Probleme de mail sous XP mis en partage cnx ADSL ! - Windows & Software
Marsh Posté le 23-04-2002 à 00:34:26
Une idée comme une autre:
tu vas à cette adresse
http://www.dslreports.com/tweaks
tu fais le test puis tu suis le lien TWEAK FAQ ( http://www.dslreports.com/faq/tweaks )et tu lis tout ce qui concerne RWIN et MTU et le petit utlitaire DrTCP.
Exemple:
Finding the largest MTU, by EXPERIMENT
If your MTU is too low already, (maybe 576), the following method will not be able to detect whether you can switch to an optimal size..... So first follow "CHANGING MTU for PPPoE" to reset MTU to 1500, reboot, then come back to this!
The best value for MTU is that value just before your packets get fragmented. How do you find out that? By using Ping at an MSDOS command prompt.
Go to Start/ Programs/ MSDOS-PROMPT, and type....
ping -f -l 1472 www.dslreports.com
(That is a dash-ell not a dash-one. Also note the spaces in-between the sections) Press Enter. Then reduce 1472 by 10 until you no longer get the "packet needs to be fragmented" error message. Then increase by 1 until you are 1 less from getting "packet need to be fragmented" message again.
Add 28 more to this (since you specified ping packet size, not including IP/ICMP header of 28 bytes) And this is your MaxMTU.
Note:If you can ping through with the number at 1472, you are done! Stop right there. Add 28 and your MaxMTU is 1500.
For PPPoE, your MaxMTU should be no more than 1492, to allow space for the 8 byte PPPoE "wrapper", but again,
experiment to find the optimal value.. For PPPoE, the stakes are high: if you get MTU wrong, you may not just be sub-optimal, things like UPLOADING, or web pages, may stall, or not work at all!
[jfdsdjhfuetppo]--Message édité par FlyingFader le 23-04-2002 à 01:28:10--[/jfdsdjhfuetppo]
Marsh Posté le 23-04-2002 à 00:44:52
J'ai mon MTU à 1480 sur le PC client...
et le serveur, pareil
J'utilise la pile PPpOe de winxp
Marsh Posté le 23-04-2002 à 00:51:26
ReplyMarsh Posté le 23-04-2002 à 01:32:53
Essaies :
Sur le PC "server" :1492
Sur les client établi la valeur optimale par ce test:
et configures les clients selon le résultat.
Marsh Posté le 23-04-2002 à 07:47:30
le mtu tu le changes sur la carte réseau avec le prog qui est sur le site c'est ca ?
Marsh Posté le 23-04-2002 à 10:19:59
Je crois que je viens de comprendre ce qui se passe, je vais remettre la pile RASPPPoE qui gere la MTU > 1480, a mon avis, c'est ca...
Le MTU path discovery ne marche pas bien, vu que les pcs trouve 1480, mais je sens qu'il y a une probleme la
Marsh Posté le 23-04-2002 à 10:43:42
http://perso.wanadoo.fr/doc.jm/MTU.htm
Je crois que c'est clair
Vive XP !
Marsh Posté le 22-04-2002 à 23:10:24
Voila, je suis victime d'un truc INCROYABLE!
J'ai un pc sous XP qui partage une connection ADSL, j'arrive à acceder aux emails avec les autres PCs du réseaux, mais dès que je recupere un email, il y a un time out...
Or, si le mail est petit: genre 1 ou 2 ko, cela marche apres 4/5 ko, il y a timeout!
Bizarre, j'ai viré le firewall de windows, et ca fait pareil
HELP!
une idée ?
Vide Grenier V4 | Mon feedback
