transformation xml et mauvais balisage
transformation xml et mauvais balisage - XML/XSL - Programmation
Marsh Posté le 15-12-2008 à 15:42:06
Bonjour a tous
voici mon code "mal formé" :
<?xml version="1.0" encoding="UTF-8"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
    <xsl:template match="/">
        <PROJ_Name>
          <xsl:for-each select="PROJ_Name/PERS_Name">
            <xsl:if test="not(preceding::PROJ_Name/PERS_Name/PROJ_Name = PROJ_Name)">
              <PERS_Name2>
                <PROJ_Type><xsl:value-of select="PROJ_Type"/></PROJ_Type>
                <PROJ_Name><xsl:value-of select="PROJ_Name"/></PROJ_Name>
                <PROJ_State><xsl:value-of select="PROJ_State"/></PROJ_State>
                <PROJ_Policy><xsl:value-of select="PROJ_Policy"/></PROJ_Policy>
                <PROJ_Description><xsl:value-of select="PROJ_Description"/></PROJ_Description>
                <PROJ_Owner><xsl:value-of select="PROJ_Owner"/></PROJ_Owner>
                <PERS>
                  <PERS_Name>
                    <PERS_Type><xsl:value-of select="PERS_Type"/></PERS_Type>
                    <PERS_State><xsl:value-of select="PERS_State"/></PERS_State>
                    <PERS_Policy><xsl:value-of select="PERS_Policy"/></PERS_Policy>
                    <PERS_Description><xsl:value-of select="PERS_Description"/></PERS_Description>
                  </PERS_Name>
            </xsl:if>
            <xsl:if test="preceding::PROJ_Name/PERS_Name/PROJ_Name = PROJ_Name">
              <PERS_Name>
              </PERS_Name>
              <xsl:if test="not(following::PROJ_Name/PERS_Name/PROJ_Name = PROJ_Name)">
                   </PERS>
                 </PERS_Name2>
              </xsl:if>
            </xsl:if>
          </xsl:for-each>
        </PROJ_Name>
    </xsl:template>
</xsl:stylesheet>
je sais qu'en xsl on ne peu fermer les balises de cet facon
mais comment puis je faire pour que ca marche ?
vous l'aurez compris je cherche juste a factoriser :
passer de ca :
<PROJ_Name>
- <PERS_Name>
  <PROJ_Type>Project Space</PROJ_Type>
  <PROJ_Name>88700</PROJ_Name>
  <PROJ_State>Complete</PROJ_State>
  <PROJ_Policy>Project Space</PROJ_Policy>
  <PROJ_Description>OneZig SW</PROJ_Description>
  <PROJ_Owner>daniel.thommen</PROJ_Owner>
  <PERS_Type>Person</PERS_Type>
  <PERS_Name>daniel.thommen</PERS_Name>
  <PERS_State>Active</PERS_State>
  <PERS_Policy>Person</PERS_Policy>
  <PERS_Description />
  </PERS_Name>
- <PERS_Name>
  <PERS_Name>fabian.buschor</PERS_Name>
  </PERS_Name>
- <PERS_Name>
  <PROJ_Name>BB MC Application 1</PROJ_Name>
  <PROJ_State>Archive</PROJ_State>
  <PROJ_Description>BlueBerry MC</PROJ_Description>
  <PROJ_Owner>patrice.declementi</PROJ_Owner>
  <PERS_Name>patrice.declementi</PERS_Name>
  </PERS_Name>
</PROJ_Name>
a ceci :
<PROJ_Name>
- <PERS_Name2>
- <PERS>
- <PERS_Name>
  daniel.thommen
  </PERS_Name>
- <PERS_Name>
  fabian.buschor
  </PERS_Name>
  </PERS>
</PERS_Name2>
<PROJ_Name>
merci d'avance de l'aide que vous pourriez m'apporter
désolé pour le double post mais je voulai bien décrire mon probleme
Marsh Posté le 15-12-2008 à 16:20:39
Faut faire des regroupements, si tu utilises un processeur XSLT 2.0 c'est pas très dûr à faire, par contre si ton processeur c'est du XSLT 1.0 t'es parti pour te taper du muenchian, et c'est pas exactement le truc le plus drole du monde.
Amuses toi bien.
I mean, true, a cancer will probably destroy its host organism. But what about the cells whose mutations allow them to think outside the box by throwing away the limits imposed by overbearing genetic regulations? Isn't that a good thing?
Marsh Posté le 15-12-2008 à 16:44:23
merci pour les liens
j'ai l'impression d'etre malheureusement en 1.0
quelqu'un serai motivé pour me faire un exemple simple avec muenchian
car je debute totalement et ne comprend pas grand chose
