PB NERO DEFAUT DE CIBLE INTERNE - Matériel - Video & Son
MarshPosté le 24-08-2005 à 13:40:51
HELLO
Je me permets de remettre un post sur ce pb car personne n'a vu mon message hier .
Donc j'ai un pb avec mon graveur et voici le log de nero
Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 01/02/2001 15:10:18 ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26/10/2004 16:21:30 Nero Version: 6.6.0.6 Recorder: <PIONEER DVD-RW DVR-109> Version: 1.50 - HA 1 TA 0 - 6.6.0.6 Adapter driver: <atapi> HA 1 Drive buffer : 2000kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <PIONEER DVD-RW DVR-109 >Version: 1.50 - HA 1 TA 0 - 6.6.0.6 Adapter driver: <atapi> HA 1
=== Scsi-Device-Map === DiskPeripheral : Maxtor 2B020H1 atapi Port 0 ID 0 DMA: On DiskPeripheral : ST3160021A atapi Port 0 ID 1 DMA: On CdRomPeripheral : PIONEER DVD-RW DVR-109 atapi Port 1 ID 0 DMA: On CdRomPeripheral : MITSUMI CR-48X5TE atapi Port 1 ID 1 DMA: On
AutoRun : 1 Excluded drive IDs: WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 BUFE : 0 Physical memory : 1023MB (1047788kB) Free physical memory: 547MB (560784kB) Memory in use : 46 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0)
24.8.2005 CD-ROM (ISO) 10:56:17 #1 Text 0 File Isodoc.cpp, Line 6168 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE
10:56:18 #2 Text 0 File Burncd.cpp, Line 2870 PIONEER DVD-RW DVR-109 Protection contre les ruptures activés
10:56:18 #3 Text 0 File Reader.cpp, Line 127 Reader running
10:56:18 #4 Text 0 File Writer.cpp, Line 122 Writer PIONEER DVD-RW DVR-109 running
10:56:18 #5 ISO9660GEN -11 File geniso.cpp, Line 3286 First writeable address = 0 (0x00000000)
10:56:18 #6 Text 0 File Burncd.cpp, Line 3155 Turn on Disque entier, using CD-R/RW media
10:56:19 #7 Text 0 File DlgWaitCD.cpp, Line 257 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 293222 ( 65:11.47)
10:56:19 #8 Text 0 File DlgWaitCD.cpp, Line 269 Write in overburning mode: NO (enabled: CD)
10:56:19 #9 Text 0 File DlgWaitCD.cpp, Line 2311 Recorder: PIONEER DVD-RW DVR-109; CDR code: 00 97 27 18; OSJ entry from: Plasmon Data systems Ltd. ATIP Data: Special Info [hex] 1: D0 00 A0, 2: 61 1B 12 (LI 97:27.18), 3: 4F 3B 4A (LO 79:59.74) Additional Info [hex] 1: FF FF FF (invalid), 2: FF FF FF (invalid), 3: FF FF FF (invalid)
10:56:19 #10 Text 0 File DlgWaitCD.cpp, Line 431 >>> Protocol of DlgWaitCD activities: <<< =========================================
10:56:19 #11 Text 0 File ThreadedTransferInterface.cpp, Line 829 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 293223 (293223) = #293223/65:9.48 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_ULTRARAW96_MODE1, 2448, config 4, wanted index0 0 blocks, length 293223 blocks [PIONEER DVD-RW DVR-109] --------------------------------------------------------------
10:56:19 #13 Phase 24 File dlgbrnst.cpp, Line 1832 Caching of files started
10:56:37 #14 Text 0 File Burncd.cpp, Line 4042 Cache writing successful.
10:56:37 #15 Phase 25 File dlgbrnst.cpp, Line 1832 Caching of files completed
10:56:37 #16 Phase 36 File dlgbrnst.cpp, Line 1832 Burn process started at 32x (4 800 Ko/s)
10:56:37 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2604 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:56:37 #18 Text 0 File Mmc.cpp, Line 16327 StartDAO : CD-Text - Off
10:56:37 #19 Text 0 File Mmc.cpp, Line 21079 Set BUFE: Buffer underrun protection -> ON
10:56:41 #20 Text 0 File Cdrdrv.cpp, Line 1284 10:56:41.593 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
10:57:00 #21 Text 0 File Cdrdrv.cpp, Line 1284 10:57:00.062 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
10:57:01 #22 Text 0 File Cdrdrv.cpp, Line 1284 10:57:01.125 - PIONEER DVD-RW DVR-109\H1 T0 : Queue again later
10:57:02 #23 SCSI -1061 File Cdrdrv.cpp, Line 1432 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x042C0000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x04 (KEY_HARDWARE_ERROR) Sense Code: 0x44 Sense Qual: 0x8E CDB Data: 0x2A 0x00 0xFF 0xFF 0xD9 0x5D 0x00 0x00 0x1A 0x00 0x00 0x00 Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x0E 0x00 0x00 0x00 0x00 0x44 0x8E
on m'a dit qu'il y avait des soucis avec daemons tools mais après avoir viré le registre de d tools et le prog ca marche toujours pas est-ce que qqcn a une idée de solutions
Marsh Posté le 24-08-2005 à 13:40:51
HELLO
Windows XP 5.1
IA32
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-109 O: CDRom0
MITSUMI CR-48X5TE G: CDRom1
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
24.8.2005
CD-ROM (ISO)
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
ATIP Data:
10:56:19 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1042
Prepare recorder [PIONEER DVD-RW DVR-109] for write in raw writing
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_ULTRARAW96_MODE1, 2448/0x04, FilePos 0 367200 718177104, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0x00
-150 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
293223 | lead-out | 1 | 0x41 | 0x00
Sense Code: 0x44
Sense Qual: 0x8E
10:57:02 #24 CDR -1061 File Writer.cpp, Line 311
Internal target failure
10:57:02 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
10:57:02 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
10:57:02 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 32x (4 800 Ko/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 01/02/2001 15:10:12
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
