10
  86. max_binlog_size         = 100M
  87. #binlog_do_db           = include_database_name
  88. #binlog_ignore_db       = include_database_name
  89. #
  90. # * BerkeleyDB
  91. #
  92. # Using BerkeleyDB is now discouraged as its support will cease in 5.1.12.
  93. skip-bdb
  94. #
  95. # * InnoDB
  96. #
  97. # InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
  98. # Read the manual for more InnoDB related options. There are many!
  99. # You might want to disable InnoDB to shrink the mysqld process by circa 100MB.
  100. #skip-innodb
  101. #
  102. # * Security Features
  103. #
  104. # Read the manual, too, if you want chroot!
  105. # chroot = /var/lib/mysql/
  106. #
  107. # For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
  108. #
  109. # ssl-ca=/etc/mysql/cacert.pem
  110. # ssl-cert=/etc/mysql/server-cert.pem
  111. # ssl-key=/etc/mysql/server-key.pem
  112. [mysqldump]
  113. quick
  114. quote-names
  115. max_allowed_packet      = 16M
  116. [mysql]
  117. #no-auto-rehash # faster start of mysql but no tab completition
  118. [isamchk]
  119. key_buffer              = 16M
  120. #
  121. # * NDB Cluster
  122. #
  123. # See /usr/share/doc/mysql-server-*/README.Debian for more information.
  124. #
  125. # The following configuration is read by the NDB Data Nodes (ndbd processes)
  126. # not from the NDB Management Nodes (ndb_mgmd processes).
  127. #
  128. # [MYSQL_CLUSTER]
  129. # ndb-connectstring=127.0.0.1
  130. #
  131. # * IMPORTANT: Additional settings that can override those from this file!
  132. #   The files must end with '.cnf', otherwise they'll be ignored.
  133. #
  134. !includedir /etc/mysql/conf.d/
Merci d'avance !
un blog sur Asterisk
