GLANZ YF-1A CD/VCD, TV, TAPE, DVD independent input ports / AC-3, DTS ready - Individual control for : Front, Surround, Center & Subwoofer volume - Q-sound 5.1 channel output - Full function remote control / Magnet shielded speakers - Built in OCL Ampilfer
디자인과 성능의 혁신 - 데스크탑 HOME THEATER의 최적 솔루션 - DVDP, PS2, X-BOX, GAME등 완벽한 호완 - 세련된 디자인인으로 시각적 디스플레이의 품격화 서포팅 - DRIVE ROLLING 기술로 만든 밀도 높은 BR-5100K SPEAKER DRIVERS는 외곡 없는 고음질 출력 - 완벽한 방자형의 설계로 모니터등 자성에 영향을 주지 않습니다.
5.1CH Desktop Home Theater surround system DTS, AC3, Dolby Digital DVD Ready Support 3D positioning sound : Support 3D positioning sound, to falling down gaming world. You can palyed very exciting game and 3d DVD surround sound. Control Box for Easy-To-Use Operation Wall Mounting Satellites for Optional Best Location Built-in Amplifier Master/Subwoofer Volume Control Power On/Off with LED Indicator Magnetic shield : All the speakers are made with Anti-magnesium. Feel free to put the speakers as near as you like to your PC and Data disks. Your kinescope and data are safe and the color of screen will never jam!
BR-5100T 5.1 En Bois plus sage
- 5.1 Desktop Home Theater Sound - DTS, AC3, Dolby Digital DVD Ready - 8" super mega base unit - 3.5" Full range 1"treble satellite unit - 100Hz-20KHz - Wireless remote control - All wooden made - Magnetic shield - Professional Hi-Fi Circuit / double LM1875 BTL amplifier chip - A/V style design - Front output : R.M.S 10W ×2(fo=1KHz,THD=10%) - Rear output : R.M.S 10W ×2(fo=1KHz,THD=10%) - Center output : R.M.S 12W(fo=1KHz,THD=10%) - Woofer output : R.M.S 60W(fo=50Hz,THD=10%) - Total R.M.S : 112W - Total P.M.P.O : 3500W - Input impedance : 20K Ohm - Controller : Wireless remote control, Volume, Surround, Center, Power, Woofer, Mute, →·← - Frequency Response : satellite:100Hz~20KHz / Sub-Woofer:20Hz~200Hz - Bass Unit : 8"(Ф210mm),8 Ohm(magnetic sheild) - Satellite Unit : 3.5" & 1" 4 Ohm(magnetic sheild) - Power input : AC 220V 60Hz 90W - Woofer size : 395(W)×296(H)×296(D)mm - Satellite size : 105(W)×191(H)×130(D)mm - Box size : 454(W)×415(H)×352(D)mm - Total Weight : 14.5Kg
Marsh Posté le 29-08-2003 à 23:22:04
en Coréen ..pas de doc en Us ...
Les Coréens nous sortent des produits locaux ... à suivre ..
Quelques exemples de produits inconnus ici ...
http://www.withcomputer.com/produc [...] ategory=18
http://www.comgate.co.kr/pricetable2.php3?cate=15
GLANZ YF-1A
ou le
GLANZ YF-2A
Quelques produits Britz ... http://www.britz.co.kr/kor/index.asp
AV-5100S - 5.1, 250Watts, DTS· THX·SDDS
BR-5100K celui là le plus design et complet ..
디자인과 성능의 혁신
SPECIFICATION
1. SUBWOOFER
POWER OUTPUT (R.M.S) : 15W
SUBWOOFER DRIVER : 3" MAGNETICALLY SHIELDED WOOFER
IMPEDANCE: 4 OHMS
2. SATELLITES
POWER OUTPUT (R.M.S) : TOTAL 15W
DRIVER: 2.5" MAGNETICALLY SHIELDED FULL RANGE SPEAKER
IMPEDANCE : 8 OHMS
3. FREQUENCY RESPONSE : 100Hz ~ 20KHz
4. CONTENT
SUBWOOFER : 170*110*246mm (H*W*D) * 1
SATELLITE : 100*76*85mm (H*W*D) * 5
CONTROL BOX : 145*60*171mm (H*W*D) * 1
FEATURES
Built-in Amplifier
Magnetic shield
- 100Hz-20KHz
- All wooden made
- Magnetic shield
- A/V style design
Encore plus Délirant
http://www.easternmulti.co.kr/
Ceron AV5 (Subwoofer/800watt) Digital
Dolby Digital, Dolby Sorround Pro Logic
Ceron AV7 (Subwoofer/1000watt) Digital
Message édité par durtt le 30-08-2003 à 00:09:08
newbie for ever ....
