pb sur comparaison de 2 fichier text - VB/VBA/VBS - Programmation
Marsh Posté le 16-07-2004 à 16:56:38
c'est pas
| Citation : loop While ((Not ts.AtEndOfStream) And (Not pb="sortir" )) |
plutot que
| Citation : loop While ((Not ts.AtEndOfStream) Or (Not pb="sortir" )) |
Marsh Posté le 16-07-2004 à 16:50:28
voici mon code j'ai un probleme car il reste dans ma 2éme boucle il ne ve pas sortir pouvez vous m'aider
dim nom, prenom, classe, total
dim nom1, prenom1, classe1, total1
dim pb
set fs = CreateObject("Scripting.FileSystemObject" )
set ff = fs.GetFile("Comptes1.txt" )
set t = ff.OpenAsTextStream(1, -2)
do
q = t.ReadLine 'Read a line in the file, put the line in s
fields = Split(q, ";" ) 'Separate the fields and put them in the array fields
nom1 = trim(fields(0))
prenom1 = trim(fields(1))
classe1 = trim(fields(2))
'wscript.echo ("NOM 1 " + nom1)
'wscript.echo ("PRENOM 1 " +prenom1)
'wscript.echo ("Statuts 1 " +classe1)
total1=nom1+prenom1
set fso = CreateObject("Scripting.FileSystemObject" )
set f = fso.GetFile("Comptes2.txt" )
set ts = f.OpenAsTextStream(1, -2)
do
s = ts.ReadLine 'Read a line in the file, put the line in s
fields = Split(s, ";" ) 'Separate the fields and put them in the array fields
nom = trim(fields(0))
prenom = trim(fields(1))
classe = trim(fields(2))
'wscript.echo ("NOM 2 " + nom)
'wscript.echo ("PRENOM 2 " +prenom)
'wscript.echo ("Statuts 2 " +classe)
total=nom+prenom
if (total1 = total) then
pb="sortir"
wscript.echo ("bon "+total)
Else
pb="delete"
wscript.echo ("Pas bon " +total +" et "+total1)
End If
loop While (Not t.AtEndOfStream)
