Suppresion de dossier
Suppresion de dossier - VB/VBA/VBS - Programmation
Marsh Posté le 03-05-2005 à 11:59:57
Set objFSO = CreateObject("Scripting.FileSystemObject" )
Set objFolder = objFSO.GetFolder("\\Mgdn0954\c$\Documents and Settings\" )
Set colSubfolders = objFolder.Subfolders
For Each objSubfolder in colSubfolders
'    Wscript.Echo objSubfolder.Name, objSubfolder.Size
 if (objSubfolder.Name<>"Administrateur" ) then
 if (objSubfolder.Name<>"All Users" ) then
 if (objSubfolder.Name<>"LocalService" ) then
 if (objSubfolder.Name<>"NetworkService" ) then
 if (objSubfolder.Name<>"Default User" ) then
 strComputer = "MGDN0954"
 Set objWMIService = GetObject("winmgmts:" _
     & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2" )
 Set colFolders = objWMIService.ExecQuery _
     ("Select * from Win32_Directory where Name = 'C:\\Documents and Settings\\"&objSubfolder.Name&"'" )
 For Each objFolder in colFolders
     errResults = objFolder.Delete
  Wscript.Echo objSubfolder.Name&"  "&errResults
 Next
 end if
 end if
 end if
 end if
 end if
Next
Wscript.Echo "pwet"
J'ai fait ce script pour supprimer des dossiers mais quand je le lance il me met des erreurs 14.
Quelle est cette erreur, et comment y remedier ???
