AFFICHER DANS UN DATAGRID - VB/VBA/VBS - Programmation
MarshPosté le 12-05-2004 à 15:28:46
BONJOUR JE VOUDRAIS AFFICHER DES DONNEES DANS MON DATAGRID MAIS CA DONNE LE MESSAGE D'ERREUR SUIVANT
LA METHODE OPEN DE L'OBJET RECORDSET A ECHOUE
Private Sub b_chercher_Click() Dim cn As New ADODB.Connection Dim rs As New ADODB.Recordset Dim n As Integer n = Val(InputBox("donnez le numero d'inventaire SVP!", "MAGASIN" ))
If IsNumeric(n) Then cn.ConnectionString = "Provider=Microsoft.Jet.OLEDB.4.0;" _ & "Data Source=MAGASIN.mdb;" _ & "Persist Security Info=False" cn.Open rs.ActiveConnection = cn rs.Source = " SELECT Decharge.NInvo, Professeur.Nom, Decharge.DateSortie, Decharge.DateEntree, Materiel.REF, Decharge.Observation, Section.Libile " _ & " FROM [Section] INNER JOIN (Professeur INNER JOIN (Materiel INNER JOIN Decharge ON Materiel.NInvo = Decharge.NInvo) ON Professeur.CodeProf = Decharge.CodeProf) ON Section.CodeSec = Decharge.CodeSec" _ & " WHERE Decharge.NInvo =" + Str(n) + " ,cn,adopendynamic" rs.Open Set DataGrid1.DataSource = rs rs.Close cn.Close End If[/g] End Sub
Marsh Posté le 12-05-2004 à 15:28:46
Dim n As Integer
cn.Open
rs.Open
rs.Close
cn.Close
End If[/g]
End Sub
MERCI DE VOTRE AIDE
